Question about Garden
Briggs stratton 2700 psi 2.3 gpm pump 311553gs
My pump is brokem, iI to changed it
5 Suggested Answers
SOURCE: Looking for manual for a briggs and stratton 2700
Gas pours out when I turn the dial from off to gas
Posted on Oct 07, 2010
SOURCE: I do like to know if this washer is good enough
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Posted on Oct 20, 2010
  • 36 Answers
SOURCE: started by Craftsman 2700 PSI
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
Posted on May 09, 2011
eugbug
  • 479 Answers
SOURCE: hi there, i need to
See this link on how to change oil and recommended oil types:
http://www.briggsandstratton.com/engines/support/maintenance-how-to/Push%20Mower%20Engines/How%20to%20Change%20Oil/
Posted on May 10, 2011
Is the craftsman gas powered 2700 psi pressure washer to strong to wash cars and trucks?
yes -- it will remove any loose paint then keep going to take all the paint off
if used around the mechanical bits ,it has the pressure to blow in gaskets and force water into places that water would not normally get to
Oct 19, 2015 | Craftsman 2700 PSI,2.3 GPM Briggs &...
I HAVE AVANGUARD 9HP PRESSURE WASHER NEED TO KNOW PSI @GPM OF THIS
most rarely exceed 2600 psi as these can blow right through your hand..gpm maybe 40-45..there should be a plate with all that on the unit..
Jul 10, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
Cant find choke on craftsman 2700 2.3 ready start 7.75
If I remember correctly, there is not an operator actuated choke on that unit. It is thermostatically controlled be a device behind the muffler.
Aug 25, 2013 | Craftsman 2700 PSI,2.3 GPM Briggs &...
What of oil to change on the 2700 PSI Brigg & Stratton enigine? On a "Generac pressure washer" and also what type of oil and how to change the oil on the pressure washer pump.
id your engine model and consult the briggs site........
the oil in the pump is filled during assembly so it doesn't have a nice pair of fill and drain plugs
briggs :
http://www.briggsandstratton.com/eu/en/
Jun 25, 2013 | Garden
I've got this white powder stuff in my fuel filter
its from using old fuel only use fresh gas 30days or newer
Aug 03, 2012 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
Garden Logo
345 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
