Question about Adesso Cyber 8600 10-Pack (CT8600A)
Tablet Pen Lines
When I go to draw with my Tablet Pen, I get a jillion lines I didn't draw, and a little blue circle. I have rebooted several times, and I do not plan on wasting more money to buy a new one. What can I do?
2 Suggested Answers
SOURCE: Adesso cybertablet 12000 mouse and pen problem
I had the same problem way back with my wacom tablet. Mine was due to mouseware drivers. Soon as I got rid of them it was fine. So if you have mouseware drivers it may be interfering with the wintab drivers
Posted on Sep 25, 2007
  • 13433 Answers
SOURCE: Are my settings wrong?
Hello, thanks for using FixYa.
That is completely normal, you haven't gotten used to using the pad. I was just looking at a review of the pad and the author writes
" The tablet worked well. It took me some time to get used to how a tablet functions as it is very different from a mouse. When I picked up the stylus from the tablet, and moved it to the right or left, and placed it back down, it was though I was drawing on a paper, and so the drawing would start in a new area, rather than where I "left" the mouse cursor. There was also a disconnect for me, as I continued to look down at my position, only to not have any real information without looking at what I was doing on the screen. I think this would change after some use, but for me, it was a strange feeling."
There is a toggle button on the pen that allows you to stop it from drawing. You can read the review here
So it seems the tablet is working normally, but it is not a mouse. It will take you some time to get used to it. The program might have settings that you can adjust that might help or make it easier to use. But don't expect too much. It will take time to master the tablet.
Posted on Oct 08, 2010
0 characters
1 Points
Illustrator CS5 does not recognize my graphic pen, wether with the Wacom tablet or my new Monoprice tablet. It draws a yellow sticky note kind of thing, it is annoying and I can't find a solution,
I too have a tablet not made by Wacom. For some reason, Illustrator only opens the tablet-sensitive definitions for Wacom. The solution I found: Go to the Wacom site, install the latest intuos driver. You won't be using it, but it will trick Illustrator into thinking there's a Wacom installed, the definitions will be active for your pen. Mine seems to work fine now.
Jun 28, 2012 | Wacom Graphics Tablets
I have a Trust TB-7300 and Windows 7. When i draw something, for exemple in Photoshop. Suddenly the pointer draw a bold line wherever it feels like. It also stand still for a couple of seconds, time to...
Hi bmw530640.
Draw a line and check meanwhile whether or not the blue indicator light keeps burning on the top left of your tablet. If not, there's a bad contact between your pen and the tablet, probably due to a malfunctioning connection between the battery and the electronics of your pen. If so, ask for a new pen on the Trust company website.
Dec 28, 2010 | Trust TB-7300
Is it possible to remove features from a tablet?
I have the bamboo fun pen also. I am currently running Windows Vista 64bit home and have the same problem. I fixed mine by going into the control options > Tablet PC Settings > Other > Go to Pen and Input Devices > Settings (Under Pen Options) Then I clicked at the top Where it states "Enable press and hold for Right-clicking". I disabled that and my pen works with no holding for the right click. I can make scratch marks all day! Hope this helps you too.
Dec 25, 2009 | Wacom Bamboo Fun 8.5" x 5.3" USB Tablet...
Hello! I own a Intuos3 Wacom tablet and I am having problems with it. My old laptop did not recognize discs, so I installed my tablet using one of the drivers from the download section and it worked just...
I'm getting the same problem - for some reason it's removed all pen pressure sensitivity recognition from the tablet. I'm going to try re-installing the drivers tonight, I'll get back to you if I figure it out.
Oct 03, 2009 | Wacom Intuos3 Graphic Tablet
Wavy lines when I try to draw straight lines.
same too me.on my old pc.that center thing was working fine.there wasnt any vibrtion at mouse pointer.i cant explain but i know same problem here..mouse pointer slips
Aug 12, 2009 | Wacom Intuos2 Grip Pen (XP-501E) Digital...
Photoshop and WP5540 compatibility
get PS cs3, never had problems with that one, i own a genius 8X6 and it was perfect, yeah i know it sucks cause i brought cs4, but well, gotta wait till those guys from adobe fix that problem
Jan 24, 2009 | Graphics Tablets
Pen Won't STOP Working
Well... I contacted Wacom support and the guy who write back recomended me to change the nib, to turn 3 times the eraser and to hit 4 times with the pen onto your palm hand...
Of course I didn´t do anything like that, I mean, what´s that??? An spell of some sort (or what)???
But what I did was the following (MAC-OS user):
-Enter to the pen tablet options on your preferences
-Switch the sensitiveness of the pen to the hardest
-Run an app that work´s best with your tablet and make some lines to check if at least in this mode the pen works
-Return to your tablet preferences and adjust at your best
I can´t explain why but my stylus is working fine again...
hope someone find this useful...
Oct 20, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Tablet gone insane.
I'm from ukraine, sorry my english;
Random clicks hapens becouse moving tip not return to the front. It continue to sent chaotic pressure messages. Some times, when you start to lift pen, tip start to resilient and we have ugly dots again.
Here is solution:
May be auto silicon oil wil help by reducing rubbing. Or harder spring will help?
I use little bit of plasticine. I push it under the tip. It prevent tip from resilienting. I have no problems, since i made this.
Good luck.
Nov 05, 2007 | Genius Pensketch 9x12 USB Deep Blue...
My cursor was smooth and easy to draw with, but now it's all shaky and won't draw well!
the latest drivers have 2 modes...
1 open the driver control panel
2 at the top of the window double click the intuos3 tablet that is giving you problems
3 choose standard mode instead of recognition data
... this is at least what worked for me. I hope it helps.
Aug 01, 2007 | Wacom Intuos3 6x11
Adesso Cyber 8600 10-Pack (CT8600A) Logo
Top Adesso Graphics Tablets Experts
ray gallant
Julie Clark
Are you an Adesso Graphics Tablet Expert? Answer questions, earn points and help others
