Not familiar with this model but all cd tray's have a manual release mechanism, its usually a small hole on the front of the tray. I've found a paper clip unwound usually works fine. Push it in the small hole, you will feel it stop against something, push a little harder and the tray should open enough for you to manually pull it open.
only getting crackles out of speakers, if left off for a while it will work again but only for about...
(More)
only getting crackles out of speakers, if left off for a while it will work again but only for about 10 seconds, does not matter what input is selected including the built in receiver
My Yamaha RX-V596 Reciever is not video switching properly. It's stuck on cab/sat, which works fine,...
(More)
My Yamaha RX-V596 Reciever is not video switching properly. It's stuck on cab/sat, which works fine, so it's passing the signal, but when I switch to DVD, I get nothing (svid or composite) Can I replace a part for this, or is it dead?
as soon as I turn stereo on it turns right back off. I press the power button and nothing happens. I...
(More)
as soon as I turn stereo on it turns right back off. I press the power button and nothing happens. I press power again and it turns on but two seconds later the power shuts off automatically.
no noise just light static noise nothing on am/fm nothing on surround just light static have to hold...
(More)
no noise just light static noise nothing on am/fm nothing on surround just light static have to hold to your ear to hear its so light
