Question about Electrical Supplies
How many amp circut to operate the C3000 welder
I want to ad a sub panel for the C3000 pannel spotter and need to know if i can go with a 30 amp breaker
  • 50 Answers
SOURCE: I need to install a GFI breaker on a Baptistry.
You could install a standard GFCI in line at each component ( heater, pump & timer) or you could install AFCI breakers similar to what are required in many residential codes (provide the same protection at the panel not at the location... http://www.cpsc.gov/CPSCPUB/PUBS/afcifac8.PDF
The AFCI breakers will need to match your panel type (siemens, GE or Square-D) and the amperage/configuration.
I would install them at the lowest level (closest to the components) in the system to reduce possibility of fire in the wiring between the components and the afci breaker.
Posted on Jan 04, 2009
protek480
  • 1714 Answers
SOURCE: My double pole 30 amp sqaure D breaker gets a little warm...
You need to check the amp draw on the breaker that is warm. The smell you notice is not normal. Use a temp gun to test the breakers for higher that normal reading. High temp is caused by high current or loose connection.
Posted on Jun 30, 2009
gotgeek2
  • 565 Answers
SOURCE: 100 amp CH breaker does not seat on older CH main
You can Google the catalog number for that breaker. You can also try to call local electrical contractors as one can usually find at least one contractor who has saved every old part that they have removed over the years. Also try ebay.
Unfortunately, even if you do find the correct breaker it will probably be very expensive :-(
Posted on Dec 10, 2009
  • 760 Answers
SOURCE: I am installing a sub panel in a detached building
You could use 6/3 with ground. You must take an equipment ground conductor along with your current carrying conductors. Still drive a ground rod at the building, and add a seperate ground bar in the sub panel. Connect your equipment grounding conductor from main building along with the equipment grouding conductor to the ground rod. Do not bond the neutral in the sub panel to ground. Be aware you will still have some voltage drop, so a 220V air conditioner might be better.
Posted on Sep 24, 2010
canwoodjc
  • 3301 Answers
SOURCE: Are there large amp breakers
yes, but your main panel has to be able to handle the sub in amps ,
Posted on Jul 05, 2011
230 volt welder
Breaker must be 50A and the size wire should be a 8/3.
Feb 23, 2014 | Welding Tools
I was welding and it just cut off and wouldnt come back on.
CHECK YOUR BREAKER FOR THAT CIRCUT OR RESET BUTTON ON
THE MACHINE.
Sep 20, 2011 | Lincoln Electric Lincoln Power MIG 216...
I aquired a Dayton mod: 3Z744 Arc welder (with no manual).I understand a dedicated electic circuit is necessary for this unit.How many amps should this 115v circuit have?
To be on the safe side when you want to weld at max setting I would go with a 30 amp circuit.Hope this helps you. Thanks.
Aug 02, 2011 | Garden
Curcit breaker triping
chances being this welder is probaby 30 amp. rated and you probably have amp. service at a lower rating change your breakers to 30 amp. or higher or you fuses i do hope this will help you,thank you.
Dec 23, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Its in protect mode and i don't know how to get it out it was hitting fine then it just stopped and i looked at the subs and they would posh all the way out then back i don't know whats wrong
overloading your amp try just one sub hooked up and see what happens if it starts working do not bridge your subs use two channels and try again other wise you fried the circut board in the amp some where
Oct 31, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
POWER ISSUES
Recomend installing a capacitor, this will control voltage drop and reduce heat. The new battery should help, but it also may be that the amps final circuts could be wearing out, and no longer able to handle the load of the sub.
Sep 28, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Ground rod placement
If this is a Sub pannel that is fed from a main pannel then you don't need a ground rod for it, but you do need to run a ground wire in the cable that feeds it. So if it is fed by a 220 volt breaker in the main pannel it needs both hot wires, a neutral, and a ground wire in the cable.
Also when you get to the pannel do not attach the ground bonding jumper to the neutral bus in the sub pannel. each of the 4 wires will be seperated at the sub pannel.
Presto.
Aug 24, 2009 | Electrical Supplies
Lincoln Welder Generator Oil Question
Better late then never! im-308 total lube oil is 4 pints for a briggs and stratton engine
and 3.5 for an onan engine with filter change.
Note: an internal kill switch will shut down the engine if the oil level drops below a minumum
operating level on the onan engine only.
on your welder use a multi-viscosity sae sj grade or better oil. recommended is 10w-30.
if you work in cold environments use 5w-30 oil , it's thinner and will flow easier
during cold starts. Synthetic oil is better. just more expensive. change oil at least
every 100 hours for better performance. good luck!
Aug 19, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
My welder will on weld for 30 seconds
Check the timer on the frot pannel, a diail with "......." or ------ " will be seen beneath the dial, turn the dial anti clockwise to off position.
Aug 19, 2009 | Lincoln Welding Tools
SNAP-ON FM140A MIG WELDER. HOW TO SET UP WIREING TO UPGRADE TO 30AMP OPERATION FROM 20AMP SYSTEM.
Hi, yes it can be ugraded but,( theres always a but,) you will need a feed from the mains to a rated connection on the main fuse box, this is not a DIY job, certain rules and regulations prohibit the unqualified. the new line will run to it's own fuse box, then to wherever you want, garage or w/shop with electrical cable 1.5biger than your max (30 amps) best be safe , you cooker socket is thirty amp, but thats max, there are some people that would increase the fuse size, ending up,( If they arel lucky), for a total re-wire those unlucky guy's arn't around to tell the tale. contact your provider and get it safe.
lets know how you get on
Feb 26, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Electrical Supplies Logo
23 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
