Question about LG Heating & Cooling
Vinegar smell in air conditioner
Hi WE have a vinegar smell coming from our lG wall mounted air conditioner. The model number is ASNW 24GC2U1. How do we clean up this problem. We understand it may be mould ? Valerie
  • 105 Answers
SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Posted on Jul 15, 2007
SOURCE: Fujitsu wall mounted air conditioner.
Is it a split system? I had the same problem with my split system and and it was because the condenser line was mounted wrong. The line was mounted so the water had to go uphill and it was causing the condensation to leak through the front of the unit.
Posted on Aug 14, 2007
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
Agent Don
  • 310 Answers
SOURCE: Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Posted on Apr 15, 2008
  • 230 Answers
SOURCE: Can a window air conditioner fit in an exhisting wall mount?
I bought window AC (5000 btu) that fit 17 in. at home depot. made by Zenith. Keep in mind of your room size.
Good luck.
Posted on Jun 10, 2008
When I try to turn on my LG wall mount unit it will not turn on
Does it give you a code? Try turning only one at a time to see if that works. I would like to help you but need more information.
Sep 18, 2014 | LG LWHD1800R Wall/Window Air Conditioner
Kelvinator wiring diagram for wall mount air conditioner model ewh09hra
Good Morning Friend,
I understand that you are looking for the wiring diagram for your Kelvinator air conditioner, model# EWH09HRA. Typically, the wiring diagrams are not readily available. I suggest contacting the manufacturer, and have your model number available for them. They might be able to locate a copy of the wiring diagram of your air conditioner for you. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Electrolux Heating & Cooling
Ice buildup in wall mounted unit
Icing on evaporator is caused by:
Dirty evaporator
Bad cold control
Low charge
Low ambient air temp
May 25, 2010 | LG LS-L1210CL Mini Split Air Conditioner
I have a ch-2 code on a lg air conditioner and curious what is the problem or how to fix it
HI; Look In Your owners manual. If you dont have one goggle the company, pull up on front cover then out be very gentle. Info for company is on a data plate. The company will need the model and serial numbers..alpharome416
Jan 18, 2010 | LG LP120HED Wall/Window Air Conditioner
Need to find manual to download for LG 2.5 hp neo plasma wall mounted air conditioner
You can find it her, you just need to have the full model number, probably located in the control panel http://www.lge.com/us/support/product/support-product.jsp
Jun 11, 2009 | LG Heating & Cooling
Wall unit emits a chemical smell when the unit is running
check the condensate pan clean out with vinegar water solution make sure you do not see any oil residue that would be a sign of a refrigerant leak let me know if you have further problems your manual should tell you how to get the cover off
Jan 08, 2009 | Fujitsu 18C1 Air Conditioner
Musty smell from wall mounted airconditioner
You need to check to ensure that your unit is sloped to the outside of the window. The correct formula is 1/4" per foot. This can be checked with a level.
Hope this helps Ya please rate me.
Jun 20, 2008 | LG Heating & Cooling
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Jun 12, 2008 | Heating & Cooling
Heating & Cooling Logo
1,113 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
