Question about INTELLINET GuestGate MK II Router
Wlan light intellinet is orange, no internet access
Intellinet wireless adapter malfunction
Wireless Zero Configuration (WZC) was introduced with Windows XP, it is also known as WLAN AutoConfig in Windows 7 and Vista. It is is a wireless connection management utility which dynamically selects a wireless network to connect to based on a user's preferences and various default settings. or most users the Windows Wireless Zero Utility is all that is needed to manage your wireless connections.
You can configure WZC as follows:
  1. Type services.msc in "run" and enter.
  2. Select wireless zero configuration from the list which appears in the next window.
  3. Double click on that option , and choose to Start or Stop the Wireless Zero service.
Here are steps to use Wireless Zero Configuration/WLAN AutoConfig in Windows 7:
  1. Click the Windows logo button
  2. Type services in the Start Menu's Search box and press Enter. Scroll to the bottom of the list and locate WLAN AutoConfig'. Double-click WLAN AutoConfig to open its Properties window.
  3. Click the General tab of WLAN AutoConfig service. Click the Startup type drop-down menu and click Automatic to have the service started automatically when the operating system loads. Click the Start button. Click Apply and then OK. Close the Services console window.
  4. Click the Windows logo button. Type cmd in the Search box and press Enter. In the Command Prompt window, type netsh wlan show settings and press Enter. Look at the last line of the Wireless LAN Settings entry to see if the message Auto configuration logic is enabled on interface or Auto configuration logic is disabled on interface appears. If the entry notes that it is disabled, type, set autoconfig enabled=yes interface=Interface Name and press Enter. Close the Command Prompt window.
Nov 25, 2011 | INTELLINET Wireless 150N USB Adapter...
I have a wireless 300n 3g router witch i cant get working... i can access the router trough wireless and wired connections but wont let me access the internet.. i have an eircom 3g stick plugged into it...
Hi,Just go to the Intellinet website and download the most recent Firmware with Modem update. I had the same problem with one of the latest 3G modems and the latest firmware had that sorted out.
Dec 27, 2010 | Intellinet Active Networking (520638)...
How can i activate internet on nokia E63?
Your device can detect and connect to wireless local area networks (WLAN). Using a WLAN, you can connect your device to the internet. To use a WLAN connection, you must create an internet access point (IAP) for the WLAN. Use the access point for applications that need to connect to the internet.
Use the WLAN wizard to create an access point
1. You can access the WLAN wizard directly from your home screen's information area. Another way to get to the WLAN wizard is to select Menu > Connectivity > WLAN wizard.
2. If the search finds WLANs, you can create an internet access point - scroll to the connection, select Options > Start web browsing. If you select a secured WLAN, you will be asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
3. To end the active connection, select the connection > Options and Exit. If you want to define whether you want to use the WLAN or packet data connection when starting to browse the web, you can set it so that the device always asks which access point is to be used.
Set up an access point inquiry when you open the browser
1. Select Options > Settings.
2. Select General > Access point, and from Always ask - You always get to select which access point you use.
Nov 02, 2010 | Nokia E63 Cell Phone
Wirelesss access point as repeater
Where r u currently located? i can help u over a phone or remote
Apr 21, 2010 | Intellinet Active Networking Wireless G...
I NEED AWEP NOR AWPA FOR MY INTELLINET WIRELESS G
Get into the configuration mode of the router by using your browser and type 192.168.1.1.
Give your username & pwd(usually ...admin/admin) and then go to wireles security tab and select WEP or WPA.
Oct 19, 2009 | Intellinet Active Networking Intellinet...
Wlan light orange
Orange WLAN light means no connectivity to the network. Try to reconnect to your wireless network and make sure to enter the correct wireless settings like the network key and SSID.
Apr 25, 2009 | Computers & Internet
Securing/Locking Wireless Service
I assume that you have at least a PC or laptop with MS Windows XP SP2 or Vista running.
Use the create a network key for the security of your network. You must name the network and then create a password for it. Also use WEP if your OS has it. Goto 'Network/ Internet' from the Control Panel ........
Feb 26, 2009 | Intellinet Active Networking Intellinet...
Orange blink of death!!!
Hello houng_lee,
I have the exact same modem, if the modem/router light is blinking, that indicates a problem with the modem. You indicate that you have internet connectivety, so you should have modem light solid blue. When you look at the Wireless light it's probably off. Which means that at this point you have internet connectivety, you should put the cd in and run through the wireless connection wizard on the CD. It will check to see 1) if you have internet connection, 2) the type of connection you have (comcast) 3) if you have any wireless devices to be hooked up. 4) That all connections are working properly.
If you have a laptop that you want to connect to the wireless router, have it next to the router, so once you've finished setting up your Wireless security and issing a WEP number for local access, you can test your setting immediately with the Laptop. I always suggest that you create a WEP number for securty reason, If you perfer not to create a WEP number, and leave it as an open access (which is fine, and easier to setup) make sure that you shut off broadcasting, So your neigborhood doesn't jump online once they see an open access router.
If you've tried these steps let me know what problems your getting during the wizard setup. It will tell you if everything is setup correctly, or their is an error. Right now, I think the problem is your setup, and it's not communicating correctly. But, the wizard will tell you that as well.
Let me know,
Good Luck
Mark
Feb 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Intellinet wireless lan card wpcd14 a1 b1
Here is the link you can use to download the drivers for your card just scroll down the list and choose the install for you card and operting system.
http://www.intellinet-network.com/html/d-wlan-pci.htm
Apr 13, 2008 | Intellinet Active Networking (502191)...
INTELLINET GuestGate MK II Router Logo
Top INTELLINET Computers & Internet Experts
Terry Hair
Are you an INTELLINET Computer and Internet Expert? Answer questions, earn points and help others
