Question about Toshiba (225EXTR5)
Keyboard detection problem
I had an overheating problem with a laptop (model A85-S107) and I dissambly the laptop and clean the heatsink. When a want to connect the keyboard again a part of the port where the keyboard is connected was broken....a conect the keyboard but its doesnt work........I resolve the issue of overheating but I have another......the keyboard doesn't work...........I have to buy another motherboard or I can change the port of the keyboard??.........The keyboard it's working because I tested in another laptop and it's working..........for me the problem looks the keyboard doesn't make pressure ........help me please...... My operating system detect the keyboard but I can't write anything
    New Friend:
I have sony vieo core i7 labtop, and ihave problem in keybord and mous in my computer, the problem is dosint working in any windows but is working in DOS, and if i use usb external keybord is work.
Posted on Apr 23, 2011
    Scholar:
  • 59 Answers
If the kb works on another system then the ribbion is ok, right?, the port on the motherboard is broken, which is almost certainly integrated(soldered to the board with no wires in between) which means to replace just the port you need to get a desoldering tool and cloth and a soldering iron(do not use a gun, they are not as acurate when working with this small of a space) and of course some solder, not to mention the replacement part or a more seriously broken laptop with the same part that you can take apart, seems like a lot of work to resurect a laptop, i would suggest a new board, new laptop or get a usb kb, maybe one of those rollup ones they sell on thinkgeek.com so you can retain some of the protablity, then again since the onboard kb is not functional it just sorta becomes deskspace for an external one. the fastest cheapest fix would be an external keyboard, next time i would recomend knowing what you are doing a little better before working on a valueable system or any that you cannot afford to loose, I see people break the ribbion cables and connectors all the time when working on laptops, its usualy because they dont know how to open the clips on the connectors, anyways try to be more careful next time
Posted on Jul 10, 2007
SOURCE:
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
Bios does not detect cd rom drives, the cd rom drives has power but it does not work cause bios its not detecting it and it a new drive, my toshiba satellite is a85-s107 let me know if u can fix it.
I have a Toshiba Satellite L355D that would not detect the CD Rom in the BIOS although the Rom appeared to powered up and running. I traced the problem to a ribbon cable connector that was between the jack the CD Rom plugged into and the jack on the mother board. The ribbon cable plug at the MB had backed out and was only making the power connections to the Rom making the Rom appear to be operating.
Dec 05, 2010 | Toshiba Satellite A85-S107 Notebook
I need to know what type of harddrive my toshiuba satellite A85-S107 uses is it sata or pata ??
The type of hard drive that is compatible with that model laptop is IDE/PATA not SATA.
Regards.
Apr 12, 2010 | Toshiba Satellite A85-S107 Notebook
My computer fan is making noise and needs to be replaced
Follow this through, it may be over kill but at least it has pictures for you so you know what to expect getting into the fan
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A85/replace-laptop-memory-2.htm
Feb 11, 2010 | Toshiba Satellite A85-S107 Notebook
Toshiba Laptop black screen
chek in bios setup your hard disk is detect or not.
when u power up the laptop press F2 or DEL or F5 or F12 then u see bios menu.then if your hard disk not detect disable sata.if u detect your hard disk set harddisk as first boot device then save settings.
but if u see first windows then blank scrrreen u need to do nothing.just do following.
when u power up the laptop press F8 key then u get safe mode and etc menu.
go to enable vga mode thwen u enter in windows xp set your display resolution to 800*600 or 1024*768
thats all.
Nov 10, 2008 | Toshiba Satellite A85-S107 Notebook
Keyboard replacement
Hello this is for uprading the memory , But does show how to remove the keyboard
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A85/replace-laptop-memory-1.htm
Good Luck .Joe
Oct 07, 2008 | Toshiba Satellite A85-S107 Notebook
Satellite a85-s107
do you have restore disc that came with laptop if you use this to reformat coputer yes it should help
Jan 15, 2008 | Toshiba Satellite A85-S107 Notebook
Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Sep 21, 2007 | Toshiba Satellite A85-S107 Notebook
LCD not working
Sounds like a motherboard fault/short, especially if youv'e got on board graphics and if there are smells coming from fan.
Sep 01, 2006 | Toshiba Satellite A85-S107 Notebook
Computers & Internet Logo
249 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
