Question about Intex 603 Krystal Clear Filter Pump 530 Gph 58603e
Intex pool pump power cord is not coming on - Intex 603 Krystal Clear Filter Pump 530 Gph 58603e
  • 297 Answers
SOURCE: pool pump intex 51 pumps water but return flow is low
if you cartridge is completly clean then start by disconecting the out tube that goes to the pump housing
sometimes debris gets caught there entering your pump.
a little hair causes other things to back up
once you are satisfird that those 2 things are ready then close it all up and open the bleeder cap on top of the cartridge holder
Now let water in from the suction side
when water starts coming out of the bleeder cap then open the return side
Now turn on the puimp
let it run for 20 seconds and then close your bleeder
Should be working fine after that.
dont forget to leave the bleeder cap alone on the bottom of the canister unless you are draining the water from the canister to clean it. As soon as you are done close it back up
Posted on Jul 15, 2009
  • 71 Answers
SOURCE: Intex pump 635 is a P.O.S.! How do I hook up a different pump?
I just left the standard intex connection on the pool and I cut the standard connection off of the filter side and I slid the hose over the top of a 1 1/2 pipe and put 2 stainless steel hose clamps over them and it worked fine
Posted on Jul 23, 2009
SOURCE: need instruction manual to set up my pump for intex easy set up
The correct website is intexstore.com
on the right side, about half way down the page there is a blue box that says instructional set up video and manuals. You then click on pumps and on your model, and you can open it there.
Posted on Aug 24, 2009
tinkerbill
  • 12 Answers
SOURCE: Need Intex Pump model #635 impeller
You know, I have made some amazing repairs on plastic items using nothing more than a soldiering iron! If you have the piece that broke off, you can carefully melt it back together. You can add more to the weld if you match the type of plastic but not too much or you imbalance it. In this case it looks like PVC. To repair it without the missing piece, form it out of epoxy putty, roughly shape it just before it sets up solid, & sand to finish.
Posted on Jan 02, 2010
Coastsider
  • 331 Answers
SOURCE: Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
Posted on Apr 14, 2010
How to take apart Intex 603 pump housing
You need to try 'security' bits. They come in sets with various sizes of star bits and hex bits.
Aug 18, 2014 | Intex 603 Krystal Clear Filter Pump 530...
Why won't the breaker on the power cord of my intex krystal clear saltwater system reset?
Defective breaker or shorting pump. Disconnect the appliance from the cord. Does it reset? yes means your appliance is bad. No means that the breaker is bad. A cord with a breaker is not the way to safely operate the pump. You should use a ground fault protected outlet or a cord with a GFCI built in. Either way if the safety device continues to trip, you have a problem with appliance.
Aug 03, 2014 | Intex Krystal Clear Saltwater System Pool...
Have an intex 16 x48" salt water pool generator
I checked the Intex web site and here is what they said:
There are several things you may need to check and do:
- Test the salt level first with Test Kit, and add salt as needed.
- Remove the electrolytic cell for inspection and clean it if necessary.
- If code 91 still appears despite the above steps, there might be a possible electrolytic cell
failure. Please contact Intex Service Center, and replace the cell if needed.
NOTE: Always turn the power off and disconnect power cord before cleaning and servicing.
I hope this helps.
Aug 24, 2011 | Intex Automatic Salt Water System for ...
Pool pump shutting off/tripping the circuit breaker
What kind of pump are you using?
Sounds like the Intex is restricting water flow there by heating up your pump and shutting it down..
You may need to re plumb everything to handle the flow.
Intex hoses and fittings are different than the industry standards just so the can make you buy from them
Do what ever it takes to get good flow
Jul 01, 2010 | Intex Automatic Salt Water System for ...
Power cord has been cut
Yes you can replace the entire cord, or you can splice the cord back together. Get some crimp on wire connectors get a tube of heat shrink that will fit over the cord, cut back the insulation crimp, the wires back together (match color to color). heat the shrink or tape it up. Back in business.
Jul 04, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Intex 603 Krystal Clear Filter Pump 530 Gph 58603e Logo
66 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
