Question about Xerox 4500 Laser Printer
Color laser printers. Costs for toner vs. initial costs for ptr
We publish a very small color boutique "magazine" on a quarterly basis (about 150 copies). We initially printed to a postscript HP inkjet printer (it was about $1000 when we purchased 10 years ago) and the cost for ink cartridges was relatively (read on) reasonable. We might spend $300-$400 for cartridges and ink heads for each issue. But it might take two weeks to print all the copies...the double sided part was a real delay and hassle.
A couple of years ago we purchased HP color laserjet printer (2605dn) which made a huge difference in printing time and hassle. It wasn't very expensive ($300ish). It prints double-sided pages and is so much faster. We are pleased with print quality (the publication includes lots of photos and colors). But we spend about $1200-$1500 each issue on toner cartridges. This just doesn't make financial sense anymore.
My thoughts are that we should invest in a more expensive higher end color laser jet printer that will hopefully not be so expensive on the toner side. (The cost of the printer can be amortized over the years. The expense and red ink each year cannot.)
Years ago this was the general rule of thumb: the cheaper the printer, the higher the recurring printing costs (toner/ink cartridges). Is this still the case? Can anyone suggest an HP color laser jet with duplex capabilities (and postscript), maybe that supports larger paper size too? Or even the first two items?
The costs currently for toner are still considerably cheaper than having this printed at a printer. But economically we're losing money and we have raised prices as much as we can in the disastrous marketplace that the world is today.
I would appreciate any information or suggestions that address the questions above.
  • 81 Answers
Have you thought about having your printer cartridges refilled? There are huge savings to be made in doing so and the quality can be just as good as the original cartridges (depending upon the refiller). Another option would be for you to purchase an older color laser printer such as the HP Color Laserjet 4500 or 4550. I use one myself and couldnt be happier with it. And as its an older printer, you can get the cartridges relatively cheap.
Posted on Jan 24, 2009
The wast toner bin on the clx.3175 needs to be replace how do i remove the bin out the printer
Open door where toner cartridges are. On left side of cartridges below the Colour Letters is a small black handle. Just pull the handle and the bin comes out. You can't simply empty the bin and re-use, you need to order a new one from Samsung. Only costs $25 and just push in. Very easy, just need to wait for part to be ordered in and then collect it, which took me a week.
May 16, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Tip
How to Differentiate Between Laser Printers & Inkjet Printers
You require a new printer but you do not know whether to buy an inkjet or a laser printer, as you are not aware of the differences between the two. Each user or organisation is faced with the dilemma while buying a new printer. Most customers operate under strict budgetary constraints and it is only normal to consider initial purchase costs and space limitations. However, it is prudent to take into consideration the long-term operating costs associated with the particular printer.<br /> The choice of printer will, largely, depend on your requirements. Inkjet printers are usually ideal for home users who have limited text and photo printing needs. Laser printers are better suited to larger office environments with high-volume and high-quality printing requirements.<br /> The differences between a laser and an inkjet printer are generally categorised into a few broad segments, namely, cost (initial and maintenance), speed, quality, space and networking facilities. It is also essential to understand the technology behind the manufacturing of the laser toners and ink cartridges as this is a major contributing factor towards the cost.<br /> <b>Difference in Technology & Networking Facilities between Inkjet and Laser Printers</b> -<br /> The technology used for inkjet cartridges is simpler and the parts are less expensive than the laser toners. The black inkjet cartridge has only black ink. The color inkjet printer contains two main ink cartridges, for black and other primary colors respectively. The primary colors are then divided into three compartments for cyan, magenta and yellow ink. The primary colors are consequently mixed to produce all other colors. The cartridge contains a reservoir which has compartments with metal plates and a number of tiny nozzles on the print head of the cartridge. The number of holes or nozzles depends on the resolution of the printer. It is usually 21 - 128 nozzles per color. The ink gets heated, when the current starts flowing through the metal plates, after the print command is given. The heat causes vapor bubbles to form inside the cartridge and make the ink swell up. The ink then flows out in droplets from the nozzles onto the paper in a few milliseconds. A vacuum is created (once the ink droplet flows out) which draws more ink into the nozzles ensuring a steady supply of droplets as required. This common technique is called Thermal Inkjet and the coinage of the name 'BubbleJets' by Canon has been due to the bubbling vapors.<br /> The Laser toners use a more elaborate and complex technology. A powder called Toner is used by laser printers, fax machines and photocopiers to print text and images on laser and photo paper. Initially carbon powder was used but now manufacturers use disposable cartridges which can sometimes be refilled. For the laser toners, individual carbon particles are mixed in a polymer which melt in heat. This binds to the fibers in the paper. The laser printers consist of the printer toner and the drum. The positively charged toner gets attracted to the negatively charged drum. The toner is transferred to the paper by the drum. The toner contains special wax that melts and dries in milliseconds. When the toner is transferred, the fuser applies heat and pressure to make a durable image. The fuser system is made up of the hot-roll and the back-up roller.<br /> The high-end laser printers generally come with networking facilities for you to connect to your computer network directly. This cuts down additional costs associated with networking, as is the case with ink printers. The ink printers cannot be linked to a network directly. Networking has to be via a computer, therefore more expensive.<br /> The laser printers are larger in size than the inkjet printers. The latter is, therefore, space saving and ideal for the home and small office users.<br /> <b>Difference of Quality & Color between Laser and Inkjet Printers</b> -<br /> Since Inkjet Printers spill out tiny droplets of ink to print, the resolution is lower than the laser printers. Laser Printers printer better quality text, as their resolution is higher. High resolution also helps the laser printers create precise fonts without fuzzy edges. However, the cost-effective inkjet printers are usually recommended for inexpensive color printing. These can print high quality text, large photo prints, graphics, banners and greeting cards at less than half the price of a color laser printer. Nevertheless, it should also be seen if the cost of ink and paper suits your maintenance budget. Laser printers are capable of producing good quality prints on all kinds of printing paper but the inkjet printers will require inkjet paper to produce good quality prints without any fuzzy edge brought about by 'bleeding'.<br /> <b>Difference in Speed between Ink and Laser Printers</b> -<br /> If laser printers lose out to their inkjet counterparts on account of price, they are way ahead when it comes to speed of printing. Users who need large volumes of printing also prefer the laser printers. Laser printers are more suited to general office use than the inkjets. The least expensive laser printer can print around 10 to 15 pages per minute. The inkjets are usually rated on the speed of draft or quick printing mode, which is suitable only for proofreading purposes. The HP Deskjet 5650, which is a fast color inkjet printer, prints at a speed of 21 ppm Black, 15 ppm Color in the draft mode. However, the speed drops considerably when high quality black text is printed and it also takes longer to print a letter-sized quality photo.
