Question about Dryers
Drum wont turn
I have Kenmore 70 Series dryer. When you push the start button, it buzzes but will not turn on. The drum is not turning automatically but you can manually turn it counterclockwise. You cannot manually turn it forward or clockwise. What can be wrong? Is it something that we can fix ourselves?
  • Anonymous Mar 04, 2009
    The heat works, so the motor is ok. The drum turns manually. I assume it's the belt.
  • Anonymous Mar 08, 2009
    We hear motor sound for a few minutes, then drum doesn't turn -
    Problem Solver:
  • 4 Answers
Is your motor working? How about your belt? Is it broken?
Posted on Jan 24, 2009
My Kenmore 70 Series Extra Capacity dryer wont start
there is several problems it could be the bearings in drum could be bad or there could be a sock or other item locking up drum from turning.
Nov 06, 2013 | Dryers
Kenmore dryer 70 series drum not turning
http://www.youtube.com/watch?feature=player_embedded&v=bJ5TNlzHKhA
Jun 06, 2012 | Kenmore Dryers
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Oct 02, 2011 | Kenmore 63942 Dryer
The drum on my kenmore 70 series dryer won't turn and the dryer won't get heat up either. The drum will start to turn if we take the lid off and manually push it but not automatically
The dryer will not heat till the motor starts . If the dryer makes a hum when you activate the start switch' but won't start, then either the motor switch is bad or full of lint. If there is no hum then the start switch may be bad.
Nov 22, 2010 | Kenmore 63942 Dryer
Dryer doesn't always start, and doesn't keep running
your have a dieing dryer motor,weak weak to turn the drum anymore,the model number is inside the dryer door if you want to try and find one cheap on ebay-mike
Feb 23, 2010 | Kenmore Dryers
Dryer won't start
The start windings in your motor have gone out. To fix this you must replace the motor.
Justin Duby
T and N appliance Repair
Dec 08, 2008 | Kenmore 63942 Dryer
Dryers Logo
462 people viewed this question
Top Dryers Experts
