Question about Ricoh Aficio SP C242SF Laser Printer
Ricoh Aficio SP C242SF Laser Printer sc 542 - Ricoh Aficio SP C242SF Laser Printer
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
  • 111 Answers
SOURCE: cannot faind Ricoh Aficio SP C410DN Laser Printer driver
you can find the driver here http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11540&ricohmodelid=6342&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fcl410%2Fcl410en%2Ehtm
Posted on Mar 21, 2009
EmmettPinger
  • 63 Answers
SOURCE: Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Posted on May 04, 2009
ricohmaster
  • 10 Answers
SOURCE: sc 542 error code
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
Posted on Sep 19, 2009
canontech
  • 1219 Answers
SOURCE: i turn on my ricoh aficio 2015 this code SC:542
itS THE TEMPERATURE OR FUSER RELATED ERROR.
try to clear it in service mode
Posted on Jan 13, 2010
How do I solve the sc 542 error problem on Ricoh aficio sp 3510dn printer when it does not have an online button or a number keypad?
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
Jun 22, 2016 | Ricoh Aficio SP 3510DN
What does the error message C8 mean?
press the helpful button
found this on fixya by J Mcallister
Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
Ricoh Aficio SP 100SU User Manual Error And Status Indicate On The Control...
Jan 27, 2016 | Ricoh SP 112SU 3in1 Laser Printer
Printer showing sc 542 code how do you reset the code
Fuser problem need to repair fuser first then you can reset code
Oct 13, 2015 | Ricoh Aficio SP 100SF e Laser...
Aficio spc242 service call sc543
There may still be small fragments of the paper jammed in the machines roller system that you might be able to get to.
At worsethe roller has teeth busted on the gears and pulleys.
Aug 03, 2014 | Ricoh Aficio SP-C242SF - 21 PPM Flatbed...
How to make reset for sc 542 for richo aficio 410 printer
That code requires going into the SP (Service Protocol) mode. If you have the service manual, it will tell you which buttons to press to enter it and to exit service mode. Once you enter service mode, power down the printer. If that doesn't reset, you have to go back into service mode, go the the SC/Fuser reset SP and once executed, power down then restart. Hint: you have to go to "SERVICE" then 1 will display. Press the right arrow key until you reach "5" then press the OK button. You can then right or left arrow until you find the reset SP. Good Luck.
Oct 24, 2013 | Ricoh Aficio SP C410DN Laser Printer
:Ricoh Aficio SP 3510SF error SC 542
Yes your MFP has had a fuser reload error. It's not permanent though. Sometimes the thermistors don't read the right temperature due to the thermistor getting excess toner built up on it or it gets moved away from the hot roller. This SC error usually can be reset by powering down the printer. It must be powered down correctly or you can corrupt the hard drive.
Hold the power button down on the operation panel until the screen goes dark. Then, physically turn the power switch off on the side of the unit. Once the unit has completely powered down and all lights are off, toggle the power switch back on. The unit should power back up normally. If the SC 542 returns, you'll have to have a technician check the fuser out.
Oct 24, 2013 | Ricoh Aficio SP 3510SF Laser Multifunction...
Codigo sc 542 en ricoh sp 3510 como resetearlo
Oi por favor. Gostaria de resolver meu problema com minha impressora ricoh 3510sf que estar dando o erro sc542. Me manda resposta. emiliomartinscte@gmail.com
Apr 09, 2013 | Ricoh Aficio SP 3510SF Laser Multifunction...
How to restart Ricoh SP C231n?
hi there, try to do the following:
- make a program mode (SP 107)
if you dont know SP mode, press clear/resume button then 1, 0, 7 then clear/stop button for atleast 5seconds.
*the monitor should appear 1.system 2.copy 3.
then press 1, then press 7,8,0,7 then #
*the monitor should appear COUNTER RESET then press 1 to start, let it finished then turn off and on your machine.,
*the SC-542 should disappear
note: if this will not fixed the problem, there maybe a problem with your FUSING UNIT, check it!
Nov 29, 2012 | Ricoh Aficio SP C232DN Laser Printer
My printer ricoh aficio SP 3400SF is showing service call error code SC542. kindly help to come out of this error. \r\nvr babu
FOR RICOH AFICIO SP 3400SF follow below steps.
1. To access Service Mode, On Control Panel press following buttons one
by one immediately.
Cancel Button (Red) ---> 1 (Numeric One) ---> 0 (Numeric zero) ---> 7
(Numeric Seven) ---> Copy Button (Green)
2. In Service Menu you will find Engine reset Menu. In that you can reset
SC 545 in Fuser Reset Menu. And you can also reset SC 542.
Jun 23, 2011 | Ricoh Aficio AP3800C Laser Printer
Ricoh sf3410 sc 542
go to maint. mode. Press Clear/Stop 1 0 7 . press Start key(hold) until you see maint. mode displayed. look for Fuser SC reset. reboot machine.
Oct 28, 2010 | Ricoh Aficio SP 3410SF Laser Multifunction...
Ricoh Aficio SP C242SF Laser Printer Logo
664 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
