Question about GE Spacemaker JVM1640SJ Microwave Oven
Change a light bulb on amana rcs10ds microwave
Amana Microwave over the stove. Need to replace light bulb. So what is the part number?
If the model number is correct in your post and I assume you are talking about the over the range light and not the cavity light then you need 53001905 halogen bulb, charcoal 53001442 still available
Jan 17, 2015 | Amana AMV5206AAS Microwave Oven
Amana microwave F1961 bulb
If you wish to get some details about microwave oven and its working ; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
Jun 09, 2014 | Frigidaire FMV156DC Microwave Oven
Microwave light socket shorted out
every thing all right accept working heater both heater tube doesn't light or no power on it
Nov 14, 2013 | Amana Radarange Microwave Oven
It sounds like a jet engine and will not heat up food.
That is normally the high voltage capacitor not charging
Oct 07, 2013 | Amana RCS10DS Microwave
Replacement door
This, I have found, is one of the best places to obtain Amana parts. I hope this is helpful to you.
http://www.repairclinic.com/Amana-Microwave-Lighting-Light-Bulb-Parts
Aug 25, 2013 | Amana AMV1150VAQ Microwave Oven
Replace microwave light bulb
See page 24 of the owner's manual here:
Feb 06, 2009 | Amana AMV5206 Microwave Oven
Trying to replace a light bulb on an amana microwave
The lamp on this model is an assembly - bulb and socket mated together.
It is mounted in an air duct on the right side of the oven near the magnetron.
You'll have to remove the outer cover to get to it.
You can find helpful exploded view diagrams and order the bulb by entering your full model number here.
Dec 09, 2008 | Amana ACM1580AS Microwave Oven
Amana AM6177 Microwave
Interior light bulb is located behind the grill, above door. It requires removing 3 or 4 screws to remove grill. I have same problem. I pulled out bulb, it looks like it was glued in some type of foam material. There are two pin connectors at the mounting. but I can't see how they fit into bulb.
Apr 07, 2008 | Amana AMV6177 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
18 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
