Question about Konica Minolta Bizhub C550 Color Copier/printer/scanner
I am using a Bizhub C550. I want to print an Illustrator file without maing it a PDF. Once, I was lucky to print 8.5 X 11 file using the Bypass tray. I like rinting through Illustrator ai instead of I
I am using a Bizhub C550. I want to print an Illustrator file without making it a PDF. Once, I was lucky to print 8.5 X 11 file using the Bypass tray. I like printing through Illustrator ai instead of Illustrator PDF because ai. gives a sharper text. Today, however, the printer would not select the bypass tray and I don't know how I was able to make it print before, and I don;t know how to make it select the bypass pass.
    Habit-Forming:
    New Friend:
  • 36 Answers
The easiet way is to open all trays and load the bypass and tell the machine you loading 8.5 x 11 on bypass.
You can also set it on any tray within the menu of the copier under paper > then select tray > then change paper tray settings. Usually it is set to auto. but you can change bypass to what ever size you want with respect to the spec of the machine.
Posted on Sep 23, 2017
3 Suggested Answers
  • 44 Answers
SOURCE: Can't print onto thick card
In your print driver, you need to go to the Printer Features -> Media 1 window and specify "Thick 2" and then go back to the main print window and specify Paper Feed "Tray 2" Then go to the copier,, place the stock into tray 2 and match the paper setup for that tray on the copier to "Thick 2" for tray 2.
Basically, both the Mac and the copier need to match paper types and feed tray.
Posted on Nov 17, 2008
saxmansaxman
  • 177 Answers
SOURCE: My office has the bizhub
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
Posted on Mar 12, 2011
How do i print a # 10 business envelope with the bizhub c200
First recommended that you use the bypass tray on the right side, also before placing the envelope in the bypass tray send the print job over first, the screen will say replenish paper then go ahead and place the envelope on the tray. and let it take it or hit the start button Ensure you select #10 commercial media and bypass tray in your print driver preferences. May also want to have tech come out and look at the tray and run MAX and Min. Adjustments.
Oct 09, 2012 | Minolta bizhub 200 All-In-One Printer
Bizhub C350 envelope problem
Load the envelopes in the bypass tray select paper on the copier control panel select by pass tray change tray select normal DO NOT select envelope select custom enter size, on printer preference select envelope tray and print
Apr 18, 2012 | Minolta bizhub 200 All-In-One Printer
My office has the bizhub c360, and when I put paper into the bypass tray, it prints from the main tray instead of the bypass tray. The settings on the printer are for bypass tray, the settings for my...
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
Can I print envelopes on my Bizhub 250
BYPASS TRAY is sed when printing onto paper with a size not loaded into a paper tray or onto thick paper, overhead projector transparencies, postcards, envelopes or label sheets Can be loaded with up to 150 sheets of plain paper, 50 overhead projector transparencies, postcards, label sheets or sheets of thick paper, or 10 envelopes referred to as the "bypass tray" throughout the manual. (See page 2-60....ATTACHED )
ftp://207.18.56.26/software/BPG/Userbizhub200250350CopyOperPh2_5.pdf
Feb 15, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
How do I print labels on the bizhub 222
Be sure to load label sheets so that the side to be printed on faces down and a maximum of 50 label sheets can be loaded into the bypass tray.
USER MANUAL page 2-64
http://kmbs.konicaminolta.us/productsattachments/manuals/bizhub362SeriesCopyOperationUserManual.pdf
Jan 06, 2011 | Konica Minolta Bizhub 222 Black and White...
Epson Stylus NX410 won't print in Adobe Illustrator CS
Try to print your file in jpeg or tiff format.Good luck!
Jan 12, 2010 | Epson Office Equipment & Supplies
Toshiba 281C Bypass tray
Problem isn't "solved", but have realized that the issue is related to the fact that the document I am trying to print is formatted for envelopes. When I print a regular word document (letter) it prints fine to the Bypass tray. It must have something to do with the fact that the document is 1000 envelopes. If I print to a PDF file, then print the document to the Bypass Tray I don't seem to have a problem.
Feb 17, 2009 | Toshiba Estudio 200L Copier
Printing envelopes on the bizhub 252
After spending way too long messing around with this on my bizhub 250 here's what finally allowed me to print:
I simply changed the bypass tray setting from "envelope" to "normal". I kept the custom size the same (9 1/2 X 4 1/8) and it started to print.
Doesn't make sense, but you can give it try.
Dec 27, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Bizhub C550 Color Copier/printer/scanner Logo
54 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
