I can unlocked my tv
After I switch on the tv Is came indication Lockheed.
  • Washing Mach... Master
  • 17,130 Answers
Please redirect your problem to the TV link of fixya.
Posted on Jan 15, 2013
If I buy the whole Lockheed-Martin, could I own an F-35?
Yes, if you have any money left over.
Jan 04, 2017 | Aircrafts
What is the probability for switching sim in Samsung Corby tv
Hi, If you need to switch the SIM card in your Samsung Corby TV mobile you may need to check whether your mobile is network restricted. If it is free from network restriction you can use any international GSM SIM to it. If it is network restricted You need to unlock it before using any other GSM SIM to it. These are the two probabilities in switching a SIM to your Samsung Corby TV mobile phone. If your mobile is network restricted, You can unlock it safer and easier using unlock code. You can get the unlock code from www.wickedunlock.com/samsung-corby-tv/rs11wp9/ at affordable cost.
STEPS FOR UNLOCKING SAMSUNG CORBY TV
Method 1:
1 - Switch ON your Samsung Corby TV with a NOT ACCEPTED SIM Card.
2 - Samsung Corby TV will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Corby TV shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Corby TV.
3 - Compose : #0111*CODE#.
Oct 05, 2012 | Cell Phones
Replaced batery in key fob and now there is no connection between fob and security system...I can lock and unlock doors with the key and I can start car ...fob doesn't work; does not lock or unlock...
reprogram the remote transmitter. first leave driver door open all other doors closed,key removed from the ignition switch. insert key into the ignition switch,then remove it.press lock and unlock on the vechicle door lock control switch at 1 second intervals 5 times. close and repoen drivers door.press lock and unlock on the vechicle lock control switch at 1 second intervals 5 times. insert key into ignition switch. switch ignition on and off twice to program a remote transmitter code whilst erasing the original codes or three timre to check how many remote transmitters are currently registered.remove key from the ignition switch.system should now lock and unlock.twice to indicate programming mode or one to four times,slowly to indicate number of remote transmitters registered.for the solara press and hold lock and unlock remote buttons together, press lock remote button for a second period of 1 second. system should now lock and unlock vechicle.once to confirm, twice to indicate registration has failed.if required repeat button procedure to program remaining remote transmitters.note to exit programming mode close drivers door or insert ignition key.maximum of 4 remote transmitters can be programmed.if akk failed let dealership reprogram remote transmitters.
May 18, 2011 | 1999 Toyota Camry Solara
How to unlock the tv with out a remote?
Hello
If you haven't a remote, it is very difficult to unlock the TV. Anyway try these following steps. Sometimes may help you.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Wish you sucess.
Oct 24, 2010 | RCA TruFlat 27F520T 27" TV
Hello, I have a question, how to do yo reprogram the remote control on a 2004 GMC Yukon?
CLOSE ALL DOORS INSERT KEY INTO IGNITION.DO NOT TURN THE IGNITION SWITCH.PRESS AND HOLD DOOR LOCK SWITCH IN THE UNLOCK POSITION.SWITCH THE IGNITION ON OFF ON OFF.RELEASE DOOR LOCK SWITCH.SYSTEM SHOULD NOW LOCK AND UNLOCK VECHICLE INDICATING PROGRAMMING MODE ACTIVATED.PROCEED AS FOLLOWS.NOTE EXISTING REMOTE TRANSMITTER MEMORY POSITIONS WILL BE OVERWRITTEN.PRESS AND HOLD LOCK AND UNLOCK BUTTONS ON THE FIRST REMOTE TRANSMITTER FOR 15 SECONDS.SYSTEM WILL LOCK AND UNLOCK VECHICLE INDICATING REMOTE TRANSMITTER PROGRAMMED.REPEAT ABOVE PROCEDURE FOR EACH REMOTE TRANSMITTER.IF THIS DONT HELP DEALERSHIP HAS TO REPROGRAM REMOTE.
Aug 09, 2010 | 2004 GMC Yukon
Power locks are unlocking but not locking only the driver side locks and unlocks
the rubber pads on the door lock actuating lever are worn or the actuators are weak. They would need to be tested and looked at to determine this problem
Jun 25, 2010 | 2000 Chevrolet Tahoe
MY TV HAVE LOCK UP
I just fixed my celera k12b-c11 tv. All you do is hold the f button and the mute button in for 3o seconds, and your tv will unlock itself.
Sep 26, 2008 | Quasar SP-3235 32" TV
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
