SC 441 NASHUATECH MPC 2050
I have an error code sc 441 on a mpc 2050.Voici manipulation applied: . replacement engine ITB . replacement OPTICS SENSOR: + encoder ENCODER ITB . replacement photointerruptor drive unit: on / off tranfer Roller But it still does not work .... Can you help me solve this problem please
SOURCE: ricoh aficio 3500
sc441 error means one or more of the developer unit(PCU) isnt rotating. you have to take the PCU out to see which color isnt rotating. there maybe one of the doctor blade is flipped, usually caused by lack of toner in the PCU.
Posted on Jun 05, 2008
SOURCE: Replace Transfer Roller
In the Phaser 6250 Color Laser Printer Service Manual (which I had to have emailed to me from my toner supplier since it is not available to the general public) I went to Chapter 6 - Error Messages and Codes. I had to reboot the printer. Here is the procedure.
Entering by rebooting the printer:
1. Turn the printer power OFF
2. Hold down the Back and Information buttons simutaneously and turn the printer
back on.
3. Continue to hold the buttons until the following message is displayed on the front
panel: Service Diagnostics V#.##, Initializing ....., and then release the buttons.
4. The front panel displays the Service Diagnostics Menu.
On the display is a menu. Find Transfer Roller. Press enter on this menu where it says Toner Waste (Not Full). Back out of the menu.
All of a sudden the machine came to life. You may have to turn off the printer and turn it back on again.
Good Luck
Posted on Jun 11, 2008
Bubbabear64
  • 2794 Answers
SOURCE: sc 322, sc 326 codes
Never heard of this happening to five machines before.  Check the connections in the laser unit.
Posted on Oct 27, 2008
  • 9 Answers
SOURCE: sc 322
Another poblem with this machine is that the sync detect for the 400 dpi and 600 dpi could be off. Go into service modes by pressing the yellow clear modes key then pressing the numbers 1 0 7 then hold done the red stop key till you see the display change. Now go into copy sp, then hit the 2 in the window {drum}, next use the page down button located in the middle of the screen till you see the one that says 2109 LD Beam Pitch Adjust. Go to number 2109-8 beam pitch data reset. execute then go to 2109-1 and set it to 144 then hit pound. Now go to 2109-3 and execute. last go to 2109-2 and set it to 168 then hit pound. Now go to 2109-4 and execute. exit out of the service modes window. now try to run a copy and a print. If these fail the you either need to clean the laser assembly, a polygonnal mirror moror or laser drive unit.
Posted on Dec 16, 2008
idriss47
  • 26 Answers
SOURCE: ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Posted on Jan 07, 2009
Ricoh mpc 350 error school 972 what is the resion Ricoh mpc 3001 error code sc 972 how I can fixed it
If you wish to get some details about printer repair and service; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 31, 2016 | Ricoh Office Equipment & Supplies
MPC 2050. What does SC 495 mean?
my dear you chek develper tenk and imge sensor chek
Jul 30, 2015 | Ricoh Aficio Office Equipment & Supplies
Ricoh mpc 2050 sc 222
222 Laser synchronizing detection error: start position [Y]
The laser synchronizing detection signal for the start position of the LDB [K], [Y], [M], [C] is not output for two seconds after LDB unit turns on while the polygon motor is rotating normally. Disconnected cable from the laser synchronizing detection unit or defective connection. Defective laser synchronizing detector. Defective LDB. Defective BICU.
May 23, 2015 | Ricoh Aficio Mpc2050 Color Digital...
Mpc 2050 sc 222
Laser sync detection error (Y): Replace BCU board Laser sync detection error (Y): Replace laser unit Laser sync detection error (Y): Check laser unit connections
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Mar 31, 2015 | Ricoh Office Equipment & Supplies
Plz help sc 681 in ricoh mpc 4500
• NoiseRFID: Communication error • Communication error occurs when the RFID starts to communicate with the RFID receptor. • Retry of RFID communication fails three times after the machine has detected the RFID communication error.
The problem is Defective RFID reader and writer • Disconnected ASAP I/F • No memory chip on the toner cartridge • Noise
Mar 14, 2015 | Ricoh Aficio MPC3500
Richo error code sc 829
I have Aficio MPC 2550 and it displays Sc 829. Is the a way to reset this code?
Apr 05, 2012 | Ricoh Aficio 1035 Copier
362 people viewed this question
jasbo
jasbo
