Question about Kitchen Ranges
Owners manual for a 3448xtw magic chef range/oven
Where is the burner igition located
fridgetech
  • 473 Answers
SOURCE: MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Posted on Nov 18, 2007
  • 1314 Answers
SOURCE: magic chef range
if you give me a model number i be might be able to help try here get your model number off the serial plate from the range http://www.maytag.com/support/manuals_literature.jsp if that dont work reply to this thread with model number
Posted on Jan 15, 2008
  • 1314 Answers
SOURCE: Magic chef oven
change the bottom ignighter just because it glowes doesn't mean its getting hot enough to open the safety valve you should see two screws at the bottom of the floor of the oven cavity after removing the racks remove those and remove the floor then you will see a deflector shield remove that to get access to the ignighter take out the two screws and install the new ignightor and reassemble
Posted on Jan 21, 2008
battlesmith
  • 382 Answers
SOURCE: lighting pilot light on magic chef gas range
Hello Jim,
Try to replace the ignitor if it is more than 3 or 4 yrs. old..If it not that old then Turn the knob to the pilot setting and depress the handle. Holding it down and at the same time, press down on the red button that sparks. You may have to repeat this a few times. Once the pilot lights, continue to hold down on the pilot knob for about 30 seconds. When you release the knob, the flame should stay oN. If it does not, replace the thermocouple. Once the pilot flame is steady, turn the gas valve knob to on!!!..Thank you...
Hope this helps you!!...
Regards!!!....
Posted on Jul 24, 2008
SOURCE: Magic Chef LP range produces soot whenever oven is on.
The vent (shutter) allowing air to mix with the gas has shut. Access the burner with the oven off, of course, and look for the shutter (a sliding 'door'). It usually has one screw holding it n place and an elongated slot to permit adjustment. It may also turn. Since your burner is producing soot, you need to open the shutter more. Loosen the screw and slide the shutter open more. Turn the oven on and look for a nice blue flame, and one that doesn't run too far over the burner. Keeping in mind that everything there will be hot when the burner is on, and also for a long time after it is off, you can use a long-bladed screwdriver to push the shutter back and forth to get the flame you are looking for. If the screw is loose, a gentle tap will be enough. When you are see that optimum blue flame and you are satisfied, let the oven cool off for an hour or so, and final tighten the screw--making sure you haven't moved the shutter much when tightening. If this doesn't work you have a bigger problem and need to call a service person. Your local gas company sometimes will direct you to a person.
Posted on Oct 12, 2009
We have a magic chef gas stove with sealed burners. were trying to change it over from natural gas to L.P. do we haveto have different orfaces?
Do you have your owner's manual? It will tell you how to convert it to propane and what size orifices to use with each burner. Not all the burners are the same size, so you will need this info in order to install the right size orifices. The data plate on the oven, which is usually behind the bottom pull out drawer, will tell you what the BTU rating is for each stovetop and oven/broiler burner. If you don't have the owner's manual, reply back with the exact model # you have (it's listed on the data plate too) and I'll look it up for you. You will need a small nut driver tool to change the orifices. As soon as you provide more info, I'll try to help you further. Douglas
May 28, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Magic chef gas oven range 6498xvs oven no longer works.
i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
May 20, 2009 | Ovens
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
We own a 1973 TravelEze travel trailer with a magic chef lp 4 burner range. The model number is unreadable. It does start with BT22 we think. We would like to order a replacement gas regulator and a m
I think you should have more numbers. there are quite a few other series for this unit. I have posted a site below for your assistance.
http://www.aaarv.net/bt22_series_parts.htm
Please rank if this helped
Apr 27, 2009 | Magic Chef 9122 Gas Single Oven
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Kitchen Ranges Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
