Question about MTX Thunder TA5302 - Amplifier - 150WATTS X 2-channel
How should i hook up 3 10 inch subs to a 2 channel amp
    Sergeant:
  • 248 Answers
Check out crutchfield.com they give wiring diagrams.
Posted on Jan 15, 2013
Crunch 2000.4 car amp, need help tuneing
re-check the speaker connections are correct and use a matching ohm test speaker on the other connections for a sound check. Sounds like hi frequency output into the sub amp. Sub-woofers are a mono signal!!
Jul 17, 2017 | Crunch Car Audio & Video
On a lanzar 535n 5 channel 3200 watt amp what is the best way to hook up 2 lanzar max 12 inch duel voice coil subwoofers
If your amp allows it hook the the sub's to the first two channels but bridge it and only run it on 2ohms so you don't blow your sub's
May 29, 2015 | Lanzar Car Audio & Video
Have 2 -12" inch eclipse sw6200 with two positive and negative hook up idk how to hook up from amp
It will depend on the capability of your amp. Each sub has dual voice coils (DVC). Each voice coil is (probably) 4 ohms. If your amp is a single channel, 1 ohm stable amp, you can connect all of the voice coils from both subs in parallel on the amp output. Other configurations will depend on the amp's number of channels and minimum resistance your amp can withstand.
May 01, 2015 | Eclipse Car Audio & Video
Looking for info on how to hook up sub to this amp thunder4160
Hi, you have two choices for hooking up a sub to the 4160 amp. You can either connect your sub to one of the two available channels, or if the amp supports it, you can bridge channels 3 and 4 to get increased power to your sub. You have a 4 channel amp - channel 1 and 2 go to your 3-way speakers up front, which leaves channel 3 and 4 available for your sub.
Jul 27, 2013 | Car Audio & Video
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
How do I hook up my 10 inch visonik sub woofers? they have 2 connections?
this is a dual voice coil sub. either have a 2 channel amp hook up to it. or have your mono amp have to sets of wires going out of it to your 2 connections. i dont suggest it but i have had one connection hooked up at a time played it when it blew hooked up the other connection as a back up. just make sure you have the right watt level for each voice coil.
Apr 14, 2010 | Visonik V10DV6W Car Subwoofer
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
Send me info how to connect a 4-channel car amp with 2 12-inch subs rear and 2 front 2-way speakers?
plug two subs in to amp in most powerful channel then your speakers in the less powerfull take your positive from your battery and hook it to your amp your ground wire shud just touch a solid piece of metal take your remote wire and hook it to your deck all other wires shud be with your deck need n e thing else holla
Apr 19, 2009 | Car Audio & Video
Hooking up DVC subs
The amp is rated to run a 2 ohm load on each channel. To do this, connect the voice coils of one sub in parallel (tie both "+" on the sub to each other and both "-" on the sub to each other), then connect that sub to one channel of the amp. Repeat this process for the other sub and connect it to the other channel on the amp. The subs will be in stereo and the amp will be outputting it's maximum power.
Mar 09, 2008 | Legacy 2CH 1000W AMP Car Audio Amplifier
Wiring my subs to my amp
bridge it and rear channel if you need to know how to bridge let me know
Feb 07, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
MTX Thunder TA5302 - Amplifier - 150WATTS X 2-channel Logo
46 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
