Question about Belkin (F5D5231-4) Router
Hi. I have a Belkin Wieless G Router and the internet light is OFF but the wireless light is on. I can connect to the internet with a wired ethernet connection directly from the modem but not wirelessly. I have had this router for a while and it just recently stopped getting connectivity. I have tried rebooting multiple times and it still not working.
  • 192 Answers
You internet provider may not support that router anymore or the freeware needs to be upgraded.
Posted on Jan 24, 2009
I have successfully installed a belkin surf n300 wireless router to my laptop, i can connect to the internet via ethernet cabler but when i disconnect the cable i lose the internet connection. how do i...
here is the manual http://cache-www.belkin.com/support/dl/8820ed00372_f7d2301_v1_uk.pdf
look up under your wireless security as it isnt set up right either in the router or on your computer.
look at page 8 to 13 of the PDF and follow the set up again. you will need the wire plugged in while doing this process but afterwords you can go wireless after a reboot.
Apr 30, 2011 | Belkin Surf N300 Wireless N Router
Bad Belkin 54g Connection Problems!
reboot your modem then reboot the router that should fix it
Jun 26, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
I just bought a Belkin Router Model # F5D8236-4. I have everything wired correctly, but the wireless light does not come on. I can't get the internet to come on to the computer I want to connect to? What...
Wireless light will lit up only if any wireless computer is connected to Belkin's wireless network.
First, connect to Belkin's wireless network that you can scan.
After you connect, try to go online
It ll work...
Jan 21, 2010 | Belkin (F5D8231-4) Wireless Router...
Belkin Wireless G Plus MIMO router - connectivity problem
  • this problem can be ISP releted they may have some issues on the ADSL line connection
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't configure belkin n wireless router.
yes always best to use ethernet when you can.richardm69
Feb 03, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
I unplugged the cable connected to my desktop and the wireless function stopped working
You must always have a 'host' adaptor whether you want a LAN or a WAN. Go to your configuration utility or control panel via your Run command to set or view your options. Steve Medley
Nov 07, 2008 | Belkin (F5D8231-4) Wireless Router...
No wifi connection
Verify which MAC Address U have Cloned. MAC Address of Your PC WiFi and Cloned One must not be same otherwise it will not work...
Feb 02, 2008 | Belkin (F5D7231-4) Wireless Router
Belkin wireless
the red light means u havent got a connection if u have installed properly try upgrading the firmware the problem might be the routers
http://www.belkin.com/support/product/?lid=en&pid=F5D9230-4&scid=221
Dec 09, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D5231-4) Router Logo
190 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
