86120-47400 pinout rear camera connection to radio
What is the pinout for this radio that was in a Hyundai Santa Fe 2005?
Do you need Wiring Diagram for hyundai santa fe.Or you need where the radio fits in hyundai santa.The connector of radio.
Please Check the link mentioned below it has all wiring diagram for hyundai santa fe radio.Also it has details for how to connect radio connector.
http://www.allcarhelp.com/2016/05/hyundai-santa-fe-radio-wiring-diagram.html
If you need anything else,please reply.
Thanks.
May 11, 2016 | Hyundai Cars & Trucks
Salvaged webcam from laptop to galaxy note 2 via pinout otg cable and generic webcam app ?
Webcam is actually just a USB connection. Shouldn't need a hardware driver for modern OS. There are generalized apps out there to encode MPEG or AVI, ect. video, but they don't need to be hardware specific. That's where a "standard USB imaging device" driver usually comes in.
Leads are: +5V, Data-, Data+, Ground.
Here's image of a typical pinout to cam ...hope this helps. 8bcfe473-4739-4a75-8ef3-aa38e60e14cb.jpg
Feb 27, 2014 | Computers & Internet
PINOUT FOR FORD FOTF-19B132-AA RADIO
1990 Ford F150 Truck Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Sep 13, 2012 | 1990 Ford F150
IC-M504 with a rear panel microphone jack-- what is the pinout?
ICOM or even HRO may be able to provide you with a schematic for that pinout.
Jun 04, 2012 | Icom IC - M504 Black Submersible PLUS...
Model D3057F3H Want to use it to power a car radio. What is the on / off connection and what is the 12V out let than can handle 5amp
Check the label on the power supply for the current rating on 12 volts.
The +12 volt is the yellow colored wire and the black is the ground.
To turn on the switch mode power supply connect pin 14 (for a 20pin connector) or pin 18 (for a 24pin connector) to ground.
You can use a switch so you can turn the power supply ON and OFF.
Please click on this link for diagrams of the 20 and 24 connector pinouts :-
http://pinouts.ru/Power/atxpower_pinout.shtml
http://pinouts.ru/Power/atx_v2_pinout.shtml
Sep 12, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Sony DCR-SR32 lost docking station is there a usb lead that will connect camera to my pc
http://pinouts.ru/Home/sony_dcra_pinout.shtml here is the pinout from the camera.if u cand handle it work but u need some exprerience to do this.to buy some cable ...i think nope
Sep 28, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Wiring diagram
Hello birdhunter, no the cobra 200 has the same pinout as the 29's and such, but the color code might be different.
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
STOCK Pinout Let me know how you get along with it,,,, Mechanic
1- Shield
2- Audio
3- Transmit
4- Receive
Sep 14, 2008 | Magnum DeltaForce CB Radio
Panasonic CQ-DP620AEUC pinout (car radio/CD player) bought used from my brother. He didn't have the wiring pinout diagram anymore. Which wire is the "memory" connection to 12 VDC?
Yellow wire is always the memory or back up, which is always 12 volts even with key off. Red is for ignition, 12 volts only when key is on. Black is ground. Speakers are color coded in pairs, the grey and white pairs are the fronts and the green and purple pairs are the rear speakers. Each speaker wire with a black stripe is the negative speaker lead and the solid color is the positive.
If you need more help just let me know and a FixYa! rating would be appreciated.
Thanks,
Dave
Jul 13, 2008 | Car Audio & Video
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
