Question about EliteGroup ECS P4M900T-M2 Socket 775 Motherboard
Installing the panel pins to my case - EliteGroup ECS P4M900T-M2 Socket 775 Motherboard
    President:
  • 2,692 Answers
Trying to install an ASUS H81M-C Mainboard with Intel core i5-4460. No way to turn on. Mainboard's Power led is on. Nothing happens at all. All connections are OK. Anyone has an idea? Thanks.
When you say that all connections are ok, you understand that we have to verify as this is the most common problem that occurs when installing motherboards. Obviously you have the large connector from the power supply plugged in since you have the power led on the motherboard. This is good. There is also the ATX 12V CPU 4-pin power connector that must be connected just above and to the left of the CPU. But the most often messed up arrangement are the front panel connections to the motherboard at the lower right corner. This is a 9-pin connector block (actually 10, but top right corner pin not there and bottom right not used).
In the link attached, go to page 26 of the pdf, which is page 1-18 of the manual. At the top of the page is a drawing of the connector block. The green power led takes the first two pins in the top row from the left. The connector plug should have a green and a white wire. The green is the positive and goes on the left pin of the pair.
Right below that is the two pins for the HDD light. This plug should have red and white wires. The red wire is positive and goes to the left pin of the pair. Going back to the top, the power button is the remaining two pins. These wires can vary in color from case to case, but if you don't see a label, just follow them back to the power switch to figure out which pair they are. This connector can be installed either way, there is no fixed polarity. The remaining two pins are for the reset switch, which some cases have and some don't. This connection does not to be used.
If you have everything correct and the unit still won't power up, then you need to verify that the power switch is working. If you have a reset switch, it is easy to test, just switch the reset and power button connectors and press and release the reset button and see if the board powers up. If you don't have a reset switch, remove the connector from the power button pins and carefully short them together for a brief second, which simulates pressing the power button. If it still doesn't power up, then there is something wrong with the motherboard.
One last thing, if the front panel connectors are all installed into one plug (which some manufacturers like DELL does, and you are installing this motherboard into their case, be sure to verify that the wires on the connector goes to the appropriate front panel switches/indicators, as these connector blocks are not fully standardized.
Nov 23, 2015 | Intel Computers & Internet
How do I replace the Leviton Bi-Pin on a Linear Fluoresent Lampholder?
Take the end cap off the fixture case - unwire the old socket and reverse the process for installing a new socket.
The little slots on either side of the socket slide onto the fixture case.
Nov 12, 2014 | Leviton 23351 T8 Or T12 Turn-type...
I have an IBM NetVista PC model #830781U and want to install additional memory...1GB chip... How do I do it??
Ok, first of all before installing the ram, you want to make sure the ram you are installing into your computer if the motherboard support the type of ram chip you are installing it in. For your model it is ddr184 pin After this, you can take out your case panel which is the left side by unscrewing the 2 screws in the backside of the panel. Carefully take the panel apart from the computer and set it aside. What you want to located is the RAM slot on your motherboard which typically is 2 slot next to the cpu which has the big fan. Most likely one of the slot or both of the slot is already accompanied by the old memory chip. There are two hinges one on each side, bottom and top. Push these pins down and it would loosen up the memory chip that is already installed on. Replace the new memory chip and make sure you align the golden tooth pins extacly to the memory socket and then push down on the chip until it clicks. Test your computer if it works, if not. You computer may not support the memory chip.
Jan 13, 2011 | IBM NetVista PC Desktop
Installing Hitachi Deskstar 40 GB drive as slave. Where do the connectors go. It says model IC35L060AVV207-0. Installing drive in Dell 4600
Look at the "connectors" end of the disk-drive.
There will be a set of thin pins for the "data" cable,
and thicker pins for the "power" connector,
and a smaller grid of small pins.
It's these pins that will be labelled/engraved on the casing:
MA(ster), SL(ave), C(able)S(elect).
Move the jumper to the "slave" setting.
Connect to the power connector.
Connect to a "data" cable.
When you add power to your computer, it should recognize the drive.
Dec 26, 2010 | Hitachi (HTS424040M9AT00) 40 GB Hard Drive
I AM INSTALLING A NEW POWER BUTTON... I NEED TO KNOW WHAT PLUGS WHERE...
If it's the power button that is on the case, it plugs into the motherboard. Most likely, in the lower right hand side as you are looking into the case with the front of the case to your right.
The little row of pins is labeled. You are looking for the label pwr sw or something similar. If you can't see any labels, short each pair of pins with a small screwdriver--two at a time. When the machine turns on, you've found the correct two pins.
Aug 25, 2010 | E-Machines T3958 (827103050974) PC Desktop
Where to hookup front panel (PIII-3754LMR - AMPTRON)
Front Panel Connector The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
please rate this post.
or donate on madridtelecom@gmail.com
Feb 08, 2009 | Intel Motherboard
Connecting front panel wiring to INTEL 845GRG Motherboard
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Thank you for using FixYa.
Input, comments are welcomed.
Mike
Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
Front panel Pinout
the pins are usually labeld on the board itself or in the board manual
May 22, 2008 | IBM NetVista PC Desktop
EliteGroup ECS P4M900T-M2 Socket 775 Motherboard Logo
173 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
