Question about Garden
Stihl ts460 fuel and oil line routing
Took the carb off and now i need the routing for the fuel and oil lines
  • 97 Answers
SOURCE: routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Posted on Mar 21, 2009
  • 148 Answers
SOURCE: routing of fuel lines for a weedeater bv200 type
The line with the filter goes to the bottom of the carb. The other line goes to the outlet side of the primer bulb and the other line from the primer bulb goes to the top of the carb (The primer sucks gas through the carb).
Ps. if you are not sure which nipple of the primer is the outlet port then put your finger on one of the ports and push the bulb. If the bulb stays ridged then that's the outlet and if it collapses but doesn't fill but up then that's the inlet side.
Posted on Jul 13, 2009
  • 3 Answers
SOURCE: need a diagram to route fuel lines on a carb
my polaris outlaw 500 sarted cuting out last ride could not ecerate past 1/4 throtle and was back fireing so went to fix and wont run at all i have spark, plug is wet, changed fuel, seems to have compresion, when it turns over it tries to fire at times more like a hickup almost stops the sarter and a puff of smoke out the carb. im about to tare it down any ideas whats wrong ? bike was hard to start but ran ran perfect killed raptors with ease. bike was bored and built by some shop before i owned using ktm sleave and piston ? motor says nicols 520. didt over heat or make noises. have tried cleaning carb, jeting no luck please help
Posted on Jul 14, 2009
  • 3 Answers
SOURCE: i need fuel line routing for mcculloch fr2.0 chainsaw
primer bulb... long barb goes to fuel tank pick-up.... short goes to carb.... make sure the new tubing is safe for the damn ethanol fuel and that it fits snug thru the tank or it will leak
Posted on Aug 18, 2009
Testimonial: "thanks"
dontbother10
  • 2220 Answers
SOURCE: McCulloch 3216 fuel primer and gas tubes routing?
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Posted on Nov 01, 2009
I have an older stihl chain saw And cleaned out the carburetor, in the process the discharge line seemed plugged then is it vital to have vacuum on the discharge line or is it a drain into the case?
ive read this a few times and ive still got a few questions : if this saw is made past 1980 its got a fuel return line from carb (as well as a supply line) also there should be a suction line over to the oil tank that makes the oil pump work, past 1992 the vac line was gone and oil pump only works by piston , is this the lines your speaking of ???
but generally if its got a hose , its suppose to work .
Aug 22, 2016 | Stihl Garden
Stihl chain saw diagram primer bulb
need new carb... Primer plate is bad. They will run without it working. Your idle problem is separate from this issue. Fresh fuel/oil mix might help. Some Stihl carbs we just replace because they are cheaper than trying to rebuild...
Nov 12, 2013 | Craftsman Convertible 25cc. Gas Line...
Stihl fs80av
generally you have 1 line from the tank that has a fuel filter attached to it that goes to the inlet port on the carb, 1 line from the carb to the primer bulb, and 1 line from the primer bulb back to the tank. when you press the primer it draws fuel through the carb and returns it to the tank through the primer bulb
Oct 13, 2013 | Garden
Stihl weedeater
I'd put my money on it being the actual carb body. The carb body its self contains a couple of small valves which can get blocked or damaged and are practically impossible to replace. Look for a second hand OEM carb and if needed use your rebuild kit on it. That would be the cheapest route
Jun 02, 2013 | Garden
Fuel line routing for craftsman chainsaw 358.350370
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Jan 11, 2012 | Garden
I need routing diagrams for both gas & oil lines for a 1990 HD XLH883H Sportster
Contact me directly at wd4ity@bellsouth.net and I'll send you a drawing for the oil lines. The fuel line simply runs from the petcock to the carb between the cylinders. Nothing special about it's routing.
Steve
Aug 12, 2011 | Harley Davidson XLH Sportster 883 Hugger...
I have a 2250 Poulan. The fuel lines have been removed. Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out...
Is there a fix for bar oil running out of the saw all the time until the tank is empty?
there is bad oil line repalce it.
Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out at the top of the carb. to the primer\'s suction side? Then out of the primer to the fuel tank? This route the primer pulls gas through the carb. Does it make any difference which hole in the tank the lines go to?
YES that correct
Dec 29, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
My Husqy 141 runs then stops
Shaemeus forcing a fuel line and breaking the carburetor will certainly be more expensive than saw shop service. Take the saw in. Most are barbed fillings, if one is exceptionally difficult let the saw shop break it and pay for its replacement. While there ask them to demonstrate how to disconnect the line. I suspect rather than a blocked line you have a hole or crack in a line.
A tune up with hose replacement I estimate at $60 at a Stihl shop.
New plug, new fuel filter, pressure/vacuum tests, carburetor adjustment. Actually a pretty good deal, tune up ($40). ALL hose replacement ($20).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 15, 2010 | Husqvarna Garden
Stihl blower - full throttle it stalls out. low speed ok. have replaced fuel line, spark plug.
Your carburetor needs cleaned or you need a carb. kit depending on how old the carb. parts are. If you need tips on carb. cleaning, feel free to ask.
Jim
May 30, 2009 | Echo Garden
Stihl carb
Try this link. It has the carby settings on page 26 & 27 of the Stihl FS 45 manual.
http://www.mccoyslawn.com/parts-manuals/Stihl/FS45_46_Manual.pdf
Apr 17, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
