Question about Brother Office Equipment & Supplies
I change a toner on the Brother MFC3760 but the change toner light stays on, what to do?
The change toner light stays on although I put in a new toner,
SOURCE: BROTHER 2030 TONER LIGHT STAYS ON CONTINUOUSLY
I had the same problem and Brother tech support walked me through this procedure which worked fine..
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Posted on Oct 24, 2007
SOURCE: Toner
Trick the thing. Put a piece of black electrical tape on the "eye". (Take cartridge out, on right side there's a small clear hole). Worked for me!
Posted on Oct 22, 2008
the kowalski
  • 86 Answers
SOURCE: BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE
To manually reset the counters, do the following:
  • Open front cover, press "option".
  • Answer Yes (by pressing 1) to the question in the display.
  • Your drum counter is now reseted. Press "option" again.
  • This time, press *, 0, 0.
  • Your toner counter is now reseted too.
(If nothing happens when pressing option, try using the back/clear button instead.)
Posted on Jun 15, 2009
komguy
  • 2306 Answers
SOURCE: Brother HL-2040 toner led stays on, won't print
There is a window on each end of the toner cartridge that you can cover with electrical tape and keep printing, it shines a light thru and when the toner is too low it says it's empty. The weight can be misleading.
Posted on Sep 02, 2009
SOURCE: Brother HL-2040 toner light stays on
I found this and it worked great.
1. Power Unit off
2. Open front cover
Posted on Nov 27, 2009
Testimonial: "Thanks!"
Toner light stays on after I changed cartridge
These are defects of Brother cartridges, even you put a new cartridge the toner empty still not reset. What we are doing is re-positioning the toner end cam on the side of the cartridge. You have to be knowledgeable with the machine to to that.
Apr 14, 2013 | Brother HL-2170W Laser Printer
Brother hl2270dw toner light stays on
Have you tried resetting it? I can't remember all the steps, I see some of the other comments have them but just to be sure you didn't miss anything I suggest you download the manual and go step-by-step. You can find one here - Brother HL-2270DW manual
Mar 24, 2012 | Brother HL Office Equipment & Supplies
The toner light came on. I replaced the toner, but the light stays on and it won't print.
Did you try unplugging the uint from the wall (leave it unplugged for 60 seconds at least ). Plug it back in and try again. If it still doesn't work try going into the software settings for the printer and tell it that you have put in a new toner cart. Usually when you install a new toner cart the software on your computer will sense that something has changed and ask. you might have better luck contating support at the Brother web site, since they made the printer and supposidly know more about it, good luck
Mar 10, 2011 | Brother HL 2270DW Laser Printer
I have just put in a new toner but still the
change the print mode and try in printing best mode.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | Brother DCP-8065DN Laser Printer
Toner light and Status light stays on
well it may need to be completely reset or you could try seeing if it is jammed or stuck in some way
Sep 11, 2009 | Brother HL-5240 Laser Printer
Have you removed the tape?
Try OEM toner from the manufacturer.
Good Luck.
Feb 25, 2009 | Brother HL-2070N Laser Printer
I have changed the toner in my printer and the toner light continues to stay on/won't print. I tried changing the drum and still the toner light stays on/won't print. I tried opening the toner door and...
No guarantee this will work but I refilled toner on my Brother 5170 and it only worked after making sure the old stuff was completely out. After removing the little plastic plug, I tapped out the toner repeatedly on the side of a trash can (like 50 times) then took a shop vac and let that **** out whatever toner was left. It really seems to be important for some reason to rid the cartridge of ALL old toner before adding the new stuff. Hope this helps!
Feb 23, 2009 | Brother HL-2040 Laser Printer
Toner light is still on
If you put new toner in your used cartridge and you still have the Toner light, you need to reset the "reset gears". Take the cover off of the gear side of the cartridge. The reset gears are actually attached to the inside of the cover. Move the gear with the lever to the opposite side of the current position.
Nov 30, 2008 | Brother HL-2170W Laser Printer
BROTHER HL-2040 LASER PRINTER- TONER LED INDICATOR STAYS ON AFTER I REFILLED THE TONER
Dont recomend refills causes too many problems, like you are experencing, put in a real brother toner should fix problem.
great link to explain of lights on panel
Dec 18, 2007 | Brother HL-2040 Laser Printer
215 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
