General ins manual for starfone sft-2 cable box
Cable hookup to back of cable box
2 Suggested Answers
  • 280 Answers
SOURCE: Cable box hookup
The cable has a bad ground and you should contact the cable provider to get things right. The cable can carry AC voltage and if there is a isolation problem it could blow the TV if you try to hook it up.
Posted on Jul 03, 2008
Want to see dvd hookup for model#ln32b360c5dxza want to .Picturepicture of back of tv
See this link for the manual - looks like the hookup diagram is on page 6:
http://www.manualslib.com/products/Samsung-Ln32b360c5dxza-2824887.html
Feb 08, 2015 | Televison & Video
I hooked up the HDMI cable from the satilite to the satilite port and then the HDMI cable out to television. I have to have the samsung system on to get a picture. Is there another way to hookup so I don't...
if you have more then 1 hdmi on tv your box should have 2 u take and plug1 directly in to tv from box and keep it the same way and just change input on tv to hdmi 1 or 2 or 3 etc. most new tvs have 4 of them or let me know what box u have hope this helps ya
Jan 03, 2011 | Samsung HW-C560S Theater System
No sound when the tv is on
There's just not enough information to help yet.
Is the TV just by itself getting a signal off air?
Is it hooked up to a cable system where audio goes to a surround sound system or does a cable box just have a single cable that goes to the back of the TV?
Can you provide a bit more detail about exactly what the general hookups are?
Sep 13, 2009 | RCA Televison & Video
Toshiba 19LV505 combo/dvd tv that has absolutly the worst sound, the setting only goes up to 50 and you still have a hard time hearing the tv. Is it just poor speaker quality. I have cable hookup and hdmi...
Bob, you need to first raise the volume on the actual cable box itself. On each cable box there is a channel (up and down) as well as volume (up and down). Set the cable box volume to maximum, you can only do this manually at the cable box. This should work.
Dec 16, 2008 | Televison & Video
Connect the lg mobile to pc
HAI,TO CONNECT INTERNET THROUGH CABLE OR BLUTOOTH.
(i) 1.CABLE : INSTAL DRIVERS FOR THE CABLE AND LG PC SUITE,RESTART PC THEN CONNECT DATA CABLE BEDWEEN PC AND MOBILE.IT,S ORIGINAL CABLE DRIVERS ARE AUTOMATICALY INSTALED,ORDINARY CABLE MANUALLY INSTAL DRIVERS.
2.THEN FOLLOW TO CONNECT INTERNET:
   START>CONTROL PANNEL>SELECT NETWORK     CONNECTIONS>SELECT CREATE NEW CONNECTION>FINISH.RESTART PC AND THEN CONNECT INTERNET THROUGH NEW CREATED IN NETWORK CONNECTIONS.
(ii)VIA 1.BLUTOOTH:INSTAL BLUTOOTH SOAFTWARE(BLUE SOLI) AND RESTART PC.
2.ON BLUTOOTH ON MOBILE AND CONNECT MOBILE TO PC (BLUESOLI).SELECT DUN INTERNET CONNECTION TO INTERNET.
Jun 30, 2008 | Computers & Internet
Cable box hookup
Apr 30, 2008 | Insignia 37" LCD Flat-Panel HDTV
How to connect TVO to cable and tv
What is the model of your television? In general, you could connect a red, yellow, white cable from the OUT of the cable box to the IN of the Tivo, and then a 2nd red/yellow/white cable from from the OUT of the Tivo to the IN of the TV - but this will depend a lot on the type of television. This hookup that I have described will not give you high definition, if you have an HD cable ro sat box, but it will work.
Apr 16, 2008 | Televison & Video
Fax phone hookup
Use an identa call box. You set the distinctive ring pattern (1-2-3) and the box will route the call through depending on what number it is. I have two numbers on one line. I have a tee adapter on the phone plug with two phone cables coming out. Each phone cable one plugs into a small distinctive ring box. I set one box switch to 1, and the second box to 2. If the first phone# rings box 1 allows the signal through to the phone. If the fax line rings the phone won't ring, but the second box will pass connection to fax and vise versa.
I brought mine from Bell Canada phone store. It is called a identa-call box, or distinctive ring switch. Best way to go !
Mar 21, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
No picture no sound
Make sure you are selecting the correct input on your TV for your TV tuner, sat or cable box.
There are three ways to do this:
1. With the tuner or cable box turned on (you can do that manually or with its remote) use the TV's remote to cycle through all the inputs, until you find the correct one and take note of the name of the input that appears on screen, or
2. Look at the back of the TV and see where it is connected. It will say the name of the input, such as "HDMI1" or "AV2," etc. Then select that input on your TV with the cable or sat tuner turned on, if you have one.
Consult your TV's owner's manual, which will give more information on hookup and selection.
Hope this helps. :)
Nov 17, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
