Question about Stihl Ts460 Cut Off Saw Gas Tank
Stihl ts460 fuel line routing
Had to put in new crank seals and took off the carb and cant figure out how they go back, help
2 Suggested Answers
snowghost1
  • 784 Answers
SOURCE: hi i have a stihl 056 super it starts and runs but only for about 30sec and about a minute on tickover then dies
hi,
I have this problem with my saw every 5 years,, first thing to check would be to see if the fuel hose has any cracks in it ~~ 9 times out of 10 the cracks are where the hose enters the fuel tank ( at the bend ).
after you check that and you are still having problems please feel free to write me back and we can move on to the next thing to look at.
chris...
Posted on Sep 21, 2012
Stihl 024 AV won't start. Replaced carb, plug, air filter, fuel line. Ran fine for 10 min then quit.
Fuel mixed properly and fresh?
if you put a few drops of fuel directly into carb, does it run for a few seconds?
have you checked the piston for scoring? (By removing muffler)
Apr 22, 2017 | Stihl Garden
My stihl fs56 strimmer will not start,i have a spark & fuel new plug cleaned carb help please
if you have spark and fuel then id be looking at lack of compression.. damaged piston ring or damaged crank seal/gasket
Apr 15, 2014 | Stihl Garden
Stihl fs80av
generally you have 1 line from the tank that has a fuel filter attached to it that goes to the inlet port on the carb, 1 line from the carb to the primer bulb, and 1 line from the primer bulb back to the tank. when you press the primer it draws fuel through the carb and returns it to the tank through the primer bulb
Oct 13, 2013 | Garden
Hey guys I have a stihl fs 85 r and I can't get
Hi Esh Weizman
Sounds like you have the fuel lines reversed going to and from the primer bulb.
I will put a picture up for you to see the routing of the fuel lines
Please take time to rate me
Bud
Oct 29, 2012 | Garden
1998 land rover discovery oil seal same idea transmission seal?
To jlcbnyc go to www.sthilts460chopsaw.com you can get a mvery good diagram of this unit.Good Luck snor38
Jan 25, 2011 | Stihl Concrete Cutoff Saw Ts460 Oil Seal...
I have a 1991 honda cr 250 I cant get to start at fist gas ran right thru carb and out bottom i took carb apart and got the floats to stop sticking cleaned it out with carb cleaner put back together but...
try a new spark plug. if u fowl out a plug some time they will not fire under compression.2 strokes need. fuel,fire and air, very simple engines.it is possible crank seal are bad .that doesn't allow the engine to create vacuum in the crank case.thus fuel and air will not make it to combustion chamber.
Jul 11, 2010 | 2002 Honda CR 250 R
Starts then dies stihl fs45/weedeater
I sounds like it sucked up some debris in the bottom of the fuel tank and obstructed fuel flow somewhere. Start by blowing out the in-tank fuel filter (You will have to fish it out with something), then load the line with carb cleaner (wear safety glasses) put fuel filter back in line and crank it a few times to pull the carb cleaner into the carb. This may dislodge the obstruction. If this doesn't work, you will have to remove and cleant he carburator. Hope this helps.
Jul 04, 2009 | Homelite Mighty Lite Lawn Trimmer
I have a 3516 chain saw mod22-600035-18 Mcculloch the fuel lines
I wish I could help. There are no parts available, there are no Exploded parts lists I've found a link to. These are Chinese chainsaws with the McCulloch name. They ARE Chinese chainsaws and I'm disappointed in Mac. Most mechanics won't touch them. We can provide no more help with this saw. Sorry
Lou
Poulan or Craftsman gasoline chainsaws are reasonably inexpensive, parts are available, and given a little TLC perform well.
Jun 10, 2009 | McCulloch Garden
Stihl chain saw won't achieve max rpm
Crank seals are leaking, causes lean or low vacuum for the carb to work properly
Mar 25, 2009 | Poulan ES350 16" Chain Saw
Stihl Ts460 Cut Off Saw Gas Tank Logo
52 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
