Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
''dl'' code comes on
''whilpool washer wtw6600sw1'' has a door lock code coming on after it makes several attempts to lock,, I have tried unplugging for 1 minute. no luck..
  • 318 Answers
The door lock switch has a solenoid lock to keep the door closed during cycles. if you tried to open the lid during a cycle then you may have damaged the lock and it should be replaced first.
if you still have troubles after that, then the control board may have an internal failure.
the lid switch costs about 30-40 bucks compared to 120-150 bucks for a board. try the lid switch first.
there is a test cycle you can run to check the lid lock if you want to do that also. but by starting a cycle it will do the same thing.
Posted on Jan 30, 2009
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Dl code comes on on my wtw6400sw washer
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Sep 20, 2011 | Whirlpool WTW6400SW Cabrio Washer
Continue to receive DL (Door/Lid cannot lock) error message. Pause/cancel and then start don't work. I have made sure nothing is blocking the door. I have unplugged and plugged back in. Continue...
Hi
Hope this helps...Please post back if you need more information.
Daniel
Jan 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
F/dl code comes on - machine doesn't run
failed door lock error, i would first unplug the unit for about 5 minutes this will reset the board. if that doesnt work you may have a bad door latch. .inspect latch that the piece on the door that when you close door piece on the door makes contact with the latch. hope this helps
Sep 16, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Washer model 48051. I am
i think the dl code is clogged water pump,tip it back and you can remove the water pump cover and check it-mike
Jul 17, 2009 | Kenmore Washing Machines
Dlf error code comes up when i try to start washer
Total repair time < 5 minutes 1. Unplug washer 2. Remove top from washer using 9/32" socket wrench (3 screws in back) 3. Locate the white connector panel on back 4. Remove 3rd connector from right in the connector panel (1st from right has 2 wires in it, 2nd from right has 2 wires in it, 3rd from right as 4 wires in it -- all of the wires into my connectors are pink) To remove, push down on top 2 pins then pull out 5. Put the connector back in. 6. Replug in washer and watch it work. 7. Get a sharpie an mark "F/DL" above the connector -- you will be glad you did 8. Put top back on 9. Comment here that "it fixed it for me" 10. Do something nice for someone today -- even just a smile for someone looking down.
I have to do this once every 9 months with my heavily used washer (I have 4 kids).
Hope this works for you.
May 12, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Fdl code message
>"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I am getting an DL F code on my front loader
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
836 people viewed this question
Dan Webster
Dan Webster
Sal De
