Question about Home
3672 american standard touch switch whirlpool tub
arealplumber
  • 33 Answers
SOURCE: american standard whirlpool tub #2425
Here is the link to installation instructions:
American Standard #2425
The information you need is on page #7.
Hope this helps!
Posted on Dec 05, 2008
  • 7 Answers
SOURCE: Whirlpool pump only buzzes.
Well there are two things....You say "buzzes?" Like pump is running "humming" & not pushing water. That would be an "airlock" in the pump & it needs to be primed.
If it's "buzzing" & pump motor is not turning (Like it's froze) you might have a bad start up capacitor on the pump that needs to be replaced. Worst case scenerio entire pump needs replacement.
Posted on Jan 14, 2009
PartsCenter
  • 125 Answers
SOURCE: I bought American Standard whirlpool
no manual. Sounds like the motor is no good. What model and brand of pump do you have?
replacement Bath Pumps
Posted on Feb 24, 2009
  • 23 Answers
SOURCE: Button on American Standard Whirlpool tub is stuck
most tub buttons are attatched to a small air tube thats connected to a switch. if that tube came off the button wont work. just look inside your access panel the tube will be there check both ends if one came off vut 1/4 inch off and reattach
Posted on Jul 20, 2009
  • 80 Answers
SOURCE: how do you remove the jets on an american standard whirlpool tub
The jets have a nut on the back of the jet. I hope you have access or else you will need to pull the tub for this job. Loosen the nut and squeeze aquarium grade silicone in between the tub wall and the nut, Tighten the nut, but not to tight. Let set over night fill and check for leaks the next day.
Posted on Sep 19, 2009
Have an American standard whirlpool tub. the on/off button is stuck on on. now the only way to shut the jets off is to flip the breaker to the bathroom. how do I fix this
This sounds like the air switch in the motor is not working properly. You will need to remove the pump from under the tub to access the air switch located in a housing on the motor.
Replacement Air Switch will cost you about $20
US Parts Center
Aug 27, 2013 | American Standard Home
We have an American Standard whirlpool tub. It's probably about 20 years old and we haven't been able to find the model name or number. It's about 4' by 5'. Our problem: we don't...
you have to access the lower control the switch should be an air type one it uses air pressure from pushing in the button they some times crack ,dislodge or damaged and will not turn on or off unit also switch can fail
Jul 12, 2017 | American Standard Cambridge 5 Ft. x 32"...
My american standard jacuzzi tub doesnt work. It's plugged in, but the push button doesn't engage anything. It worked before I removed it to install ceramic tile around and under it.
check the air tubing coming off the back of the motor. that tubing should connect from the air switch on the motor to the bottom of the air button on the top of your tub.
if it is not connected then it will never turn on.
Feb 03, 2011 | American Standard Home
My American Standard Whirlpool does not turn on. I push the Power button and don't hear anything. Circuit breaker is on, anyone have any ideas? Thanks!
Remove access panel make sure pump is plugged in some electricians put a GFI outlet under tub for motor make sure GFI did not trip. Next the switch is an air switch look for the hose going to switch is connected last you may need a new air switch which is common to fail
Nov 03, 2009 | American Standard 2770.018w.020 Cadet...
My american standard jacuzzi tub is pluged in but jets won't turn on
check for power at plug in if power your vacume switch is probably out replace switch.
Apr 28, 2009 | American Standard 2771.002.021 Cadet 5' x...
I have an american standard air tub and cannot get the air jets to shut off.  They turn off, but come back on automatically a short time later.  How do I shut the power off?
Check the air vacuum switch and line as you may have a air vacuum leak. The button that controls the on and off to the jets is an air vacuum switch....It may have a slow air leak in the line or connections that is activating the on and off control
Dec 16, 2008 | American Standard 2748.328 Town Square 5'...
American standard whirlpool tub #2425
Hope this helps!
Oct 24, 2008 | Home
Home Logo
63 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
