Question about Maytag M3V08S2A Air Conditioner
Air Conditioner Smoke
There is a smoke coming out of the air conditioner. It kind of looks like the smoke that leaves your freezer when you open it up and it's hot out.... and that cool smoke comes out.
    Novelist:
  • 159 Answers
The smoke you are seeing is the cold air turning the hot humid air into a cool mist. This may happen when you first run the a/c to cool the room. Once the room is cooled down you should not see the mist any more.
Posted on Jul 12, 2007
SOURCE:
In my air conditioner smoke is coming out is there any danger to worry
if smoke was coming out of my air conditioner i wouldn't use it, get it fixed. thats a silly question any dumbo would know that
Oct 15, 2016 | Heating & Cooling
Why is my air conditioner blowing white smoke?
Smoke or frost? More than likely frost make sure the air filter is clean and evaporator coil is clean this is a sign of low air flow across evap coil or turn fan speed up.
Aug 06, 2014 | Dometic Rooftop RV Air Conditioner
2004 Chrysler Voyager, had an acrid burning smell and a lot of smoke when heater is turned on, also a rattling/squealing noise, all stops when heater turned off?
you more than likely have a sciezed air con compressor. most modern cars have climate control which uses air con even when demisting and when engaged the electric clutch tries to engage but the pump itself will not turn, clutch will get red hot and burn your belts
Nov 25, 2013 | 2004 Chrysler Voyager
Odorless smoke coming out of my amana air conditioner is the problem odorless smoke coming out of my air conditioner wath is the problem?
That's a cool mist, like a fog. It's not smoke and occurs when the outside humidity is extremely high.
Be sure the air intake filter is clean and if it continues for a long time, raise the temperature setting of the AC a couple of degrees and allow it to run, until the mist clears. It harmless, so don't worry about it.
Thanks for choosing FixYa.
Jul 30, 2011 | Heating & Cooling
Whirlpool air conditioner blows out smoke it still blows out cool air but after awhile I see light smoke coming from the vents. Any suggestions?
Fortunately, that's not smoke. It's a cool mist or fog, that is caused by high outside humidity and the coldness of the cooling coils. Generally, it's nothing to be concerned about. Just be sure that you keep the air intake filter clean and the the drain hole in the drain pan is not clogged.
I hope this was of help to you and thanks for choosing FixYa.
Jul 24, 2011 | Whirlpool ACM082 Air Conditioner
White smoke coming from vent in room air conditioner
it sounds like it was humid which is normal for the cool air to mist, it will happen in your automobile ,also
Jul 24, 2010 | Airtemp B3Q06F2A Air Conditioner
Smoke is coming out of the a/c
Ice probably formed on the outside of the unit and the a/c is working to defrost itself. Check out this page: http://andysair.blogspot.com/2010/01/looks-like-smoke-is-coming-out-of-my.html
Jul 08, 2010 | Sharp AFS60NX Thru-Wall/Window Air...
KENNMORE AIR CONDITIONER
This smoke is actually condensation formed by having a humid room meeting the cold dry air. This is not a problem and does not pose a threat. Similar to the effect when you open your fridge or more obvious your freezer. Just temperature and humidity differances causing this.
Aug 03, 2008 | Kenmore 75085 Air Conditioner
Maytag M3V08S2A Air Conditioner Logo
2,232 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
