Hi any chance you could send me a wiring diagram for a carrier ducted air conditioner model number 38QRT060. its a very old air conditioner and the diagram on the unit has faded.it looks like the honeywell controller is faulty and i was hoping i could bypass it to get it running.i work for an airconditioning company as an electrician in muswellbrook nsw aust.thank you
kstfas
  • 75 Answers
SOURCE: Air Conditioner malfunction
Hi, Sounds like you have a short in the control circuit to me. Turn off all power going to the unit. Write down or otherwise mark the wires leaving the control board going to the thermostat. Remove them from the control board. Replace the fuse. Turn power back on and see if the fan still runs. If it does, check and or replace the heat limit switch that brings the fan on during the heat cycle. It may just need adjusted. If the fuse blows, I would think that the control board is probably bad. If it doesn't blow, Remove the thermostat. Leaving all thermostat wires open check them with an Ohm meter. There should be no continuity between them. Twist all the wires together at one end and ohm them again at the other end. You should have complete continuity on all wires. If the wiring checks out, down power the unit. Double check your wire colors and rewire the control board. With all wires open at the thermostat, turn the power back on. Touch the RED wire to the YELLOW wire. The Condensing unit should come on. Touch the RED wire to the GREEN wire. The fan should come on. Touch the RED wire to the WHITE wire. The heat should come on. Down power the unit. Replace the thermostat. Test unit. If the fuse has lasted ok but blows now it is either wired wrong at the Thermostat or the thermostat is bad. I hope I have helped. NOTE: If you can not understand these instructions. Call a licensed Heating / Air conditioning company. kstfas
Posted on Sep 23, 2007
motor1258
  • 6674 Answers
SOURCE: Coleman Mach III 13,500 btu ducted roof air conditioner
Did you plug upper unit (on roof) into lower control unit (inside). Not to insult you, because i've done it myself, in a rush situation. Breaker on? Sure you didn't mix up any wiring?
Posted on Aug 16, 2008
pierre1811
  • 144 Answers
SOURCE: replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Posted on Jan 21, 2009
  • 189 Answers
SOURCE: air conditioner replacement--new size required?
567C024RCU In this model number is the # 24. That stands for 24,000 btu's. This is a two (2) ton unit. Has this two ton unit cooled ok in the past? if so replace with the same size. But make sure yo change the indoor coil to match the size "and" efficiancy of the ew unit.
Posted on Apr 14, 2009
SOURCE: wiring diagram for portable air conditioner
I think the wiring diagram is on a printed sticker on the side of the water collector, just pull it out of the right side as you look at it. There should be one on there hope this helps as i have the same unit in the other room. regards Richard
Posted on May 29, 2009
I have a condensor Carrier model 38ck030300. It is old and I cannot read how many tons it is. I probably need to replace it with new. Do you know how many t it is? Which units will be...
The unit is 2.5 ton system. many units can replace the existing, you can upgrade to a 3ton if you wish without problems or upgraded ducting if enough ducting exist.
Brands that will almost fit as is are Payne, Day and Night, Rheem, Ruud.
Jul 26, 2011 | Carrier 38CKC036 Air Conditioner
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
What is e4 code of duct split carrier a/c ?
Need model. Number or name. E4 is several different codes for carrier. Likely a temp sensor from what I'm seeing.
Jul 13, 2011 | Carrier 38CKC042 Air Conditioner
I need a wiring diagram for an old westinghouse starter model number 3462d31. It is for a 750 ton chiller model number cv76-11088
E-mail me @ Bobicehouse58@yahoo.com and I will send you what I have.
Make and Model of Chiller will be helpful.
May 05, 2011 | Heating & Cooling
Does not ignite error code flashes 6 times
Look on the reverse side of the removable front panel of the Carrier. Each model will have a wiring diagram and a diagnostic chart to help you pin point the issue. Without knowing the model number the error code means something different for each model.
Nov 20, 2010 | Carrier Heating & Cooling
Wiring diagram needed for carrier air con unit
Here ya go:
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/38ckc-c2w.pdf
May 27, 2010 | Carrier 38CKC036 Air Conditioner
KINDLY SEND WIRING DIAGRAM OF DIAKIN PACKAGED ROOF TOP AIR CONDITIONER MODEL UAT08KAY-1
Hi; Call California number 1-310-769-0105 This is from what I can find to be correct.Also make sure You have the exact model and serial numbers. You can find the wiring diagram usually on the inside cover of the electric compartment covers...alpharome416
Feb 10, 2010 | Dometic Rooftop RV Air Conditioner
I have a carrier 15,000 rv air conditioner with remote control, can I change the bottom unit & hook it up to a wall mount thermostat? My old a/c was hooked to the thermostat so it is wired for the...
Call 1-866-464-2478, Mon-Fri, 8am-5pm.
I see no reason why not, once you have lower unit (control box) and wiring diagram. When you call that number, have your current model number ready of upper unit, and I'd ask for technical assistance. Good Luck.
Sep 16, 2009 | Heating & Cooling
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
