Question about Brother MFC-5840CN All-In-One InkJet Printer
Brother MFC 5480cn and SBS 2003
I have been able to use SBS 2003 as a print server for my Brother 5480cn printer but the device manager still shows the yellow question marks. It is a multifunction printer and when connected to my SBS server I have no scanning ability either without plugging the usb cable into another computer on the network. I used the drivers for Windows 2003 server from but like I said it only gives me printing. How can I get the multifunction running through my SBS 03 server like I had it running through my vista ultimate computer?
SOURCE: brother MFC 7420 all in one Scanner not working
sorry but is the 7420 compatible with Vista? what does the box say?
Posted on Mar 01, 2008
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
  • 320 Answers
SOURCE: error 2001 on brother mfc 7420
please tell me more! i just checked my brother manual and i do not see a error code 2001????????????
Posted on Feb 16, 2009
the kowalski
  • 86 Answers
SOURCE: Brother MCF-6490CW will not intall drivers with Windows 7 Ultimat
The drivers should come inboxed with windows 7 on the official final versions. Later on the drivers also will be released on brother's homepage(s), but they usually take some time before uploading drivers to the homepage when new OS' are released. Try using the Add Printer Wizard and see if you're able to find the MFC-6490CW in the list of printers available.
Posted on Jun 02, 2009
  • 7 Answers
I had the SAME problem. I have 3 pc laptops and 1 Mac. The Mac could still print, but the pc's were hosed. I called BrotherUSA and this fixed the problem!
Go to your printer and after making sure it's connected to the network with the Ethernet cable, go to Menu > Print Reports > Network Config. This will print a page that shows your printer's IP address. We need to config that address in your Printer, Fax and Scanner settings in Control Panel.
Go to Control Panel > Printers & Faxes. Right click on your printer > Properties > Ports tab. Click Add Port and select Standard TCP/IP Port. Click New Port and click Next on the wizard. Enter the IP address of your printer in the first field (the second one will auto-fill). Click Next and Finish. Printer's done!
Right click on your PC-FAX in Printers & Faxes and Properties. Click on the ports tab and just check the box that you just created for Standard TCP/IP Port. Click OK. Fax is done!
Go back to Control Panel and select Scanners & Cameras. Right click on your printer/scanner > Properties > Network Setting tab. Select the Specify your machine by address radio button and, if it's not already in there, enter the IP address of your printer. Click OK. Scanner's done!
This will work as long as your router is running. You may need to repeat this process after a power outage or if you need to reboot your wireless router. Not too bad, though! I just wish everything was as easy as a Mac!!!
Posted on Aug 27, 2009
Outlook won't print to Brother MFC7360N AllInOne Laser Printer
Must be set on Brother MFC-7360N series. Set on PC-FAX will not print with all programs, as it is printing with an output through the fax. Go to control panel, select devices, printers to change to pc-7360 series. This should print on all programs.
Mar 17, 2014 | Brother HL-5240 Laser Printer
I have a printer problem, it is a Brother MFC-465CN. the lcd display screen is showing "Unable to Int. 48" can ou help please
This indicates a problem with the print head.
Clean the print head when needed by doing one of the following:
  • Press the Ink or Ink Management key and then select Cleaning. Or
  • Press the Menu key and then select Ink Management, Cleaning.
These cleaning processes do consume an amount of ink.
Nov 02, 2010 | Brother MFC-465CN InkJet Printer
Can my brothers mfc 240c printer be used to print from more than 1 computer in my house wirelessly? how do I set this up?
The MFC-240C does not have a wireless interface, so you can't connect wirelessly directly to it. What you would have to do is set up a print server, which can be a standalone device or can be one of your computers, and then the other computers would print through that one connected computer.
Jun 26, 2010 | Brother MFC 240C All-In-One InkJet Printer
How do I connect my Brother MFC-9440CN laser printer to my laptop wirelessly?
You need to supply IP address to your printer then the the Laptop also needs an IP. Try to ping first the printer IP add if its visible. thanks.
May 22, 2010 | Brother MFC-9440CN Laser Printer
MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
Does anyone know where to get drivers for a Brother MFC 7340 for windows server 2003? I have found windows server 2000, xp, vista, and windows 7 drivers but not server 2003.
If there is no driver ... that means the OS does not support the hardware. Your options are ... Microsoft, Brother, third party or learn how to program and write one. You can appeal to MS and Brother ... my guess is they will not likely write a new driver for a 7 year old OS.
Does the MFC 7340 have a ethernet connection? You might be able to print to it as a network device through a 'qualifying' computer ... Copy the document from the computer running Server 2003 to a XP or other computer and print from there ... just an idea.
May 02, 2010 | Brother MFC-7340 All-In-One Laser Printer
Rpc server is unavailable
The computer displays error "RPC Server is unavailable".
It may be that you have a static value in your registry's field PagedPoolSize, we need to make this "0" (zero). check the steps ->HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
Jan 29, 2009 | Brother MultiFunction Center MFC-440CN...
It isn't a network printer since it only has a USB interface (no LAN port)
but you may purchase a print server if you want to share the printing function on your network (only the printing function can be shared). But some multifunction printers do not work with print servers due to driver issues. There are some users on the net who were able to make this work with an IOGEAR multifunction print server.
There is one Brother multifunction network printer that you may want to check:
Dec 11, 2008 | Brother MultiFunction Center MFC-440CN...
Trouble prining with my MFC 5480cn. Using
Hello you can delete the print job manually.
you need to have administrative right on the computer to do this.
go to run> input "cmd"
net stop spooler
go to
%SystemRoot%\system32\spool\printers or(System32\SpoolPrinters )
delete all files that ends with->
write in cmd "net start spooler"
check your printer job now and it should be gone.
good luck
Sep 16, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
169 people viewed this question
James Cagle
James Cagle
Jim Keysor
