Question about Samsung HW-C700B Home Theater A/V Receiver
Samsung HW-C700B switching inputs
I have my receiver hooked up to my tv and cable box through HDMI and everytime I turn it on it goes to TV Optic 3 then I have to switch inputs on the remote then go back to TV and it will go to HDMI 3 then. Also it sometimes selects Audio to TV and not the surround sound.
  • 20 Answers
SOURCE: Samsung HT-TQ85 HDMI Input not working
I rember reading an article stating that the HDMI does not suppory audio
Posted on Sep 23, 2008
  • 382 Answers
SOURCE: I have an older Samsung surround sound kit that
Most TV's have a MONITOR OUT connections, sometimes called audio out.
This may be either analogue (RED / WHITE) or digital (optical or coax) simply run these back to the receiver's input and you should be good. Many TV you have to go into the menu and disable your TV speakers and enable audio output.
Cheers,
Kevin
Posted on Feb 10, 2010
hfmiles
  • 1165 Answers
SOURCE: Hi there, I bought this
I think you would have to use the tv remote control to change the input signal from the dvd receiver to the digital tv receiver. If that doesn't change anything, see if there is a setting for external speakers when not using the dvd receiver.
Posted on Feb 13, 2011
  • 14 Answers
SOURCE: on my sr606 receiver when
Try this. Check to see if you have the cable going round and accute corners. Sometimes the placing of HDMI sockets on the unit mean that the cable is forced into a sharp turn to route it to the cable box. HDMI cable is touchy when it comes to routing. For example an HDMI cable coming out the side of a TV and having to do an immediate 90 degree turn to get to the cable box is enough to scramble the signal. HDMI cable must not be kinked, wound up tightly or forced into tight angles. The worst offenders for this are curiously the more expensive cable as they have a tougher outer shielding that makes them more prone to situations in cramped and tight corners. If you really need to get round a tight corner, try a cheaper cable. Hope this helps
Posted on Mar 15, 2011
  • 961 Answers
SOURCE: no sound from tv. do
Your best hook up is going to be HDMI(out) from bluray and cable box to (in) on tv. The only thing you would need the optical cable for would be sound(out) to a reciever.
Posted on Apr 02, 2011
I hooked up my soundbar using the HDMI out (TV) port from bar to HDMI in port on my Philips TV power is on bar however I can't get any sound out of bar. But just audio cables worked what to do?
OK, If its the Samsung Sound Bar, this item should have 2 HDMI input, 1 3.5mm audio jack input and a digital audio input (fiber optic). Since there are various input, the remote control should have a source button, or it will probably read O/A Input, this is to change thru the inputs from the sound bar. If you connected your TV HDMI output to HDMI 1 from the Sound Bar, then press the source button to reach HDMI 1, maybe it will be display with a different name, like sound 1, or DIGI.1 Give it a shot and let me know in the comment section. Good luck.
Dec 19, 2015 | Samsung HW-H450 2.1 Channel 290 Watt...
I installed a HDMI cable and an Optical cable to whatch movies and shows from my LG HD LCD TV, but nothing seems to work. The stereo is also a LG LHB336 system. Which is compatible with the TV. We were...
Hi,Even though you have done some cabling already,for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 24, 2011 | LG 42LC2D 42 in. LCD HDTV
Just bought a samsung plasma hd tv. we are able to get satelite w/ sound but once we try to connect to the dvd/ vcr and playstation 2, we are unable to get sound or it shows up in black and white.need step...
Hi,here is my solution...
to listen your TV on your
stereo System
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out "of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
RECEIVER corresponding your RCA or Optic or HDMI connection
There you go..Your TV sound is on the
stereo Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
Thanks
Jun 26, 2011 | Samsung Televison & Video
I just picked up the Samsung HW C560S receiver. I'm trying to run a cable box as well as a blue ray player through it connected by HDMI. Blue Ray seems to work fine but can not get picture from cable box....
When you run the cable box and the blue ray player to your receiver you use two sets or cords yes? there for you need to run two sets of cords to your TV from the receiver. Have you done this? Both the DVD and Cable box will have different inputs to the TV. Turn the cable box on and cycle through the inputs on the TV. One should pop up for the DVD and a different one for the cable. Let me know if this works.
Mar 07, 2011 | Samsung HW-C560S Theater System
I hooked up the HDMI cable from the satilite to the satilite port and then the HDMI cable out to television. I have to have the samsung system on to get a picture. Is there another way to hookup so I don't...
if you have more then 1 hdmi on tv your box should have 2 u take and plug1 directly in to tv from box and keep it the same way and just change input on tv to hdmi 1 or 2 or 3 etc. most new tvs have 4 of them or let me know what box u have hope this helps ya
Jan 03, 2011 | Samsung HW-C560S Theater System
I have a samsung tv and samsung blu ray i have my dvr in hdmi 1 and my blu ray in hdmi 2. when i first turn on my tv and blu ray it works fine but if i switch to cable the back to blu ray it says no...
First, HDMI is not a perfect hook-up solution. Cable box connections via HDMI are notorious for being problematic. The best thing you can do is contact Samsung and get the latest firmware for your TV.
Samsung Customer Care: 1-800-Samsung (1-800-726-7864). If this does not resolve the issue, connect the cable box using Component cables instead of the HDMI. Component cables are HD also. I hope this was of some assistance.
Apr 07, 2010 | Samsung LN55B640 LCD TV
I just bought a yamaha rx-v365 receiver and hooked to my cable box via a hdmi and optic audio cable. this is working fine but i cant get a dvd player to work via a component and coax audio cable. neither...
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
Nov 25, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
Need hook up diagram for Samsung HDTV using HDMI with Cable box and Samsung 5.1 Surround Theater System
you can run a fiber optic cable out of the tv into the surround system if the sytem has a fiber optic input, or your tv should at least have red and white rca cables for audio out, then you just pick any input on the surround sound and any audio from dvd players ect thats hooked up to the tv will be sent through that one input on the surround sound. The only thing you'll have to do is turn the volume up or down on your sound system.
Jul 09, 2008 | Televison & Video
Samsung HW-C700B Home Theater A/V Receiver Logo
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
