Question about Royal MC-14MX - 14-Sheet Heavy-Duty Micro Cut Paper Shredder Media Destroyer, MC14MX, MC-14MX, ADLMC14MX, ADLMC-14MX, 29351X
MC 14 MX paper shredder won't will not shut down until I turn it off
Keeps running until I turn it off
  • 35 Answers
SOURCE: My shredder keeps running and won't stop in on/auto mode
UNPLUG THE SHREDDER.
If this model has electronic eyes (optics) to control the auto-start/stop function and you oil the cutters, chances are the optics are contaminated with shredder oil. Take a cotton swab with a little alchohol and clean and dry the optics.
If you removed the top cover, it is a possibility that you disconnected the wires from the PC Board.
Posted on Mar 03, 2009
  • 5603 Answers
SOURCE: shredder keeps running when no paper
Some shredders have a switch to run continuous if desired. Check for that first.
Another problem is that during a jam, the paper sensing switch can get bent causing the shredder to run continuous.
Posted on Jan 09, 2010
  • 1218 Answers
SOURCE: Shredder motor runs but won't shred paper. No
If the motor is running do the cutting shafts turn??? if not then unplug and open up the top to see if any gears are broken/stripped; give Royal a call at 1-800-524-0799 for parts and prices once you've located the problem.
Posted on Aug 22, 2010
  • 1218 Answers
SOURCE: I own a Royal RL170MX shredder. I turn on the
If the blades rotate then the paper should go in...just be sure the blades are turning in the forward direction and not in reverse.Also make sure you lubricate the blades with shredder oil.
  • 1218 Answers
SOURCE: Royal 150MX shredder won't auto shut off. When
Prob could be the "eyes" in the middle where you put the paper in. They just might need cleaning with a soft cloth( unplug machine first.) If that dos'nt fix it the eyes could be faulty or the pcb could be faulty....give Royal a call at 1-800-524-0799 for parts and prices.
I have a TBI on my Chevy and when I turn the key on it keeps running the fuel pump after the 2 seconds like to know what to look for and where to find it
didnt specify year model or engine --generic answer --if the tbi is flooding ---check the fuel pressure regulator --and the tbi itself
Apr 16, 2017 | Cars & Trucks
Chain saw won't keep running
There are 2 adjusting screws, one is idle speed and the other is mixture. Adjust the idle screw until it keeps running. That may be all you need. But to check that the mixture is right turn the mixture screw, quarter turn at a time, keep count! until it flutters or speeds up. If it speeds up stop and adjust the idle back a quarter turn at a time until it runs without the blade turning.
Oct 25, 2016 | Garden
Sd0452a stuck in clean mode
When a Manitowoc is turned on in clean mode, It stays in clean mode until it finishes (about 30 minutes).If you turn it off and then on again,it just keeps cleaning. Let it run in cleaning mode until it finishes then turn the witch to ice mode.
Mar 25, 2014 | Manitowoc Kitchen Appliances - Others
Sanislim keeps on running
does anybody know where you can purchase spares for the sanislim just im looking for a replacement motor?
Feb 26, 2013 | Saniflo SaniPlus-Round SaniPlus Macerator...
2007 Pontiac G6 GT radiator fan keeps running after engine is turned off. Runs for another 4-5 mins after engine is turned off.
Heat sensor keeps blowing air thru radiator until it cools, then cuts off. Some auto do this. If it bothers you let the engine idle a few min. after you drive it and then turn car off. When you drive your car and the engine is hot it heats up even more when you turn it off because the water has quit circulating. The fan will run til it cools. It's supposed to do that.
Sep 03, 2010 | Pontiac G6 Cars & Trucks
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
To turn the fan off, press the "fan key" until it says "auto". This will turn the fan off. When the programs scheduled, changes, the fan will go on again. You have to repeat the fan to "auto" each time the schedule changes.
May 12, 2010 | Honeywell Programmable Thermostat Heater
My gas furnace keeps will run until it reaches
Sounds like the Thermostat isn't resetting quickly enough.
Feb 17, 2010 | Heating & Cooling
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Porsche 944 electric fan keeps running even when ignition is turned off
Replace the cooling fan relay, another person had the same issue, that's waht it was.
Oct 07, 2008 | 1989 Porsche 944
Royal MC-14MX - 14-Sheet Heavy-Duty Micro Cut Paper Shredder Media Destroyer, MC14MX, MC-14MX, ADLMC14MX, ADLMC-14MX, 29351X Logo
108 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
