Question about Gateway DX4870-UR20P DT.GDDAA.005 Desktop PC - Intel 2nd gen Core i5-2
How to open DVD on Gateway DX4870-UR20P computer
How to activate DVD drive on Gateway DX4870-UR20P Computer
coolfixya
  • 82 Answers
SOURCE: my computer house dvd tray will not open up.
Near to eject button you can find a tiny hole ..insert a paper clip into it ..then the tray will eject...
Posted on Feb 28, 2009
Craiglloyd
  • 33 Answers
SOURCE: dvd drive will not open on Gateway computer
Find the make and model of the drive (usually located on top on the physical drive) You may need to remove the drive from the casing. Google search for the firmware of the drive using the make and model. Update the firmware and it should work.
Posted on Apr 02, 2009
benwabnick
  • 2404 Answers
SOURCE: dvd-rom sd-616E driver no longer recognized by
Reboot the computer and go into the BIOS, see if its recognized in there, if its not recognized then you'll need to turn the computer off and unseat and reseat the cable and the power connector to the dvd drive. Then turn on the computer again and go into the BIOS, if the dvd drive is still not recognzied then you'll need to replace the drive.
If the dvd drive is recognized in the BIOS and not in windows then you'll need to go into the system restore in windows and choose a date the last time the computer was working, it will restore your computer back to this date and reboot. At that point it should recognize your dvd drive. If it doesn't then your OS is corrupt and you'll need to wipe out the drive and restore your computer back to factory defaults.
Posted on Feb 04, 2010
  • 341 Answers
SOURCE: I want to add memory
Take the case sides off and your DVD will either be locked in with a spring loaded slide mechanism or it will be screwed in from either side of it.
Posted on Feb 03, 2011
5781848
  • 416 Answers
SOURCE: (suggestions for video card upgrade on Gateway DX4870-UB318)
you can use any video card with this interfaces -
I/O Expansions Number of Total Expansion Slots4Number of PCI Express x1 Slots3Number of PCI Express x16 Slots
Posted on Nov 15, 2012
Testimonial: "ty so much Denys! i got a EVGA Nvidia Geforce gt610. still working out the kinks on it with SecondLife but all in all im happy the computer is running the way it should with video. now for my crappy internet connection! lol"
I have A gateway dx4870 ub308. when i turn it on it beeps 4 times and even tbought the on light stays . on it won't do anything else
The hard drive or some other critical component may be failing, or just the OS or hard drive corrupted. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. That way, at least you may not lose your files.
Then, you could try to do a Factory Restore on the computer, and if that works, copy your personal files back to your newly restored computer.
Jun 19, 2014 | Gateway DX4870 Desktop DX4870-UM20P
RESTORE GATEWAY DX4870-UR20P?
Use this video to help you with this process.
May 30, 2014 | Gateway DX4870-UR20P DT.GDDAA.005 Desktop...
Computer will not boot up
3 beeps points to ram problem, try removing the memory and putting it back, sometimes it'S just a bad contact... else, try new memory.
May 22, 2014 | Gateway DX4870 Desktop DX4870-UM20P
Why does my computer periodically reboot every few minutes? Confirmed - Not a fan/cooling issue Confirmed - Not a memory problem Confirmed - Not a virus
I would have said over heating but if you have tested for that I would still keep an eye on the fan to see if it is slowing down or switching of at the time it reboots.
Apr 29, 2014 | Gateway DX4870 Desktop DX4870-UM20P
How do I replace my broken DVD RW drive?
Removal of the case will give you access to the drive mounting area. As a general procedure, disconnect the cables, remove the attaching hardware and remove the drive. Be sure to save the removed hardware for installation of the replacement drive
Apr 18, 2014 | Gateway FX6860-UR20P PT.GCEP2.001 Desktop...
Loads to a black screen with cursor only
This is one of 2 possible problems.
1. Faulty Hard drive
2. Corrupt operating system
if it's number 2, reinstalling your operating system will do the trick, but be aware you will loose your documents and all data.
Best option is to bring it to a computer technician so they can run a diagnostic test.
also a technician will more than likely be able to recover your data aswell.
Mar 16, 2014 | Gateway DX4870-UR20P DT.GDDAA.005 Desktop...
I bought a new computer case and I want to use my mobo from my current pc. Gateway DX4870-ub318. I can't tell which pins to use for the power.
You will get better help at a computer repair shop than a component sales outlet. The same problem with two monitors suggests either bad cables or motherboard trouble.
Feb 26, 2014 | Computers & Internet
CPU and Power Supply Gateway DX4870-UB318
the power supply you must NOT upgrade. the only upgrade is the motherboard. You must call to the supplier computer Gateway, and get the support via ONLINE CHAT, for more explicit information help.
God bless you
Jul 04, 2013 | Gateway Computers & Internet
Gateway 838 GM-I cannnot open DVD and CD door
If there is a small hole on the panel of your dvd drive push a straightened paper clip inside until you feel it press down this will open up the drive. If your computer came with a motherboard disk the drivers could be on it Click start control panel administrative tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver You might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Hope this helps.
Dec 22, 2012 | Gateway Computers & Internet
Gateway DX4870-UR20P DT.GDDAA.005 Desktop PC - Intel 2nd gen Core i5-2 Logo
82 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
