Question about Dell Optiplex GX280 (99301) Motherboard
Dell gx280 memory
Ive just acquired a gx280 desktop with no ram, i put 2 1gig sticks in and nothing would come up on the screen but there were beeps a couple of times i tried it. after closer inspection of the ram it turns out that its pc2-3200R. by this time it now doesn't beep and the fan runs flat out.
would this have now damaged the motherboard?
  • 2 more comments
  • naymx5 Feb 08, 2009
    have now put the right memory in, but still no go, fan runs flat out. the only way ive found to make it boot is to apply pressure to the top of the fan on the one side, it will then boot up but when running the fan revs up and down some times to deafening speeds when in use.
    what could be causing the problem? processor socket nackerd?
    processor cooling fan. sounds like a jet-engine. the more load thats put on the computer the harder it spins. i know with these type of pcs the fans operate to load placed on the cpu but this is rather excessive.
    no dust,quite clean in side the case and in the fan / ducting. the noise is caused by the shear speed its running at, its running way above 6000 rpm from what the system has said.
    ive had a good look and they all look fine, no leaks or bulges. i have another board that does exactly the same as the one im using currently. will only boot if you push down on the exhaust side of the fan ducting and when running under normal usage the fan is flat out.
    these pcs are from a collage clear out of dud pcs they couldn't boot as they have replaced them, there typicaly out of warrenty when they gave up.
  • 73 Answers
It sounds like the memory is the wrong type. you should get SDRAM-DDR2 at 667 MHZ. pc2-5300.
Posted on Feb 08, 2009
  • 1 more comment
  • Matt Barr Feb 08, 2009
    Which fan are you talking about?
    Is there a lot of dust in the system? ive had this clog up the fans and cause them to make a lot more noise than necessary
    I beleive this system is part of a very large batch that dell sent out a few years ago that had motherboard issues. if you look around at the capacitors on the board, do you see any that look "popped"? They dont open up, they just bulge a little on top.
Intel gma 900 integrated ram
assuming you need a RAM upgrade... the GX280 uses DDR2 PC5300 memory, and can support up to 4 1GB sticks of memory.
Oct 07, 2013 | Dell OptiPlex GX280 PC Desktop
Memory upgrade on gx280 beeps on boot but doesn't start. memory beeps 1 234 5 6
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer. The other issue is if that model supports 4 gig memory.
Aug 30, 2012 | Dell Computers & Internet
Issues with 2gb 32ddr dell memory compatible in dell gx280
Unfortunately, the CPU on these computers may be capable of handling the 2GB memory, the motherboard isn't on either system.
The specs for the Dell GX280 are available here: http://support.dell.com/support/edocs/systems/opgx280/en/ug/specs02.htm . This system takes 400 or 533 MHz DDR2 non-ECC memory and the form-factor determines the maximum memory. In the mini-tower format, you have 4 DIMM slots and can have 4 GB of memory. In the small form factor, it takes 2 GB max.
The Dell E310 specs are available here: http://support.dell.com/support/edocs/systems/dim3100/en/sm/specs0.htm . This system can only support 2 GB (2 x 1 GB) memory.
I wish that I had better news for you.
(who had a similar Pentium 4 computer with the 1 GB limit. Since that system was running a 32-bit system and only actively addressed 3 GB, I didn't try to put 2 GB sticks in any of the 4 memory slots.)
Dell optiplex gx860 continuous beep
This indicates a motherboard problem, first remove the ram one stick at a time and test as you go, if one stick is bad the computer won't start up. If memory checks out, remove hardware one at a time and put back as you check up the ladder, if all checks out the motherboard is the most likely issue.
Mar 03, 2012 | Dell OptiPlex GX280 PC Desktop
What is the most memory l can put in my dell optiplex gx 280 desktop ,l have 512 in it now
For mini-tower and Desktop
You should have 4 slots.
4GB is the max if you replace all the sticks.
For gx280 SFF (Small Form Factor)
You should have 2 slots.
2GB is the max if you replace all the sticks.
Nov 17, 2010 | Famous Brand Dell Optiplex GX280 Intel...
6 long beeps Dell GX280 -- unsolved Please help auntie! I have four PCs model RB-DT-OL-Dell GX280 ? they are fairly thin and light, you can open them like a suitcase. They worked just fine, then all of a...
I had 1 long beep, 3 faster beeps, then 2 beeps *I think*, and also my fan was going crazy fast - like someone else said "a vacuum cleaner"...
Well, I reseated the memory and problem was gone - it did seem like the memory was kind of "loose" - perhaps from shipping (bought this used).
The link to Dell's website was good for the beeps AND the "ABCD" codes reading on the back. Thanks very much! God Bless.
Jun 27, 2009 | Dell OptiPlex GX280 PC Desktop
Long low bleeps after adding RAM
it is either incompatible or dead.  try it in another machine.  if the stick of ram runs, it is likely an incompatibility.  refer to your documentation included with the motherboard/laptop (you didn't clarify) to see what it supports.  there is actually a huge difference between pc100 and 133 (which are now obsolete) and ddr2 and ddr3, although they respectively share similar pin count and layout.
May 18, 2009 | Dell OptiPlex GX280 PC Desktop
"my computer will only beep no screen,it beeps
Hi
You likely have a bad memory module. First, try removing all the memory and putting it back in again. This is called reseating. If you still get the errors, then try removing one stick at a time and testing it with each stick (provided, of course, you have more than one stick installed). If you only have one stick installed, remove it and turn on the computer and it should beep at you as well. That memory stick will need to be replaced.
Thanks and please take a moment to rate this solution as fixya. Thank you.
Mar 14, 2009 | Dell Dimension 8200 PC Desktop
My dell gx 280 just put new ram
Here is the code,Please make sure the memory you used is DDR2 and please rate this a fixya
Feb 14, 2009 | Dell OptiPlex GX280 PC Desktop
Computers & Internet Logo
654 people viewed this question
Alun Cox
