Question about Garden
Hot start problem with qualcut chainsaw - Garden
Machine won't start
Sounds like somethings blocked mate, strip it down and clean it out
Aug 18, 2014 | Hitatchi 32cc Top Handle Chainsaw 14"
When my chainsaw gets hot it wont start why
C.D.I is overheating ,replace ign.source.
Aug 16, 2014 | Poulan Garden
Saw want start when its hot
Hi tjjohnson042
your problem is a faulty coil...replace the coil.
It is shorting out when hot, when cool it will crank and run great
Please rate me
Bud
Oct 03, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hard time starting my husqvarna chainsaw when hot. chainsaw has choke but no primer
Poor hot starting on small two stroke engines can very often attributed to poor fuel quaility in your area, other things to check are that the air grills in the starter cover are clear, all the cooling air for the cylinder is taken through her, if there are any winter flaps in the partion wall of the top cover make sure these are closed, have the machine tuned by a compitent saw person, over speeding will increase the cylinder temperature and cause bad re starting, try not to let the machine actually run out of fuel, re fill before it does.
Sep 09, 2011 | Husqvarna Garden
The saw stalls when it gets hot and won't restart till it cools down
This is possibly an ignition coil breaking down when hot, the only answer is to replace it, before you do that just try slackening the fuel filler cap when it starts to die, if it picks up again there is a problem with the fuel tank breather.
Aug 22, 2011 | Poulan 18" Wild Thing Chainsaw
Homelite 10540 chainsaw 35CC chainsaw won't start when hot
Go to: http://www.drystacked com for a 12 page article on Walbro carburetor theory and troubleshooting. Check particularly, the position of the gasket in the lower chamber. Check the spark plug for blue, snappy spark when the engine is hot. If ok, place a small amount of fuel mix in the cylinder and try for start. If it pops several times, look to the fuel system. Check the fuel filter, air filter, and muffler for plugging. Does the primer bulb fill with fuel after several pumps? Check the fuel lines for decay or other damage. When the engine is hot, try not using the choke, but set the fast idle. Hope some of this helps!
Jul 13, 2010 | Homelite Garden
How to adjust a mcculloch 610 chainsaw carberator
there are two screws on the card of youy chainsaw one is the slow running jet the other is the full throttle jet start up saw run it till its hot adjust slow running jet first till saw ticks over ok then adjust fast running jet till you have full throttle,, start with both screw turned in to one and a half turns then adjust from there
Mar 28, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Eager ****** McCulloch Chainsaw; Won't start when hot...
Loosen the fuel cap just before you shut it down. Close it just prior to restart. If that corrects it, there is a fuel vent problem. HTH
Lou
Oct 05, 2009 | Garden
Chainsaw starts off running strong gets hot and quits after 10
Remove the muffler and inspect the piston and rings. If there are any vertical lines or grooves in the piston or the rings, you must rebuild the top end of the saw. (including cylinder)
Apr 05, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
127 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
