Question about Aiwa AV-D97 Receiver
Keeps shutting off
Okay, I admit, we do have a lot hooked up to our system; but we do our best to keep the receiver well-ventilated. It started every once in a while...just shutting off....especially when I'd turn the volume up. Now, It shuts off almost immediately, even with the vol. all the way down! HELP PLEASE! I can't afford a new system!
  • quattro_28 Dec 23, 2008
    Helle,
    i have the same Problem. If i connect with Power the Stand-By LED switched on and all i get is an klick Sound: "klick.... klick, klick. Thats all. Somtimes i see at the Display "Good-Bye".
    All Inputs, Outputs and Speekers are disconnect, always the same Problem.
    What can be the reason ?
    Mike
  • xxshadow17xx Mar 02, 2009
    I have the same problem too. I tried resetting the unit by pressing the enter and power button at the same time but no luck. All i get is the click to turn on and click when it automatically shuts off. The display lights come on, on the first click but it shuts off immediately. Also when i press the enter button when the unit is off, It will shut off very quickly so i cant even set the time.
    New Friend:
  • 83 Answers
Are you able to check whether any of your speakers may have been blown? or have a direct short to ground ..this usually indicated by the amplifier protecting itself and shutting down,, try un plugging one speaker at a time and you may find that it is one of the speakers ....then get a replacement or get it repaired
Posted on Jul 09, 2007
SOURCE:
Yamaha RX-V1600 shutting off
try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happend to me on RX-V592
Jan 21, 2013 | Yamaha Audio Players & Recorders
Reciever keeps shutting off!
If your reciever is in a tight enclosed space, than it will overheat and shut down to protect itself. Try to get some ventilation to it by either opening the cabinet door, adding a fan, or pulling it completely out of the enclosed space.
Jan 05, 2011 | Pioneer VSX-33TX Receiver
The receiver keeps turning itself off. I've had it hooked up in the current configuration for over 8 months with no problems and tonight it started shutting off.
the best thing to do is turn off the speaker outputs, if you have the capability on the front panel, turn off the unit, disconnect all speakers. after that, turn it back on and see if it works ok. turn the speaker switch back on, do all the clicks from the relays sound normal? is it on now? if so, you have a bad speaker. connect them 1 at a time til you find the bad one. if not, then the unit is bad and needs repair. it would likely have been caused by a defective speaker or internal component of the speaker, or the speaker wiring. good luck
Feb 11, 2010 | Pioneer VSX-D710S Receiver
Is it okay to hook up my playstation system to my projection tv?
It's OK as long as the picture keeps moving. Besides, that is for projection televisions not for LCD or DLP's
You should be fine.
I hope that this helps.
asnowman
Oct 01, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Sep 20, 2009 | Pioneer VSX-D509S Receiver
I have a samsung ht-tx75 and it keeps shutting down every 10 minutes saying protection.the fan is working
Protection is very likely caused by an over heat condition, even with the fan working if the receiver is in a very enclosed place that warms up and is not ventilated it will cause the problem. The solution is to provide more ventilation so that the receiver can cool itself properly.
Feb 26, 2009 | Samsung HT-TX72 Theater System
Dish ViP622 keeps crashing - on 6th unit from Dish network
the 622 receivers are very sensitive to static electricity build up, if you have been through more than two receivers i would demand having a technician come to your home to check grounding of your dish system, while he is there he will also check the grounding where you plug the receivers in, i suggest not using any surge protectors/power strips and, as debmaldo did, try different outlets, if you have a very high end surge protector, it should be okay but for troubleshooting purposes try a different wall receptacle
May 05, 2008 | DISH Network ViP622 DVR DTV Receiver /...
Receiver shuts off on its own
I have the same receiver and the way to fix is simple. in the main board of this unit there are 5 connectors and they slide into other components like Lego. the issue is the king of material they are made of it's cheap. if you reseat the mainboard it will fix it for a day or two, them it will start again. the easyway is to re seat the board and put a fan inside of the receiver between the transformer and the inside of the amp pointing down about 20 degrees connect the fan to a ajustible voltage adapter and connect it to the outlet in the back of the unit. so it comes on when you turn it on. this voltage adapter is cheap. the adapters people buy for phones and or MP3's at Radio shack or Best buy it goes from 1.5v to 12 volts/ this way you can control how loud the fan is in side the receiver. i find 4.5V does the trick. The connectors on this board start to loose contact with some of the pins when heated. the fan keeps it cool enouth to fix the issue. I fixed manny these ONKYO 804's this will fix it. you just have to do it. the main board is inder the HDMI board in a Vertical position running from one side to almost the Power supply. it has 2 screws also holding it in the inside middle back of the amp. Becarefull with these amps 75 V at 23amp's DC is no joje leave it off for a couple of hours to satart working on it. Good luck.
Apr 24, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
Aiwa AV-D97 Receiver Logo
384 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
