Question about Drive Medical Health & Beauty
Reduction of runtime between battery charges.
Runtime has dropped from 3-4hrs to 1-2 hrs. Battery pack was replaced with 2 - 12V, 12AH sealed batteries. This did not help. I made some measurements with the scooter running on a flat surface with a 175# load (me) at full foward speed: 5 - 6 amps @24.0Vdc. Motor plate info is; 24Vdc, 3.0Amax, 270W. Contacting Drive tech line was of no help when I asked if these measurements are normal. Neither was the local service shop. I am thinking the motor is drawing too much power. Anyone have an opinion?
Thanks in advance
Tony
  • 2 more comments
  • acpapp Jan 26, 2009
    Thank you for your response. The no load measurements are; 2.5A at 24.6V, battery voltage at idle was 25.8V so about a 1V drop during no load operation. Same voltage drop when checked with a 175# load. I also retested the scooter with the electric brake by-passed and obtained the same results. FYI; All measurements made at the battery pack.
    I also had the batteries load tested and they checked OK. He did comment, however, that with a 6 amp draw, he would expect the 12 AH batteries would need recharging after about 1.5 hours of operation.
    I checked the drive train for foreign matter and for unusual resistance or noise. All seems well.
    Any additional help would be most appreciated.
    Regards, Tony
  • acpapp Mar 12, 2009
    Thanks for your reply,
    Checked all the contacts, cleaned as needed(not much evidence of corrosion), and applied dielectric grease upon reassembly. Also, ensured battery clips and contacts are clean and tight. No change in performance.
    I'm astonished that I cannot get an answer from many other sources, including the manufactures technical dept., as to the normal current draw for this unit! I guess we truely have become a replace and see society. I refuse to join, however!!
    Anyother suggestions would be most appreciated.
    Regards, Tony
  • idare_ya May 11, 2010
    would it be possible for you to test the no load draw? Is threre alot of resistance in the drive train? inspect the drive train possible somthing caught or causing excessive resistance.
  • ruddski May 11, 2010
    If the scooter is a Drive take apart scooter there are contacts that go from the rear the the front section that get dirty as they are open to air and can get dirty, split the scooter in half and check the contacts and clean them.(bad design) Also check to make sure that the clips on the batteries are tight and all the contacts back towards the rear section.
    Problem Solver:
  • 7 Answers
The only other things I can think of is a bad motor brush, or a bad gear not turning freely in the gear box. I am not as familiar with the drive scooter, but it should have two caps on the motor that have brushes in them. The brush is held in by the cap, unscrew it and take brush out ( it is spring loaded) and check contacts. If it is worn down too much or unevenly worn it needs to be replaced, also if the spring is not set right or the brush is stuck it will cause drag, Put the brushes back in the same way you took them out if they are good, if you need to replace you need to wear them in by putting rear wheels of scooter up on something and run scooter by putting a rubber band on throttle. If it's the gear box it needs to be replaced
Posted on Mar 13, 2009
I have a aowa electric bike 48v 500w. the batteries are split into 4 12v 12ah. can i use a lower, lets say 12v 10ah battery or lets say 4 12v 9ah batteries?
yes, the ah has to do with the capacity of the batteries, so the lower the ah the shorter the runtime, and if you have 3 10ah and 1 6ah the capacity of the 10ah batteries will be downgraded to 6ah
Sep 26, 2014 | Peg Perego 12 Volt Rechargeable Battery
I've a ZEPHYR 700 RC, I've replaced the original batteries with 70 AH battery to be able to load my LED TV, Laptop and a light source since we have -in Gaza nowadays- a 12 hrs of no electricity and on
Is it runtime that you are having a problem maintaining? If you are looking for 12 hours on battery you will need a bigger UPS - or one that you can add more battery compartments to... Your current UPS just won't do it... and be careful about connecting multiple batteries to 1 UPS - you may just blow the invertor in the UPS.
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Nov 20, 2013 | Computers & Internet
2 batteries together labeled rt 1250
Not sure what the problem is, but most likely, it's two RT1250 batteries in parallel, with the label on one covered by the other battery.
An RT1250 is only 4.5AH, which would be a pretty short runtime. 9AH (two batteries paralleled together) would roughly double the runtime. That would be about 10 to 15 minutes for a 350VA UPS.
Specs and (USD) pricing are available here:
http://www.batteryuniverse.com/Sealed-Lead-Acid/Ritar/RT1250/GZ1250_Ritar_RT1250_Sealed_Lead_Acid_Battery
Aug 31, 2010 | Computers & Internet
New battery
A lower capacity battery (12v 8Ah) can/should preferrably be replaced by a better capacity (12v 12Ah), and usually more expensive, quality battery of the same voltage with higher amperage rating: it will in general take longer to charge but will also last longer in usage.
Please make sure that you fully charge and discharge your new battery pack a few times to 'condition' it.
Hope it helps and have fun!
Aug 01, 2010 | Peg Perego 12 Volt Rechargeable Battery
Microsoft Visual C++Runtime Library
hello there
please follow this link for a explanation and a fix for this ok
  1. "Microsoft Visual C++ Runtime Library Runtime Error" error message ... Describes the error messages that you receive after you install Office XP or an ... "Microsoft Visual C++ Runtime Library Runtime Error" error message after you ...support.microsoft.com/kb/307817
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
Battery on mp3 player dies alot
You have to charge the battery
Sep 01, 2009 | Audio Players & Recorders
Insufficient runtime available on agent
Try to do a runtime calibration using your powerchute software or SNMP agent. Check what is the runtime there, or check the runtime setting of your Powerchute software, maybe it set to more than the actual runtime of the UPS.
Jun 05, 2009 | APC Smart-UPS 1500VA Shipboard...
To increase backup in apc symmentra ups
old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Feb 04, 2009 | APC Symmetra Tune-UPS technical support -...
Health & Beauty Logo
192 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
