Question about Sony Playstation 3 (PS3) Console
The right analog stick does'nt work with fallout 3
About 50 hrs in to fallout 3 it glitched and then froze, when i restarted it and loaded the save point, the right analoge stick lost its function with fallout 3 and only fallout 3. i've tried other controlers and the same thing happens with fallout 3. The controlers works fine with other games. help...sos.
  • 1 more comment
  • Anonymous Jan 24, 2009
    same problem here but on the 360 version
  • Anonymous Mar 20, 2009
    same problem. my fallout never froze. I stopped playing for a couple days and when I started it up today the right analog stick would not function. i restarted the controller and then the system but it didn't fix.
  • Anonymous Mar 30, 2009
    i have the same problem for 360 but i have no previous saves cause i would always delete them for more room and now i dont know wha to do
If it works while youre on ur pip boy map then all you have t do is find a safe or door to pick the lock on. idk why and i know it sounds wierd but it worked for me i just picked the lock successfuly and it worked again.
Posted on Apr 23, 2009
  • 3 Answers
Omg i just had that managed to fix it by picklocking something, first get out of danger and use ur pipboy to travel to megaton break into a very easy house voila! worked!
Posted on Feb 18, 2010
  • 3 Answers
Codfo3 is right, I was exiting the broken bow of Rivet City by way of the locked door from the inside to complete the Replicated Man quest when my game froze on me. So, I restarted from an earlier save and exited through the locked door again, that's when my right analog on my dualshock3 froze. I could walk around but couldn't look up, down, left, or right. So, I got worried thinking "Great my DS3 was broken". When I brought up the Pip Boy screen I noticed that I could move the cursor around on the map, but couldn't look around in the game. I read codfo3's suggestion and remembered that I had left an ammo box in Super Duper Mart locked because my lock pick skill wasn't high enough back then. When I unlocked the ammo box, voila, it cleared up. Thanks again codfo3.
Posted on Aug 09, 2009
The same thing happened to me. The only solution i've been able to find I'm afraid is to load an ealrier save file. I learned a long time ago that when playing an rpg, one should always have multiple save files in case something happened that you didn't want. Say you save your game and you've got really low health. Happens to everybody. Well also say you've hit a point of no return without realizing and just around the corner you've got a huge boss fight. The only way to continue the game is throught the boss with nearly no health, and you can't turn back. You're pretty much screwed. However, if you have multiple save files, then you've got the dead end one you just made AND you've still got the save file from twenty minutes ago. So just load an older save file if you have one, beacuase these problems with the analog sticks will probably continue.
Posted on Feb 06, 2009
Xbox analog sticks are the wrongs way around.
In the options menu there may be a controller configuration called Southpaw. This reverses the sticks. It might be the problem.
Apr 13, 2012 | Microsoft Xbox 360 Controller
I have the original fallout 3 game and got the game of the year edition a year later i put all the add ons on the game took broken steel and the pitt off until im ready to play them but now the game keeps...
You might need an update from xbox live. If there is one available you'll have to delete any saved games and start fresh. The original release contains a glitch that the update should fix but if you keep playing on a saved game the glitch will persist.
Aug 09, 2011 | Bethesda Softworks Fallout 3 for Xbox 360
I cant look around in fallout 3 (right stick frozen), and my last save point was hours and hours ago. however the right stick works in pause menu and other games. what do i do?
What probably happened is your right stick was compressed when the remote turned on. Try turning the remote off and on, or un-plug and plug it back in. If that doesn't work simply save your game using the left thumb stick.
Mar 11, 2011 | Bethesda Softworks Fallout 3 for Xbox 360
Hi, My Xbox 360 controller is acting weird, but
That is an odd issue, I don't have fallout3 for the xbox, I play it on my gaming rig but I do have the wireless 360 controller for the PC. It might be that the configuration file on your saved data became corrupted or the orientation for the players dominant hand became corrupted. The preferences are stored with your saved games so you may want to see if the problem is in an older staved state. You may also wanted to check the game settings for anything like Left hand/Right hand position. I don't know how the settings are laid out since I am only familiar with the PC version. If all else fails you might have to altogether remove your saved games and restart from scratch, chances are there is some sort of data corruption.
May 09, 2010 | Bethesda Softworks Fallout 3 for Xbox 360
Fallout 3 disc reading/load issues
Try going to your memory on your xbox highlight the hard drive and Press Y on the hard drive symbol and then press the following: X,X,Left Bumper, Right Bumper, X,X. then select yes this will clear any game updates they will have to be re-updated
Jan 27, 2010 | Bethesda Softworks Fallout 3 for Xbox 360
if its glitched you most likey wont be able to get it to work if not try renting fallout 3 and see if it works with the rented one otherwise youll have to delete youre saved game and start over i had to do that with nascar 09 because it glitched me and only when i started over did things work correctly
Apr 28, 2009 | Microsoft Xbox 360 Arcade
Pipboy screen alignment off
I had this issue, but the only difference was, my pip-boy would go CRAZY bright green, however the only sad thing is, you will have to restart from your last save, there is no fixing this, there is many glitches I have found through-out the game..Just make sure you save frequently. BTW if you have any further questions about Fallout 3, just post more questions, I read these quite frequently, I have a lot of expertise in basically about 99% of Xbox available games :)
Let me know how it goes, nine_iron88
Thanks
Justin
Jan 23, 2009 | Bethesda Softworks Fallout 3 for Xbox 360
My ps3 it does`nt play any games or dvds
sad to say this, but maybe formatting the HD and then do a system update, might remove a possible glitch, but u will lose all info in the HD,other than that, i dunno.
Download an update to a memory stick with ur pc in case u need it.
Nov 19, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
2,955 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
