Question about Sharp R-1514 Microwave Oven
Sharp R 1514 fan button
Fan button on the front is broken and Iwant to install a new spring. How do I get in there?
  • Sharp Master
  • 9,098 Answers
The only two springs I know of in this model are for the door open button and the door latch.
We have a similar model's service / repair manual and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly and troubleshooting tips.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
If you have a bad fan button, you would need to order a new select button assembly.
The part number is JBTN-B138MRF0 and you can order it here.
If you need other parts for this model, you confirm part numbers and order them from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Posted on Jan 29, 2009
Display panel r-1514
Possible that the control pad or the main board or the processor is faulty. You can remove the top cover after disconnecting and remove the front panel, check for insects within that have nested , if so clean the board and reset the panel connection. If not you can call for help to Sharp support at your place.
Check website : Sharp
Jan 31, 2013 | Sharp R-1514 Microwave Oven
How to install latch and spring in microwave door
You need to know where the 'catches' are inside the choke cover on the door to remove it carefully without breaking anything or marring the cover. You might get inside and find that the post for mounting the return spring has broken and that is part of the outer door panel.
Sep 11, 2009 | Sharp R-1610 Microwave Oven
Lower button - Start Minute Plus, does not return. Spring broken?
you have a bad spring and micro limit switch. You need to pull the cover in the front in order to remove that.
Jul 28, 2009 | Sharp Microwave Ovens
I have a sharp microwave oven R 1514. there are 4 buttons on the front and one is broken, will not pop back out. I bought new springs and need help with the installation
It looks like you need to remove the unit from the wall, remove the outer cabinet sheet metal, then remove about 6 screws from the backside of the control panel.
You should be able to tell as you get in there what needs to be removed.
But it doesn't look like you can access to replace without taking the outer cabinet off.
Jan 24, 2009 | Sharp R-1514 Microwave Oven
Interior Microwave doesnt come on..Burned out?
If it doesn't have a door you have to remove the cover. Its likely a special microwave bulb and the socket will have to be replaced with the bulb. the bulb is built onto the socket.
Jan 14, 2009 | Sharp R-1514 Microwave Oven
Push button foe a R-1870F Microwave. Somehow the button slid down in behind the conrols. How do you get it out. It look like some type of spring holds it in place.
You have a broken tab on your door open button (drawing ref. 3-2-4) or a broken door lever (ref # 4-25).
The button is normally held out by the spring.
You can find the entire service manual for the R1870/R1871 at our site here.
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 10, 2008 | Microwave Ovens
Sharp r-1514 microwave
check control circuit and related circuit.
Oct 25, 2007 | Sharp R-1500 Microwave Oven
Sharp R-1514 Microwave Oven Logo
112 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
