Question about Grohe 28.444.AV0 Movario 5 Spray Hand Shower - Infinity Satin Nickel
The hand held shower head pops off when water is diverted to it
The hose snaps in just fine, however when we divert the water to the hand held sprayer it flys off
3 Suggested Answers
  • 297 Answers
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
al_kupchella
  • 843 Answers
SOURCE: Can the hand-held shower hose be replace without
No, you need to cut a hole. Usually an access panel is provided during the initial installation, either in the ceiling from downstairs or in the other side of the adjacent wall. But it's pretty easy to add one. After you cut a nice rectangular hole, you can cover it with a piece of painted plywood that has a trim piece attached to the plywood. The plywood is held in place with a couple of screws. When you remove the panel, the trim stays attached to the plywood. When you place the panel in the hole, the trim covers the gap between the drywall and the plywood.
Posted on Dec 01, 2010
How do I change a single diverter to a 3 way diverter?
Not exactly sure what you are attempting. A quick-and relatively inexpensive way-would be to add an Alsons diverter to the shower arm. It is simply removing the shower head, adding the diverter, and reinstalling the shower head and accessory hand held shower. If you are looking for something different, there are myriad valves on the market that would allow for such change. However, changing to a new valve could get somewhat complicated. For example: you may need to increase the size of the supply lines that are feeding the shower; some diverters require a 3/4" feed.
Also, if you check the box stores, they have several shower/hand held shower kits that already have the diverter with the packaging. Again, I am not exactly sure of the end result in which you seek, but I hope this helps some.
Oct 31, 2014 | Dmm Symmons Temptrol pressure balancing...
I have a delta single handle tub fixture the shower diverter pops out all the time
Hi Jeff sorry about your problem. Just wanted to ask about what you mean pops out. When you try to get water to the shower head the spout "pops out" and water just goes back to the tub? If this is the case it sounds like your diverter on the spout has failed. I favor the Delta one that you have to pull the chromed plastic area where the water discharges instead of the one with the knob you have to pull up to get it to divert the water to the shower head.
These both are available at your local plumbing supply store not the big box store always but I have noticed them at the HD in Honolulu. I hope this helps if not a photo goes a long way. Dave.
Sep 21, 2014 | Home
What to do if i can't stop the water flowing from the shower spout and there's little water pressure coming from the shower head and a hand held shower?
One rule I live by: more parts, more problems. Sounds to me that the plumbing/valves were not insalled properly. If you hired a profesional plumber, have them fix it. I am a licensed profesional plumber and I offer a 1 year warranty on all my work. If the contractor did the work and does not hold a plumbing license, that person is still responsible and may have to suffer legal consequenses.
Sep 10, 2013 | Latoscana TC3TPW690 Water Harmony...
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
Water comes out of kitchen tap then slows down to nothing at all comin out
If the aerator is clear of debris, there is a valve of sorts in the center of the faucet that diverts water to a spray nozzle (the sprayer on a hose that would be next to the faucet). Even if you don't have the sprayer, most all kitchen faucets have this diverter valve. It's a bit like the thing (in a bathtub/shower combination) that switches the flow from the tub spout to the shower head.
Sometimes, something will work its way into the diverter so that it stops the flow to the tap. It could be a piece of debris (mineral flake, rust flake, etc.) that can be backflushed out. This would require removing the faucet and removing the main valve assembly. Long story short, think about replacing the faucet if the diverter valve is acting up.
Mar 12, 2011 | Washing Machines
I just installed the valve new. I have a shoewe head and a hand held that feed from the unit. It was intended to 1) serve the shower heas alone, 2) serve the hand held unit alone, 3) put water to both...
Assuming that your two heads are fed from the typical curved wall mounted shower pipe, what you need is a diverter valve. Removed both heads till it's down to just that curved pipe. Get a diverter valve from a plumbing supply store. Tell the sales folks that you want to install a diverter valve so that in one position, the hand held receives water and in the other, it cuts the hand held and puts it to the reg. shower head instead. They should give you a "T" sort of fitting. The female threads of this screws into that curved shower pipe. Then you will find two male thread ends. These connect to both your shower heads. Finally there will be a push/pull knob that is operated to control which head gets the water.
Nimsgame
Feb 13, 2011 | Home
Can this diverter run both the shower head and a hand held shower.
This unit will allow the function of the shower head or the hand held shower individually. You can make both operate at the same time but the performance will be dismall at best.
Oct 23, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
Leaking
Make sure you fitted the rubber O ring on the end of the shower flexible hose. That will seal the water pipe.
Mar 29, 2017 | Kohler K-9511-BN MasterShower Shower Arm &...
Shower - Rain head won't turn off so hand held can be used solo.
Probably the fitting is not working properly. Please change the fitting.
Apr 17, 2010 | Plumbing
Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
Grohe 28.444.AV0 Movario 5 Spray Hand Shower - Infinity Satin Nickel Logo
32 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
