Question about Dell Inspiron Computers & Internet
Ide error status 28 - Inspiron Dell Computers & Internet
Why is my kodak 5250 showing error code 3807?
Error: "System status failed" (3807) Published 08/25/2010 11:38 AM ' Updated 08/28/2012 05:23 PM ' Answer ID 1249
How do I resolve the error message "System status failed" (error code 3807)?
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
  1. Open the printer access door.
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
If the error is resolved, upgrade your printer firmware:
  1. Locate and select the firmware for your printer.
  2. Follow the on-screen instructions to install the firmware.
If the error is not resolved, contact us.
Jul 01, 2014 | Kodak ESP 5250 All-in-One Printer
Need help trouble shooting stuck on black screen dell inspiron 1720 so ran Diagnostics this is what i get backError code 0148 Msg:error code 2000-0148 Msg: unit 0:Ide error: status 1A error registry 0020h...
Error Code 0148
msg: Error Code 2000-0148
msg: Hard Optical Drive 0 - incorrect status 1 A Error
Register: 0020h
sense information: (02-0401)
sense: 70h 00h 02h 00h 00h 00h 00h 0Ah 00h 00h 00h 00h 04h 01h 00h 00h 00h 00h
Sorry but you have a hard drive issue. Replace the drive.
Mar 10, 2014 | Computers & Internet
Dell error code 2000-0151 incorrect status 28
That error indicates an "incorrect status" of your optical drive. I suggest you run the Dell diagnostics on your drive. To test your CD/DVD drive from the utility partition:
1. Reboot your system. When you see the Dell logo, hit F12 to enter the boot menu.
2. Select Boot to utility partition.
3. Select Test System.
4. Select Custom Test.
5. Use the arrow keys or mouse to select your CD/DVD drive.
6. Insert a CD or DVD.
7. Click Run Tests.
8. Write down any error messages.
Feb 28, 2014 | Dell OptiPlex 390 DT Desktop Computer...
Code 28
Code 28 Error Message
The Code 28 error is one of several Device Manager error codes. The Code 28 error will almost always display exactly like this:
"The drivers for this device are not installed. (Code 28)"
Details on Device Manager error codes like Code 28 are available in the Device Status area in the device's properties: How to View a Device's Status in Device Manager.
Aug 23, 2011 | HP Computers & Internet
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
DST Short Status Test (Error detected)
DST stands for Drive Self Test, it means your drive is failing.
I would get a new hard drive and USB enclosure, install new drive in laptop and install windows, then take the old drive and install it in the USB enclosure so you can connect to your laptop when windows is running and restore your files, assuming the drive is not completely dead.
thanks for rating
Jan 10, 2008 | Dell Inspiron 6000 Notebook
ERROR: code 28 -- Windows XP & USB 2.0
I'm unable to connect my western digital hard drive to my Windows XP computer via the USB port. When I check the USB 2.0 Controller in the Device Manager, there is a yellow exclamation mark (!) next to it. When I check on the status of the USB 2.0 Controller, the following message appears:
The drivers for this device are not installed (code 28).
What do I do now?
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Computers & Internet Logo
46 people viewed this question
Alun Cox
