Question about Hotpoint HSS25GFP Side by Side Refrigerator
How to replace evap fan motor on ge side by side refridgerator
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
My GE refrigerator is not maintaing cold temp in either frig or freezer
Probabilities:
1. Main board, most likely
2. And/or evap. fan motor less likely.
3. Defrost heater, less likely
4. Evaporator thermister, unlikely, but possible
Try defrosting it for 24 hours (by unplugging) and see if it helps.
GE refrigerator repair orange county, ca
Feb 06, 2010 | GE GSL22JFPBS Side by Side Refrigerator
New evaporator fan not running smoothly
Great ! ! Usually the main control board is the problem , when the evap fan doesn't run .
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer fan noise
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
May 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Evaporator freezing up on my ge gss25tsrd refridgerator
YOU CAN SEE HEAVY FROST ON THE REAR OF FREEZER WALL?
Jan 29, 2009 | GE Refrigerators
My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Sep 08, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Fa does ot work replaced fan motor fa still does not come on
it's probably the board in behind the cover in back of refrig.it powers the fan. it's a good idea to replace white sensor on evap coil also if your fan didn't come with one
Mar 05, 2008 | GE GSH25JFR Side by Side Refrigerator
How to troubleshoot amana refridgerator
the evap fan, fan by compressor and the compressor should all be running. if they are then more than likely a bad compressor, so junk it
Oct 30, 2007 | Amana 22.6 cu. ft. Side-By-Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
19 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
