Question about Boxlight Projector Lamp for MP-40t, SE-13HD, CINEMA 13HD
Cinema 13HD cuts off
Every time I sit to watch a movie, after approx 7-8 min's the projector cuts itself off. Once I did see that the "warning temp light" was on. Normally this only happens once or twice during a 1:45 long movie. What could be my problem?
CLEAN THE FILTERS IT IS OVER HEATING, HAD SAME PROBLEM
Posted on Feb 01, 2009
What are the benefits of watching movies online?
None. Go to a cinema, much better and more chance to meet people and keep the cinema owner in business.
Jun 12, 2017 | The Computers & Internet
One Blue line is on the screen
open up the projector and you will see a small screen attached to the lamp and a Flex Cable attached to the screen,
Remove the cable and Clean it with Alcohol Liquid from both sides then put it back and check.
Aug 02, 2015 | Epson PowerLite Home Cinema 3020 LCD...
How doi get the projection to 1080 resolution and do i need any thing extra to watch a movie in 3 D
What are you connecting the projector to?
The source needs to be sending a 1080p data stream.
Apr 05, 2014 | RCA Morelli Cinema Hdx-44 Tv Projector
Turned on the projector and it immediately shut down and now has no power
it seems that the lamp ballast is failing
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
lampdeng@hotma
Mar 09, 2014 | Boxlight Cinema 13HD Lamp
When you are watching on projector sanyo PLV-Z2 it goes off and
overheating. possible fan malfunction. clean out the projector with canned air. dust keeps in the heat.
Oct 24, 2009 | Sanyo PLV-Z2 Multimedia Projector
Sanyo plv z2000 warning led it shutdown
Check all the fans if its working or avoid anything that cover the exhaust fan, or the temperature of your room.
Oct 23, 2009 | Sanyo PLV-Z2000 Projector
Power cuts off periodicly
Maybe. Try a larger guage extension cord.
Jun 11, 2009 | Sony STR-DG820 Receiver
Optoma H31 - Turns itself off !
sounds like the projector lamp to me. the rated hours are always up to the published hours and never "this is what you will achieve." I would suggest getting a lamp as you will need one shortly by the sounds of it. In many cases the projector does this as it is programmed to protect itself from the lamp shattering inside the projector. Let me know if you would like a quotation for a lamp as we ship internationally. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Mar 28, 2009 | Optoma H31 HOME THEATER PROJECTOR...
Projector image burn (retention)
first off, make sure you got the right lamp and it's from sharp, not a "lamp store". the quality varies. it could be burning hotter than it's designed for. second, you may need to reset the setting to factory default (through the menu options). third, you may need flash upgrade. you'll need to contact a sharp service center for that.
Mar 28, 2009 | Sharp Projector lamp Projector Lamp
Optoma projector switches off after 5 mins
AS regretable as this sounds component failiure was my first thought .. It's not the bulb temp sensor as the fan is opperating and that usually cuts all power .
You may find that as you have a bulb ( usually worth more than the units they reside in ) rather than a repair another unit of Ebay would be a safer and more economic conclusion ... Regards Vortash
Jan 14, 2009 | Optoma HD72 Multimedia Projector
Boxlight  Projector Lamp for MP-40t, SE-13HD, CINEMA 13HD Logo
132 people viewed this question
Top Boxlight Office Equipment & Supplies Experts
jasbo
jasbo
Computer Links
Mike Charette
Are you a Boxlight Office Equipment and Supply Expert? Answer questions, earn points and help others
