Question about Ricoh Aficio 1018D Copier
Connection error hey FixYa . I just add " Ricoh Aficio 1018D PCL 6 printer " into my computer .. and i am using "wifi" connection . And i have see RICOH Aficio printer showing up inside my Devices and Printer area.. and i test few print but no respond from printer.
  • tan shyh vei Jan 15, 2013
    @Computer Link the printer work well on other computer... but it
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
SOURCE: add toner
replace toner supply unit. inside of the unit are 4 mylars to push toner towards hopper exit gate. looks like them mylars are ripped off and the toner is not getting to the dev unit
Posted on Oct 26, 2008
SOURCE: Error message on Ricoh Aficio BP 20 PCL 6 printer
Flashing orange means low toner.....solid red should be a paper jam
Posted on Feb 21, 2009
  • 2385 Answers
SOURCE: Ricoh Aficio 1013F
you need to install printer on computer as network printer from the supplied CD.
Posted on Mar 27, 2009
  • 32 Answers
SOURCE: Ricoh Aficio MP 2510 netwrok printer all jobs from users are Acce
the reason why the job(s) at the workstation say they are completed, and there is no job at the printer, is because the user code management has been turned ON.
if you turn user code management on, and do not setup users, with user codes, then jobs will continue to run like they are now. either turn OFF user code management, or setup users in the address book of the printer.
Posted on Apr 02, 2009
Ricoh Aficio SP C430DN - Print Data Error
Its you, change drivers, postscript on the printer? PCL 5C is what your are using?
Mar 31, 2014 | Ricoh Office Equipment & Supplies
Use ricoh aficio 1018d as scanner
first do u hv a scanner and printer connection board in ur machine.if not its imossibal to work u must get one and install it.
Feb 11, 2014 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh aficio 1018D all in one printer is showing problem. No. SC 194
sc194 is an error with the scanner. It could be a bad exposure lamp, but it could also be a circuit board that needs to be replaced (either the SBU board or BICU board).
Mar 05, 2011 | Ricoh Aficio 1018D All-In-One Laser...
Hello, ricoh aficio 1018d error code display sc 925 what can i do for it.
IMB non-connected error
Symptom:
IMB is not connected. This SC only
appears with B040 and B043 version
machines.
Possible Cause:
• IMB is not connected
• Poor connection between BiCU and
IMB
• IMB defective
• BiCU defective
Sep 27, 2010 | Ricoh Aficio 1018D Copier
I have ricoh aficio 1018d can it fax or print and i cannot find connection points on machine
Sir,
You can fax or print with the aficio 1018d provided that you have the fax and printer options. these connection points are located at the back of the machine.
Mar 06, 2010 | Ricoh Aficio 1018D Copier
PCL XL ERROR - ILLEGALMEDIASOURCE
I would advise trying to use the PCL 5 Driver - I presume that at the moment you are probably using the PCL 6 driver.
If you need any further infor please post back with a little bit more info!
Aug 23, 2009 | Ricoh AFICIO SP4100NL MONO-LASERPR 31PPM...
Cant reset Z error at Printer Ricoh Aficio 1018D
Im assuming that you are referring to the Z as the jam light. In that case the operation panel will tell you what part of the machine is jammed by displaying a diagram and a letter that corresponds to a chart that you will see when you open the front door. make sure to open all the doors then close them to reset jam code (there is a hidden door on the right lower side called the A door) Good luck
Apr 05, 2009 | Ricoh Aficio 1018D All-In-One Laser...
Feb 20, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh aficio 1018 printer
yes you have to install the drivers and give the usb option for communication
Aug 05, 2008 | Ricoh Aficio 1018D All-In-One Laser...
Printer wont do anything ricoh aficio 1515 pcl 6
The first thing to try is to turn the machine off, then back on at the red "main power" switch located on the left side of the machine. If the code returns it is indicative of firmware problems or a loose connection.
At this point I would seriously recommend getting a service tech to come out. However, if you want, you can take off the back cover (MAKE SURE THE POWER CORD IS UNPLUGED) and double check all of the connections by (GENTLY) pressing them into their connections. Hope this helps. Let me know.
Mar 31, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
35 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
