Question about Kenmore Refrigerators
Off switch for refrigerator
Model 795.76202.901 Is there an off switch
Where is the defrost switch on 106.53592300
Not sure there is a manual defrost switch. Look at the link below for defrost switches for your model. On some refrigerators, if you set the temperature switch to off and unplug then plug in the refrigerator it will force the defrost mode; then unplugging and plugging again will reset the mode.
Oct 20, 2014 | Kenmore 57029 Side by Side Refrigerator
Where is the on off switch on a sub zero refrigerator model 736TCI
There is no on/off switch for this model, simply unplug the frig. Some models have a switch for the ice maker, but not the frig itself. If it's a vacation thing you can turn the thermostat up, but your frig could have a musky smell upon returning.
Jul 10, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
MAYTAG REFRIGERATOR MODEL RSW2700
Are you sure your refrigerator came with an energy saver switch? I can't find one listed for the model you have. If you are trying to add one, that is not something that is easily done for the older models. If my documentation is incorrect and your model did come with an energy saver switch or you are looking for another part, then you might be able to get it through www.searspartsdirect.com . Just plug in your model number and select model # search and you will get different models of your refrigerator. Select the one that applies and look for the correct part.
Jan 23, 2012 | Maytag Refrigerators
Model GLH66EESB4 refrigerator. Makes ice but
Remove the ice bucket and auger assembly and hold the door switch closed while pressing the ice dispenser button to check for a dead motor. If it turns, try holding it with your hand to see if it can take a bind. If it will then your auger is the problem, if not it's motor time.
Mar 14, 2010 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator in-door water dispenser fails to work
First ... your model number is missing some on the end. please check your model number on the machine for the correct lookup of parts.
For your situation I found this model number # FRS22ZRHD1. Take a look at this picture of this models dispensor.
there are 3 switches # QT 2 -- 38a & 38b
this should be close to your model of fridge but you will half to make sure.
and yes you should just replace the bad switch.
Part numbers for the switches for this model # are 218479900 & 241689101
Jan 08, 2010 | Refrigerators
Whirlpool refrigerators model number ED22TEXHWOO does not feed ic
YOU COULD HAVE A BAD DOOR SWITCH OR AUGER MOTOR OR THER IS ALLSO THE SWITCH WHEN YOU PUT THE GLASS IN
Nov 06, 2009 | Refrigerators
How do you replace the light switch?
Unplug the refrigerator.Take a small skinny flat screw driver and pry the switch out. You can unplug it once you have it out but hold on to the wire so it does not fall into the refrigerator. Have the new switch ready to install or tie or tape the wire while you go get the new switch.
Oct 27, 2009 | Kenmore 57029 Side by Side Refrigerator
Light will not come on. not the bulb. everything
First lets start by unplugging the refrigerator and checking 4387911 Refrigerator Door Switch. Then let me know if the door switch is good or bad. You can find this switch part number by clicking the part number and model number search feature below. Enter the part number and press FIND IT. Let me know what you find with the door switch possible problem and if not the switch I will go to step 2, Thanks, Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Aug 05, 2009 | Whirlpool ED5FTGX Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
