Question about Belkin F5D7330 802.11g/b Wireless Adapter
I can get iternet access on the desktop, and the router says that everything is connected (at least.. accordig to the status lights) and yet, I'm unable to get the wireless to connect. no laptop in the house can connect to it, not even my brand new one... its showing that theres a full signal, but i'm getting an exclamation point when i pull up my wireless manager. I've ried resetting botht the router and the modem, and unplugged both for 15 seconds at a time. I'm stumped.
  • splinky311 Jan 24, 2009
    Hi MrMark. Thank you for your assistance. I am trying to fix this for a friend, and don't have access to an owners manual. Ordinarily, ive never had to alter security settings before, as the network is unsecure, and my laptop will cinnect to unsecured networks without issue. any clarification and assistance you can offer would be immensely helpful.
    President:
  • 1,214 Answers
You need to set up security on the router that matches that setup on any wireless laptops.
Reply respond and I can give you more directions, but the procedure is in your owner manual.
Posted on Jan 24, 2009
  • Mark Egan Jan 24, 2009
    Go to the Belkin website and download the manual. I just checked, there is one there.
Cannot acces iternet
Remove power from everything, Batteries, if applicable check cables, power Modem, wait for selftest, power Linksys,wait for selftest, reboot computer.
Dec 15, 2012 | Linksys WAG325N Router (WAG325N-AU)
Windows vista crashed. changed bios to load xp. worked. old files on hidden drive. problem is cant connect to internet. driver files on hidden drive. Now what? Try to find driver and load it?
your explanation is very confusing. your internet connection must come from a modem either directly or remotely thru router. your mentioning of hidden drive does not make sense. drivers are not part of internet connection. you need to reset the modem and router if you are connecting through it. turn everything off. unplug router and modem. after 15 seconds unplugged, plug only modem in, wait until lights stablize; now plug router power back in, wait for lights to come on;,next turn PC on. Wait until completely booted up. go to control panel click on Network Internet, when opens try to find the local connect to network. if none, then your modem is not receiving signal or IP Address from your internet provider(comcast,centurylink, whoever). check status, if active fine. if active but icon says no internet access then your router is not set correctly. you may have lost its set up and you will have to reset up your router. you should have the step or instructions for doing that. after resetting and network active, restart computer so that is receives fresh settings from router.
if no network is found after restart you may have to reconfigure your internet connect by using the internet connection wizard(control panel).
Sep 27, 2012 | Dell Dimension B110 PC Desktop
Linksys stop connecting to computer
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop/desktop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. check with the ISP to see if you have an outage.
8.check status lights to if the power and the Ethernet are functioning properly.
9. power to the router > Ethernet cable connected> ISP shows connectivity.
Jun 17, 2011 | Computers & Internet
No iternet connection for widows7amber light keeps flashing internet isworkimg but not though router 80211
Do you see the network on the pc you are trying to access the internet from? If yes, then check to make sure the cable is securely connected from the router to the cable/dsl modem. Try to change the cable out completely if you can. You can also try to bypass the router to the computer to make sure you do have a signal coming in for internet. Try to reset the router and reconfigure it. If you on a loptop make sure you have the wireless on, some models you can switch wireless on and off and this will prevent you from accessing the internet.
Jan 19, 2011 | Belkin (F5D7633UK4A) Wireless Router
Cant share internet using a router
Hi There, what model of dlink router do you have?
Also, Or just check the ports you have in your router, the internet should be connected to the WAN port and the switch and/or computers to the LAN port(s).
If the router is new by default you should be able to access internet by plug everything the way I told you.
Also, by default the router ip address should be 192.168.1.1, type that into your web browser address bar, then you will have access to the router admin web page were you can see the status page, there will tell you if you have or not access to Internet really. Maybe the problem is that the router have no access internet access at all.
Mar 12, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
I cant get virgin netgear router to connect to my medion laptop, i get to the last part of the installation process when it says attempting to connect to newtork and it comes up move your connections...
Have you accessed and setup your wireless part of the modem?
To access the router settings menu, you will first need to log into the Wireless router following the steps below:
Open Internet Explorer
In the address bar type the following address:
192.168.0.1
You will be prompted to enter a Username and Password to access the interface, please use the following default details:
Username: This can be found on the bottom of the router
Password: This can be found on the bottom of the router
From the list on the left hand side, click on ‘Router Status’.
Within the Router Status section there are two areas you will be able to access:
Show Statistics
Connection Status
The Router Status page gives you a detailed status overview of the connection configured on the Wireless router.
Click ‘Connection Status’ to see more information on the broadband connection.
If you have already configured your broadband, you are able to establish/terminate the connection by clicking Connect/Disconnect.
You can also click ‘Show Statistics’ to show you current connection speed and more information on your Broadband connection.
Clicking on Basic Settings enables you to check all the Internet settings of your Broadband connection. Including the Login name (username) and password, IP address and type of connection.
Clicking on ‘Test’ will perform a standard check of your Internet connection and settings.
ADSL SETTINGS
The ‘ADSL Settings’ section provides you with some more information about your Internet connection. These are:
Multiplexing Method
VPI
VCI
WIRELESS SETTINGS
This section gives you full information regarding the Wireless connection. From here, you can change security settings, the SSID (Name) of the router and the access control list. Options list from:
Name(SSID) virgin broadband (default)
Region Europe(default)
Channel 11(default)
Mode g&b(default)
Enable Wireless Access point
Allow broadcast name
Security options (None, WEP and WPA)
- hope this helps
Jul 03, 2008 | Computers & Internet
SMC EZ Connect Access Point apparently not connecting to wired router
you doing something wrong there.
give the mac address of smc to the access point that's all you get it
Feb 18, 2008 | SMC EZ Connect (SMC2655W-KIT) 802.11b
Linksys wireless broadband router and wireless access point
Hi I would love to help you with all the resources and knowledge I have, however, this would require online chatting kind of. You either reach me using the live chat feature of Fixya or just add my msn id in your messenger : sandeepbakshi@hotmail.com. Whenever I am online, I would assist you. Again, if the above given suggestion is not possible, please give me the following details: 1. exact model no (on the bottom panel) 2. firmware version (if possible) 3. no. of hard wired PCs (directly connect) 4. No of wireless computers 5. ISP 6. any other device connected to the router 7. status of internet on the hard wired PCs 8. status of wireless computers 9. The status of lights on the router (dont forget to specify the labels on top of the lights to make things clearer) thank you
Mar 10, 2007 | Linksys Wireless-G WRT54G Router
Belkin F5D7330 802.11g/b Wireless Adapter Logo
178 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
