Question about Stihl Concrete Cutoff Saw Ts460 Oil Seal Ts 460
Stihl ts 460 fuel line andoil line routing
Fuel line routing
2 Suggested Answers
SOURCE: hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Posted on Aug 03, 2010
Stihl TS 760 NOT GETTING FUEL TO CARB OR PLUG BUT HAS GREAT SPARK HAS SIT FOR A WILE POSSIBLY OUTSIDE IN ELEMENTS ANY SUGGESTIONS
What's the compression like.? The carb requires the vacuum of the falling piston to draw fuel through the venturi of the carb.
Check the fuel lines are not perished or split, and fuel filter is clean..
If all of those are good then check the carb, strip it and clean it, replace any fatigued diaphragms, make sure the needle isn't stuck in the sleeve.
Jun 02, 2016 | Stihl Garden
How do I disassemble bar oiler and tank on unidentified chainsaw?
Stihl 017& 018 repair to bar oiling system, showing oil pump ...
? 12:36
www.youtube.com/watch?v=lJFAmUz49DQ
Jan 1, 2014 - Uploaded by Andy Reynolds A common fault with the Stihl 017 and 018 is low or no oil getting ... 018 repair to bar oiling system, showing oil pump feed andoil tank removal.
Sep 30, 2015 | Garden
Wont start-is getting fire&carb is rebuilt flywheel pinis ok
Check you fuel line configuration. More than one time they've come in with the fuel lines exactly backwards.
Jan 16, 2014 | Stihl Ignition Module Coil 050, 051, 076,...
Stihl fs80av
generally you have 1 line from the tank that has a fuel filter attached to it that goes to the inlet port on the carb, 1 line from the carb to the primer bulb, and 1 line from the primer bulb back to the tank. when you press the primer it draws fuel through the carb and returns it to the tank through the primer bulb
Oct 13, 2013 | Garden
What is the fuel line routing on a Stihl FS 44?
Bigger (inner)of the two hoses is the supply to the carby ,the smaller hose (outer) fuel return from carby to tank.
Aug 26, 2012 | Stihl String Trimmer Brushcutter Service...
FUEL LINE FOR THE TS 500
You will need to contact a Stihl dealer. Here is a link to the site where you can locate a dealer near you.
Stihl dealers
Jul 10, 2012 | Stihl Saws
1998 land rover discovery oil seal same idea transmission seal?
To jlcbnyc go to www.sthilts460chopsaw.com you can get a mvery good diagram of this unit.Good Luck snor38
Jan 25, 2011 | Stihl Concrete Cutoff Saw Ts460 Oil Seal...
Stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Mar 24, 2010 | Oregon Scientific Complete Carburetor for...
Stihl Concrete Cutoff Saw Ts460 Oil Seal Ts 460 Logo
60 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
Spud Howell
ray gallant
Are you a Stihl Saw Expert? Answer questions, earn points and help others