on Nov 10, 2010 | Office Equipment & Supplies
I need price list of cartridge (Color / Black) of hp deskjet F 380 All in One
If you search it out online, you will find about 50 different prices. Pick a reputable supplier and check shipping costs before you buy.
May 07, 2011 | HP LaserJet 1020 Printer
Cyan and Magenta does not print on the right side of the paper. Toner indicator shows three quarter of the cartridge to be full. Yellow and black prints are perfect.
I have worked/ serviced similar Laserjet Color Printer with same issue.
Actually, prints with faded colors or different colors are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. For instance, red color is formed by a mix of yellow and magenta toners. The color is replaced by yellow due the the partial or complete blocking of the image laser beam for
magenta as the mirrors which reflect laser beam get covered with dust and toner (which partially blocks the laser beams). Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer. Note that first magenta goes off, followed by yellow, then cyan and lastly black. This is due to the mirrors placement inside the printer. Magenta is the last one facing upwards at 45 degrees angle and gets most of the dust and goes off first.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Mar 31, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Faded streaks for only blak color on Ricoh 3500N laser printer
Your toner cartridge is probably getting low. Toner is actually a powder, and it can get settled during shipments, bringing it home, etc etc. Take out the black toner and give it a gentle side-to-side shake a few times and pop it back in.
That should help.
Apr 28, 2010 | Ricoh Aficio CL3500N Laser Printer
Hp cm1312 all in one color laser. color is grayed
After a frustrating support call from HP where they wanted me to send the printer into a service centre for a ridiculous cost, I tried troubleshooting myself and seemed to fix this error 51.23.
The solution was to put the printer in cleaning mode:
Setup - Service - Cleaning mode
Hope this helps other people....
Jul 12, 2009 | HP Laserjet CM 1312NFI Color Printer
Cartage is become too costly to my work load, please suggest me , i want to refill and use the canon 1800. i have no complaint with the machine my id shankar_k999@yahoo.com
You should purchase a small B&W laser printer (HP recommended), they are under $100 these days, and use you Pixma for colour, only when you need it -Inkjets are brutally expensive to operate. I assume that you don't need colour for the majority of printing, and a laser will reduce cost per page by about 20 times -for example, about 2000 pages per cartridge vs. 100-200. Refilling inkjets is a messy and unreliable procedure; however you will be able to source remanufactured toner for your laser to further reduce printing costs.
Mar 11, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer won't print black
Gently roll or shake your black toner cart.
when you do not use the printer on a daily/weekly basis, the toner dust compacts in the bottom of the holding area of the toner cart, and can sometimes cause these problems.
Jul 29, 2008 | HP LaserJet 4200 Printer
Minolta PagePro 1250 poor print quality
It is not cost effective to spend any money repairing an entry level laser printer. Replacing the toner cart or drum is insanity. New B&W lasers equivalent in performance to the 1250w are available on sale for ~ $50. You can get the Samsung ML 2010 for $59 every week on sale. Also the excellent Brother laser. For that matter you can get the a Samsung color laser (CLP-300) for $79 on sale with a $150 rebate.. . Due yourself a favor and get a new printer instead.
The Minolta is a great printer but I bought mine for $50 at Office Max, where they will gladly sell you the drum for $79! Huh?
Jun 26, 2008 | Minolta Color PagePro PS Plus Laser...
Problem printing in color on Xerox Phaser 8200 from Mac
That actually should make magazine quality color.
What are you experiencing? Do the colors not match? Are there smears or light streaks?
I will gladly work with you to revolve your problem, I just need a frame of reference to start.
Let me know.
You may simply need to download and install a different driver.
They are on www.xerox.com you should be running the PS version of a driver for better graphics.
Apr 02, 2008 | Xerox Phaser 8200 Laser Printer
Xerox 4500 Laser Printer Logo
136 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
