Question about Electrolux RHDFP60GS Duct-Free Kit
Electrolux RHDFP60GS Duct-Free Kit installation instructions
How to install dryer duct booster fan?
I believe you have the model with the pressure switch.
Pressure Switch (DVK100B-P Kit)
The pressure switch is designed to be mounted in the duct between the fan and the dryer. When it senses dryer airflow, the switch activates the DVK100B dryer booster fan.
The link below is for the instructions on how to install the fan w/ pressure switch.
http://www.aeroflotech.com/docs/DVK-P%20I&M.pdf
Jun 13, 2014 | Computers & Internet
Electrolux dryer won't heat
a gas dryer has a ignighter that may have burned out. a $40 part
May 12, 2014 | Electrolux Dryers
Where is the fuse on my microwave Electrolux PLMV169DCD located?
We have three service manuals covering the PLMV169 series, which you can download free:
http://www.microwavedisplay.com/plmv169dcc_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_late_prod_sm.pdf
They're all pretty similar.
You can usually find parts from the Pros here.
If not, contact Electrolux at the phone number on the front of the service manual.
It may be the C/T fuse (thermal fuse located above the magnetron) or the oven cavity thermal cutout, located on the top of the cavity.
Accessing these two parts for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Electrolux / Frigidaire owner's manuals and installation instructions
here.
It may also be that there was a power surge which damaged the control circuit board, activating the built-in surge protection.
This is not resettable. The circuit board has to be repaired. We do that for $39.95, details here.
Dec 03, 2011 | Frigidaire PLMV169DC Microwave Oven
I cant find the wear abouts of the bulb on my prestige oven model CS25
Check your owner's manual.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can download owner's manuals and installation instructions for Electrolux and Frigidaire here.
You can download GE owner's manuals and installation instructions here.
If the owner's manual doesn't cover it and there's no obvious cover on the side or rear, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
The light is sometimes located on the right side in the air duct attached to the magnetron or on the top of the oven cavity.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Some use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Jan 09, 2010 | Kitchen and Much More Microwave Ovens
Need assistance installing a JVM1660BB range microwave oven. How do I attach the sleave to the duct to the microwave, while mounting the Microwave on the wall. Thanks for the specs on the microwave oven....
From page 14 of the installation instructions online here:
"Extend the house duct down to connect to
the exhaust adaptor.
"Seal exhaust duct joints using duct tape."
Jun 06, 2009 | GE JVM1660 Microwave Oven
Unable to install the electrolux slide in electric range
  • Electrolux may have supplied generic installation instructions, failing to account for design differences
  • Electrolux failed to validate the installation instructions against the actual hardware
Jun 23, 2017 | Electrolux EW30ES65GS 30" Slide-in...
Frigidaire plmv169dcd not venting properly. Filters are clean.
If it's equipped with a charcoal filter, that needs to be changed (not cleaned) about every 6-12 months, depending on use.
I would also very the installation and venting set up found in the installation instructions.
You can download Electrolux/Frigidaire owner's manuals and installation instructions here.
If all that is proper, then I would suspect an obstruction such as an animal nest in the vent outlet or in the duct work.
Feb 14, 2009 | Whirlpool GH7145XF Microwave Oven
GE TRIM KIT NEEDS INSTRUCTION ON HOW TO INSTALL JX2030 KIT NUMBER
Aug 06, 2008 | GE Microwave Ovens
Electrolux RHDFP60GS Duct-Free Kit Logo
20 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
