Question about Kenmore Sewing Machines
I took the tension apart for a kenmore 148.15600 model
I don't know how it goes back together. the tension assemble has at least 14 pieces. do you know how to put it all together
    Scholar:
  • 34 Answers
Hi - unfortunately, putting the tension back together takes alot of training - not only do you have to re-install the parts correctly so the hook is in the correct position and the bobbin is in the correct position when the needle moves down thru the needle plate and into the bobbin case to pull up the bobbin thread. Further, you need to set what called the timing - your needle needs to enter the bobbin dead on center and to a very precise depth. Technicians often use a special tool to set the timing, because each machine has a different a different hook and bobbin case.
I know this won't win me any points, but you will probably need to take the machine to a repair shop to have the hook replaced or reinstalled. If you mechanically inclined, you can search the web for a service manual for your machine - the service manual will illustrate how to replace the hook and specify the timing and needle depth settings.
Good luck,
Ginny
Posted on Jan 31, 2009
Kenmore 1249 top tension control is apart and don't know how to reassemble
Contact Kenmore.
http://www.searspartsdirect.com/partsdirect/brands-products/Kenmore-Parts/Sewing-machine-Parts?page=1
I don't see your model, but if you use the chat or call the number they may be able to send you a parts diagram with the info you need.
Nov 11, 2012 | Sewing Machines
How do i fix sewing machine tension?
#1 rule in dis-assembly of anything is to lay out the parts in the order they came off. I do this with a piece of tape turned sticky side up on my table. (for future reference)
As for your machine.. since you did not provide a model number the best I can offer is this parts page which has some diagrams under each model. Please locate model from the several pages listed... and view the diagrams.
http://parts.sears.com/partsdirect/getProductType.pd?parentCategory=Laundry+%26+Garment+Care&productType=Sewing-machine-Parts
Aug 19, 2012 | Kenmore Sewing Machines
I took apart the bobbin part of my kenmore machine and can't get it back together
if you look in the well where the bobbin is supposed to go do you see two white pieces of plastic with a red hyphen on them...one on either side? if so, take a small pointed object and pull the red hyphens toward the center of the well. put the assembly back in the machine (it will only go one way, so be gentle. when you get it lined up, it will drop in). then push the two white pieces back away from the center with your finger. drop in the bobbin.
Mar 03, 2010 | Sewing Machines
Can't balance top/bottom thread tension-model 158.Bottom thread is a straight line. Have increased top tension to the stop. No effect.Have reduced bobbin tension until bobbin and case fall freely when held...
I disassembled the top thread tension controller consisting of 12-13 pieces, including 2 springs. Since they all fell out on the table I spent about 2 hours learning the proper stacking order on the central shaft.
With a combination of reasoning based on each unique piece shape and trial and error I put it back together, adjusted top and bottom tensions according to the instruction booklet for the machine, tested some stitching, made final adjustments and all worked well.
I don't know what was changed in the process but it worked.
Don
Sep 03, 2009 | Kenmore Sewing Machines
Tension control on older sewing machine.
Better off taking it into a reputable sewing center to rebuild
Aug 22, 2009 | Sewing Machines
Cant put back together
Upload some photos of your machine, showing where you removed the parts from, also showing the parts you removed,
and I''ll guide you how to put them back.
Jun 09, 2008 | Kenmore 15516 Mechanical Sewing Machine
Putting back the pieces of bobbin case on Kenmore Mini Handi
This is for front loading bobbin..........
The Shuttle hook will look very much like this, and marries this to the "half moon" of the fixed shuttle.
The retaining collar ring that holds it all together has a plate like protrusion (like bull horns), this faces to the top and to the back.......there should be a small lug (or two) with corresponding small hole or slot on the fixed housing (hook race) that locates the ring tightly in the correct position.
There should be 2 swivel arms (black plastic at 4 o'clock & 8 o'clock)) that move to hold the whole thing together by clipping onto a small lug on each side of the ring.
If you tip the machine 30 degrees on its back while you do all this, it makes the process easier, as things are less likely to fall out.........support the back with a soft object for convenience (tissue box, pillow etc)
The bobbin case goes in after the housing is assembled, if you try to do it first, it will prove more difficult.
If this is not quite accurate for your model a photo of the bits would be helpful
Feb 27, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Sewing Machines Logo
229 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
