Question about GE Dryers
Ge spacemaker dryer DDP1400SABWH - GE Dryers
2 Suggested Answers
  • 21 Answers
SOURCE: GE Spacemaker Electic Dryer Poor Drying
Hello
Make sure you have a 30amp two pole breaker. Also, it could be a heater problem.
John
Posted on Jan 07, 2010
GE spacemaker Washer Dryer Combo don't drain properly?
Check the drain hose for obstructions. Is it being pinched where it goes over the top of the drain pipe behind the washer?
The pump may be going bad...
Jul 29, 2014 | GE WSM2700W Unitized Spacemaker Washer and...
Ge spacemaker laundry dryer does not heat
All dryers have states to control heat GE has a safty stat that is comon problem small round stat at top after removing lid check with ohms meter with wire unpluged if no continuity changed then check venting of dryer inside and out improper venting will cause dryer to over heat
heat element is the next go to same check but must take dryer apart more send model Number we can give you a diagram and location of everthing you will need
Jan 30, 2013 | GE Spacemaker Washer and Dryer Electric...
The dryer timer stopped working
Is that a temperature senor in the GE spacemaker Laundry dryer? My dryer stops spinning when it gets too hot. After it cools down, it will spin and dry again.
Jan 05, 2013 | GE WSM2700W Unitized Spacemaker Washer and...
Remove front panel ge spacemaker dryer
Here's the trick: The Spacemaker dryer is the same as many other GE dryers but is upside down!
1. Unplug the dryer.
2. Flip the dryer upside down so the white panel is now on top and the unfinished steel panel is on the bottom.
3. Remove the 2 screws that connect the bottom, white panel from the back and lift up to remove.
4. Pull off the Settings and Fabric knobs on the front of the dryer. Take off the front control panel (remove the 2 screws).
5. Remove the 2 screws that attach the front panel (located behind the control panel you just removed). Hold the dryer drum by the top edge and pull the front panel away (note that the panel will be hooked to the rest of the dryer at the bottom corners). DO NOT PULL AWAY ENTIRELY!
6. Disconnect the wiring that is attached to the front panel (these come apart easily by hand but you might want to mark the wiring so you know where to connect it when reassembling).
Apr 05, 2012 | GE Spacemaker DSKS433EB Electric Dryer
Hello
John
Nov 24, 2009 | GE Profile DPXH46EAWW Gas Dryer
GE spacemaker dryer won't start
Have you tried keepin the dryer door open, depressing the safety switch which enables the dryer to work when it is closed, and then turn on the dryer to see if it turns at all? Sometimes its the smallest things that cause these problems. That switch that gets pressed when the door closes, sometimes malfunctions. Sometimes the door of the dryer gets out of whack and doesnt really make contact with the switch enough to trigger the flow of electricity.
Jan 01, 2009 | GE Spacemaker Washer and Dryer Electric...
GE Spacemaker dryer scraping metalic sound when on
i know you say ge dryer but i think thats a frigadire inside ge dosent make an over under.When dryer off take your hand and go around the in side of the tub where it meets the felt seal.some times somthimes somthing will get caught between the turning drum and the felt seal causing a noise.if not that you have some wear problems and will have to take apart to inspect
Dec 31, 2008 | GE Spacemaker Washer and Dryer Electric...
GE Unitized Spacemaker
WSM2480D0WW is a gas dryer there is no heater coil... but it has a burner and igniter...if you have a electric dryer it is at the end of the blower
Jun 12, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Dryers Logo
48 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
