Question about Jensen VM9410 Car DVD Player
Spare parts does anyone know where i can purchase spare parts like a power cord or a dvd laser lens for this model i purchased off ebay and it was missing a few parts i know how to fix i just cant find any sites for parts
DVD PLAYER OPEN&CLOSE WINDOW OPENING AT PLAYER RUNNING TIME
Posted on Apr 04, 2009
    New Friend:
I have a dvd player lens but, i am not able to match the loader
what should i do?
Posted on Mar 17, 2010
You can purchase the power cord at www.electronics-pluz.com or call 407-523-0159
Posted on Feb 26, 2008
Same thing. Jensen VM9311 looking for mounting cage & parts. Any suggestions where I can get them???
Posted on Jan 14, 2008
SOURCE:
I have a dcd 1650 and it won't read discs, but sometimes it does, I have checked and cleaned lens
A Laser Lens malfunction will cause this to happen and is a common problem. This can be fixed at home if a new Laser Lens or Laser Lens w/ transport can be found for your unit. I used ebay to purchase a new Laser Lens for my Denon DVD 5900. The part is also sometimes available from parts stores like Parts Express for a premium, $100+ Parts Express vs $17 ebay in my case. I would recommend purchasing a FACTORY SERVICE MANUAL from an online vendor. The manual will cost between $10 - $20 and is downloadable. The installation is very straight forward. The part that might not be clear would be the grounding shorts on the new Laser Lens. THE NEW LENS COMES SHORTED AND AFTER THE PART IS INSTALLED IN THE PLAYER THE GROUND SHORTS MUST BE UNSOLDERD FOR IT TO WORK CORECTLY. The part comes this way to protect the Laser from static shock damage.
The repair on a Denon DVD 5900 cost $30 and took about an hour to complete.
Jan 07, 2013 | Denon DCD-1650 CD Player
I am looking for a power cord for JBL on stage II speakers. Part no. 700-0042-001. Model no.TEAD-48-180800U
The following power cords will work with your speakers
You can purchase the power cord from the following site if you are in the UK:
http://www.power-adapters.co.uk/jbl-7000042001-acdc-18v-power-supply-adapter-p-7165.html
You can purchase the power cord from eBay if you are in the US:
http://cgi.ebay.com/AC-Power-Supply-Adapter-Charger-JBL-700-0042-001-/350422898000
Regards,
sjstore2
Dec 18, 2010 | JBL CREATURE II Computer Speakers
Cord
Tries websites like Amazon.com,Ebay.com to buy the a/c power cord for the replacement.
Jun 17, 2010 | Classic Electronics DVR1000 DVD Recorder
Put dvd in starts to spin but stops and displays no disc
ive seen this in countless DVD players either 1.the laser mech is toast or
2. the laser driver cog's are missing teeth
either way you need to replace the laser mech you can normally order one from a electronics service center to fit or you can contact the company/manufactuer and see if you can get a laser mech for the unit
now most cheap DVD player manufacturers do not supply spare parts as there made on the cheap in china and should when faulty be thrown in the bin and a new one be purchased! because it is not worth fixing!
hope this helps,ben
Aug 10, 2009 | Memorex MVD2042 DVD Player
Need to purchase a power cord
I could not find one on line but check with TigerDirect.com.  1-866-921-PART (7278)
May 29, 2009 | Westinghouse W33001 30 in. HD-Ready LCD...
Where to purchase ?????
try this ebay auction number it is a power cord for think pad for may different models this might just work for you. good luck!
ebay auction Item number: 270343560573
Mar 29, 2009 | IBM ThinkPad Replacement Part
Buy a power cord for Gateway 900?
I recently purchased a power cord on ebay. The price was awesome. Everywhere I went wanted over $100 I found mine on ebay for $12. So try ebay.
Jan 04, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
When I try to watch ANY DVD, after loading, the screen says "bad disc"
hello,
Sounds like you need to clean the optical lens on the inside of your player. You can do this the easy way and purchase a dvd cleaning disk or you can remove the cover of the dvd player, there will be a couple of screws on the side and a couple on the back. Once you have done that, open the cd tray and unplug your player from the outlet. Now take some cu-tips and a small amount of rubbing alcohol and lightly dip a cu tip in and look inside your player. You will see a small glass bubble inside the middle of the carriage that will be the optical laser reader. Gently swab off the optical lens a couple of times with each cu tip dipped in a small amount of alcohol. It would a good idea to also purchase a can of compressed air and blow your system out to make sure it is clean of dust and dirt. Make sure you blow the system out before cleaning the optical lens. Let dry for about 2 minutes before plugging back in and replacing the cover. Now try and play your dvds. You might also want to clean each dvd before placing them in your player as an added help. I hope this helps and let me know if you are still having problems because it could be a defective part and I will be able to let you know what it is with a few more questions and the answers you give.
If you do not mind please rate my help, I would really appreciate it. Thanks
Jul 09, 2008 | Cyberhome Televison & Video
NO disc
The same happened to me recently, you need to go to your electronic store and purchase a CD/DVD laser lens cleaner, put it in run it problem solved
Jun 01, 2007 | Panasonic SC-DK10 System
Jensen VM9410 Car DVD Player Logo
991 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
